POV-Ray : Newsgroups : povray.general : Media singularity Server Time
25 Dec 2025 19:18:43 EST (-0500)
  Media singularity (Message 1 to 5 of 5)
Subject: Media singularity
Date: 16 Feb 2005 21:10:49
Message: <4213fd29@news.povray.org>
http://img115.exs.cx/my.php?loc=img115&image=pattern7jc.png
What is the cause of the seemingly chaotic pattern?
Thank you,
William
pattern.pov:
//POV-Ray 3.6.1.icl8.win32
global_settings {
  assumed_gamma 1
  max_trace_level 170
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.04
    recursion_limit 1
    low_error_factor 0.5
    minimum_reuse 0.015
    adc_bailout 0.01/2
    media on
   location  <6, 8, 10>
   up        <0, 1, 0>
   right     <1, 0, 0>
   look_at   <0, -1, 0>
sphere {
  0, 30000
   pigment { color rgb 1 }
   finish { diffuse 0 ambient 1 }
  hollow
  no_shadow
#declare fsqr = function(a) {a*a}
plane {
  y, -5
  hollow
  pigment { rgbf 1 }
  finish { diffuse 0
           ambient 0 }
  interior{
   media{
    intervals 20
    emission 0.01
    scattering { 4, 1 }
    density{
     function { fsqr(sin(x/4)*sin(y/4)*sin(z/4)) }
Subject: Re: Media singularity
Date: 16 Feb 2005 23:19:16
Message: <Av74XDA6sBFCFwJ4@econym.demon.co.uk>
I'm no media expert, but I guess it's something to do with the way that
POV is calculating the position of the "exit point" of the plane, which
is then used to determine the spacing of the samples. The "exit point"
is actually an infinite distance away, but POV somehow has to convert
that into some large finite value. I guess this value varies in an odd
way from pixel to pixel.
Normally that doesn't cause a problem, but with this periodic density
function small changes in the spacing of the samples can cause resonance
effects.
If you replace the "plane {y,-5" with a box of finite thickness,
something like "box {<-1000,-1000,-1000><1000,-5,1000>" the chaotic
effect goes away.
Mike Williams
Gentleman of Leisure
Date: 17 Feb 2005 22:23:05
Message: <MPG.1c7f0d25885a1fa2989d06@news.povray.org>
In article <Av7### [at] econymdemoncouk>,
nos### [at] econymdemoncouk says...
> effect goes away.
Though.. Technically, it isn't infinite, the plane bisects a sphere, so
the media is actually contained in that. Reducing the size of the sphere
to 10000 still produces the same oddities, though with some faint white
streaks in it, like the edges of ripples. 5000 and the whole thing starts
to get murky and darker, but the pattern never disappears and it starts
to look like some odd thing floating inside the media. I need a faster
computer.. lol But seriously, it doesn't seem to be a result of the
ambient on the sphere either... This is really odd.
Hmm.. It gets less visible at a sphere size of 2000 and pretty much
vanishes, (in the sense that it is no longer a 'sharp edged' pattern), at
1000, though the resulting pattern is still showing complex oddities. It
is nothing like what a box produces. This definitely seems to be
*entirely* related to the choice of using a sphere and a plane to create
a container for the media. Definitely interesting, but very strange.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 17 Feb 2005 23:54:16
Message: <RgknXEA7RXFCFwLu@econym.demon.co.uk>
>> effect goes away.
Yes. It's more complicated than I thought.
The effect doesn't appear when using a box, but it does appear when
using "difference {  plane {y, -5}  plane {y, -1000}" when the lower
plane is sufficiently distant. When using this difference, the sphere
can be replaced with "background {rgb 1}" and the effect remains exactly
the same.
Mike Williams
Date: 18 Feb 2005 15:09:32
Message: <MPG.1c7f25bd6d3ef93b989d07@news.povray.org>
In article <Rgk### [at] econymdemoncouk>,
> the same.
Yeah.. This:
global_settings {
  assumed_gamma 1
  max_trace_level 170
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.04
    recursion_limit 1
    minimum_reuse 0.015
    adc_bailout 0.01/2
    media on
   location  <6, 8, 10>
   up        <0, 1, 0>
   right     <1, 0, 0>
   look_at   <0, -1, 0>
plane {
  y, -5
  hollow
  pigment { rgbf 1 }
  finish { diffuse 0
           ambient 0 }
  interior{
   media{
    intervals 20
    emission 0.09
    scattering { 4, 1 }
    density{
plane {
  y, -100
  hollow
  pigment {rgbf 1}
  inverse
Probably comes a lot closer to what it 'should' look like. It still gets
artifacts if the second place is at -200, so you may have been partly
right, or maybe completely, I didn't let the previous 'working' version
with the sphere finish so can't compare them. Likely the light bounces
around so make times that anything 'thinker' than about 100 units
generates artifacts. Probably an effect of trace level or some other
setting, though increasing it to 'fix' the problem would slow the media
down even more. The artifacts this produces btw are very different when
you place the second plane at -15000, where the sphere limit would have
been, but with some similarities, so the 'shape' does effect the
artifacts when they do appear.
void main () {
  else
