POV-Ray : Newsgroups : povray.general : Indentations/Lines on balls Server Time
11 May 2026 10:53:58 EDT (-0400)
  Indentations/Lines on balls (Message 1 to 9 of 9)
Subject: Indentations/Lines on balls
Date: 7 Feb 2005 00:34:59
Message: <4206fe03@news.povray.org>
We've all use a tennis ball or basket ball. I'm trying to model some
balls in pov and need some help. What's the best way to create the lines
that go around them? (Like the white one on a tennis ball and the black
ones on a basketball)
My main goal is to model a netball. They have a different pattern than
most balls as the lines are really the stitch lines between each piece
of leather that makes the ball.
See one here:
http://www.supertramp.co.uk/images/gilbert_all_weather_netball.jpeg
I can get the material right (or close enough) just by playing around.
However, what advice can I get on the lines? They don't need to resemble
stitches as only the top balls are REALLY stitched. The others are just
pressed into the plastic.
Cheers!
Rick Measham
Subject: Re: Indentations/Lines on balls
Date: 7 Feb 2005 09:10:25
Message: <420776d1@news.povray.org>
> lines that go around them? (Like the white one on a tennis ball and
> the black
I've seen pov source that makes a tennis ball seam, and baseball or
cricket ball. Probably around 4 or 5 years ago on Compuserve. I'll
check my old archives.
Alf
Date: 7 Feb 2005 10:47:49
Message: <42078da5@news.povray.org>
Sorry - nothing found back to '95.
Alf
Date: 7 Feb 2005 12:04:43
Message: <42079fab@news.povray.org>
> See one here:
> Cheers!
> Rick Measham
Looking for this:
http://objects.povworld.org/cgi-bin/search.cgi?X=ball
Maurice
Date: 7 Feb 2005 18:16:04
Message: <4207F6B9.3020400@nomail>
> the black ones on a basketball)
Maurice replied:
> Looking for this:
Exactly that! Thanks.
However, the method here uses a texture map around the ball -- which
works well -- but I don't know how to properly create the lines for a
netball. I can play around. I've worked out that a rectangular line run
through photoshops rectangular-to-polar will give me something fairly
useful, but I still need to work out what the pattern is. If there is a
known, easy, way to do this can someone let me know?
Cheers!
Date: 7 Feb 2005 18:31:46
Message: <4207fa62$1@news.povray.org>
Doesn't look like there's going to be an easy way to do this.
One thing which you can benefit from is that the pattern is symmetrical with
6 sides, like a cube. The corners of that cube are marked on the ball by
where 3 seams come together (in the image you provided, in the upper left,
upper right, lower left, and lower right, and there are four more we can't
see). So it may be possible to "cut" the sphere into 6 parts by using
gradient patterns with normals like <1,0,1>, and then make a single, square
image map which, when overlaid on top of these parts properly, creates the
seams in the right places.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 8 Feb 2005 07:04:31
Message: <4208aacf$1@news.povray.org>
"Rick Measham" <nomail@nomail> wrote in message
news:4206fe03@news.povray.org...
> See one here:
> Cheers!
> Rick Measham
Hi Rick,
I've put my attempt at a netball on povray.binaries.images with the source
on povray.binaries.source.
Chris B.
Date: 8 Feb 2005 15:21:48
Message: <42091F63.5010304@nomail>
What a legend!
This is terrific Chris. I'm slowly getting my head around how you did
it, but the results are brilliant!
Thank you so much for your time and effort.
Cheers!
Date: 24 Feb 2005 09:11:31
Message: <421de093@news.povray.org>
Still looking?  I've found the file I was looking for, (while looking
for something else). Its in html by Daren Scot Wilson, 9KB, has full
explanation and cut-and-paste SDL scene, pre-1998. If you want it,
email me at the address in my sig.
Alf
http://www.peake42.freeserve.co.uk/
http://www.qsl.net/gw3srg/
