POV-Ray : Newsgroups : povray.general : Creating 16-bit HFs from C++ Server Time
14 Jan 2026 22:14:58 EST (-0500)
  Creating 16-bit HFs from C++ (Message 1 to 10 of 18)
Subject: Creating 16-bit HFs from C++
Date: 21 Feb 2005 05:57:12
Message: <4219be88$1@news.povray.org>
I'm writing some code in C++ (on windows) to generate some 16-bit height
field data.  What is going to be the easiest way for me to export the
numbers to use in POV?  The PNG file format looks pretty complex (compared
to BMP which is what I'm used to).
Is there any way to make POV use red+256*green or something like that from a
BMP file?  Or some software that will make red+256*green into 16-bit grey
PNG?
Thanks
Scott
Subject: Re: Creating 16-bit HFs from C++
Date: 21 Feb 2005 07:18:38
Message: <4219d19e$1@news.povray.org>
> PNG?
> Thanks
> Scott
Hi Scott
You could use TARGA to export your data. There is an introduction to
this format here :
http://astronomy.swin.edu.au/~pbourke/dataformats/tga/
I did write a piece of C++ some years ago that handled the
reading/writing of TGA images, but I fear it's not terribly well
coded... And it is badly commented, and in french... I could give a try
at cleaning it up if you wish, but I think you'd be better off writing
it yourself ;-) Anyway the format is rather easy to understand.
Hope this helps
Vincent
Date: 21 Feb 2005 09:45:33
Message: <4219f40d@news.povray.org>
  The png format is not intended to be read/written directly (unless you
are a really hardcore programmer... :P ) but there are libraries for
that purpose. Of course at least the most common png library is pretty
hard to use all on itself, but that's another issue... ;)
> PNG?
  From http://povray.org/documentation/view/3.6.1/279/
"The TGA and PPM file formats may be used as a storage device for 16
bit numbers rather than an image file. These formats use the red and
green bytes of each pixel to store the high and low bytes of a height
value."
  The raw TGA file format is extremely simple. It has a 18-byte header
(which format is fixed) and then the raw image data.
Date: 21 Feb 2005 10:31:25
Message: <4219fecd@news.povray.org>
> value."
Thanks, raw TGA is exactly what I need.  Cheers.
Date: 21 Feb 2005 14:27:59
Message: <cjameshuff-F0941A.14280321022005@news.povray.org>
In article <4219be88$1@news.povray.org>, "scott" <sco### [at] spamcom>
PNG would be the best option. libpng is really not that hard to use,
just follow the examples in the documentation. You get lossless
compression and files that are widely supported.
Alternatively, you could encode the data as 16 or 24 bit fixed point
float values split into 8 bit chunks among the RGB channels, and either
use POV-Ray's built in red-green "16 bit grayscale TGA" feature or
combine the channels manually using a function to generate the height
field. I would suggest the latter...it seems most flexible.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 23 Feb 2005 01:13:19
Message: <421c1eff$1@news.povray.org>
Have you considered writing the data out as a mesh2?  Since you're
writing a C++ program anyway, it's probably a lot easier to write a few
floating point numbers out in text format than to write out a specific
image file format.  Plus you get to have a greater degree of precision
than with a 16 bit image file.  Also you can control the mesh smoothing
if you calculate a few normal vectors.
I wrote a C++ program (win32 command line) that takes a raw 32bit
floating point output file from World Machine, calculates the mesh, does
a non linear transform (cylindrical wrapping), calculates the normal
vectors, then spits out a mesh.  Email me if you'd like the source and
you can feel free to use it however you like.
Peter D.
> PNG?
> Thanks
> Scott
Date: 23 Feb 2005 05:53:01
Message: <421c608d@news.povray.org>
Peter Duthie <pd_### [at] warlordsofbeercom> wrote:
> does a non linear transform (cylindrical wrapping)
... to the vertex points, you mean?
  (Technically a mesh is more than just its vertex points, and performing
a transformation on the vertex points is not the same thing as performing
a transfromation on the mesh.)
Date: 23 Feb 2005 12:04:57
Message: <421cb7b9$1@news.povray.org>
Aha, me too, but linux is my choice.
As Christopher mentioned libpng is not that hard to use.
Just yesterday I took a look at the manpage (man libpng) and there are
several examples on how to write the image data.
I didn't try it yet, but it didn't look too complicated.
Maybe within the next week I'll have some C++ code.
Sebastian H.
Date: 23 Feb 2005 13:01:13
Message: <421cc4e9$1@news.povray.org>
I believe height fields trace considerably faster than their equivalent
meshes.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Feb 2005 13:19:25
Message: <cjameshuff-99376F.13180923022005@news.povray.org>
In article <421cc4e9$1@news.povray.org>, "Slime" <fak### [at] emailaddress>
> meshes.
Have you tried it? (I haven't...I'm really wondering if there's much of
a difference.)
A mesh has other advantages as well. You could create overhangs and
other structures, make it higher resolution tessellation in areas that
are more important, use a tessellation that doesn't produce artifacts
that are as obvious, etc. You can also compute the normals more
precisely while you're generating the mesh, rather than estimating them
from the triangle data. Look at the height field macros to see the
difference this can make...they compute the normal by looking at the
slope of the height function.
On the other hand, an image-based height field is easier to
edit...though you really need something that can handle 16 bit images.
