POV-Ray : Newsgroups : povray.general : mesh question Server Time
14 Aug 2025 04:01:43 EDT (-0400)
  mesh question (Message 1 to 9 of 9)
Subject: mesh question
Date: 4 Feb 2005 15:40:22
Message: <4203ddb6$1@news.povray.org>
How do I select which diagonal to use when converting quads to 2
triangles? I need to use information from 2 adjacent quads? I can't
figure it out :(  Any online suggestions?
The vertices are stored in an array
  #declare Verts = array[N][NPoints+1];
and the quads are extracted (clockwise) in nested loops
  #declare Tp1 = Verts[Count][VPt];
  #declare Tp2 = Verts[Count][VPt+1];
  #declare Tp3 = Verts[Count+1][VPt+1];
  #declare Tp4 = Verts[Count+1][VPt];
TIA
Alf
Subject: Re: mesh question
Date: 4 Feb 2005 17:41:05
Message: <4203fa01$1@news.povray.org>
> triangles?
It should not matter...
-Sascha
Date: 4 Feb 2005 18:17:55
Message: <420402a3$1@news.povray.org>
> > triangles?
It does. A general solution is to connect using the shortest diagonal. If
you don't, you can get very stretched triangles, which don't look too good
for texture/phong-interpolation. This might not be that big an issue in most
cases, but in extreme cases, you want to have a fairly even triangle instead
of long and sharp ones.
Tim
"Tim Nikias v2.0"
Date: 5 Feb 2005 05:41:15
Message: <4204a2cb@news.povray.org>
> > triangles?
  Actually it matters when you use uv-mapping. This graphic illustrates
the problem in question:
http://www.cs.tut.fi/~warp/images/uvproblem.gif
  (Let's see who is the first to wrongly answer something related to
perspective... ;) )
Date: 5 Feb 2005 09:32:50
Message: <4204d912$1@news.povray.org>
>> triangles?
This image of the leading edge of an aircraft wing using large
triangles, shows the problem:
http://www.peake42.freeserve.co.uk/pix2/mesh1.jpg  13K
It looked like the shadow line artifact but if I flip the diagonals
the surface looks OK. Unfortunately, the problem re-appears elsewhere
:c(
Date: 5 Feb 2005 09:32:54
Message: <4204d916@news.povray.org>
Ahhh...  Thank you. There's always a simple answer. I'll try that.
> If you don't, you can get very stretched triangles, which don't
> look too good for texture/phong-interpolation.
Thanks again. See the link in my reply to Sascha.
> This might not be that big an issue in most cases, but in extreme
> cases, you want to have a fairly even triangle instead of long and
> sharp ones.
This is easily sorted. The wing rib outlines are stored in an array of
splines so I only need to interpolate between splines. Unfortunately
this will increase the triangle count. Oh well - I've got 1G ram now
so press on :c)
Note: I started this WIP around 3 years ago, and it has been abandoned
many times ;) See
http://news.povray.org/povray.binaries.images/thread/%3C3c6d9fde@news.povray.org%3E/?ttop=189070&toff=3000
Subject: Framed, an X-WIP (34k)
Date: 15 Feb 2002 23:55:10
Alf
Date: 5 Feb 2005 15:44:14
Message: <4205301e$1@news.povray.org>
Oops... of course you're right!
>>>triangles?
> Regards,
> Tim
Date: 5 Feb 2005 16:19:42
Message: <4205386e$1@news.povray.org>
Thats interesting, I never thought about that...
This leads to the question: Does splitting along the shorter diagonal
also give better results concerning u/v mapping? I drew a few irregular
quads and by taking a look at how they would be u/v mapped I got the
impression that splitting along the longer diagonal might be slightly
"better"...
Is there anything that can be done about it (e.g. are OpenGL quads meant
to somehow overcome this kind of problem)?
-Sascha
Date: 5 Feb 2005 18:57:00
Message: <42055d4c@news.povray.org>
  OpenGL quads show this exact problem when the quad is not rectangular
nor rhomboidal (ie opposite sides are not parallel). This (d)effect
can be clearly seen in many cases, for example if you tesselate a
torus with quads (the quads at the upper and lower side of the torus
will exhibit this problem).
  Theoretically there exists a method for avoiding this problem, but
I have not heard any 3D hardware (nor even software) using it:
Render quads as quads, not two triangles, and scale the texture
non-uniformly to adjust to the shape of the quad (as in the
to-be-expected illustration in the image I gave a link to).
  In fact, you can even render the quad as two triangles given
that there's a proper correction factor applied to the texture
of the triangles.
  However, as I said, I have never heard of any 3D hardware
supporting this (nor know of any software which would support it).
  Often you can avoid the problem with better modelling. For example,
in the case of tesselating a torus, you could use triangles placed
so that this effect does not present itself (ie. in a kind of
hexagonal grid on the surface of the torus). However, I'm sure there
are instances where there's no good workaround.
  (Btw, one could hastily think that dividing the quad into four
triangles could solve or at least alleviate the problem, but if you
think about how it would be textured you will realize it will not
help too much.)
