POV-Ray : Newsgroups : povray.general : Math question regarding interpolation of orientations Server Time
25 Dec 2025 20:57:10 EST (-0500)
  Math question regarding interpolation of orientations (Message 1 to 5 of 5)
Subject: Math question regarding interpolation of orientations
Date: 28 Jan 2005 15:22:07
Message: <41fa9eef@news.povray.org>
I have a question about interpolating orientations:
I have a set of timestamp/orientation pairs (the orientations are
represented as unit quaternions), and now I'd like to interpolate them
to get a smooth animation. Simple cubic interpolation works, but is not
optimal.
I've read that orientations should be interpolated using slerp
(spherical linear interpolation) - this would ensure that the
interpolated points are on the (4d) sphere are on a great circle
representing the shortest distance between the two orienations.
So far so good, but I'd need cubic interpolation... Is there something
like "spherical cubic interpolation" ?
Perhaps someone already wrote some POV-Ray macros or other code that
does what I'm looking for and would share it?
Or know a link to a paper about that topic...?
Thanks a lot!
-Sascha Ledinsky
Subject: Re: Math question regarding interpolation of orientations
Date: 28 Jan 2005 17:20:04
Message: <41faba94@news.povray.org>
Slerp is a very simple algorithm, once you've understood the basics. To
slerp-interpolate, you still use a linear parameter t, just that it is used
as a multiplier for an angle inside a sine-evaluation.
So, you could still just go ahead and interpolate t cubic instead of linear,
and there you go: cubic slerp interpolation.
The formula for the slerp is this:
q1 and q2 are two quaternions, alpha is the angle between the two,
calculated like this:
alpha = acos( s1*s2+vdot(v1,v2)) , where s1 and s2 are the real parts of the
quaternion, and v1 and v2 are the imaginary vector parts.
So q(t) = (sin((1-t)*alpha)/sin(alpha))*q1 + (sin(t*alpha)/sin(alpha))*q2
With a little googling and some math you should be able to get this working
properly.
Tim
PS: I'm planning to implement quaternions and interpolations etc myself at
some point, but am currently occupied with some exams and my hair-macros...
"Tim Nikias v2.0"
Date: 29 Jan 2005 06:17:44
Message: <41fb70d8$1@news.povray.org>
Thanks Tim!
The only thing I don't understand is "you could still just go ahead and
interpolate t cubic instead of linear"... Wouldn't I need additional 2
quaternions (that is, q0, q1, q2 and q3) to cubically interpolate
between q1 and q2 (to construct something like a catmull-rom spline)?
But well, I'll first start with implementing the slerp formula and see
how far I get with cubic interpolation. Maybe I'll be back with some
more questions :-)
Thanks again,
-Sascha
> properly.
> Regards,
> Tim
Date: 29 Jan 2005 06:45:01
Message: <41fb773d@news.povray.org>
Oh, now I understand! Well, I thought you were after an interpolation which
would start slow, and end slow, which would give a smooth impression. As
value t is just moving from 0 to 1 in a linear fashion, the resulting
quaternion would be a linearly paced interpolation of the two original
quaternions.
If you're after cubic interpolation with 4 or more control quaternions, well
then... Ehm... I can't help you much there, but I guess with a little
brainpower you should be able to dissect the cubic interpolation and just
figure or experiment where and how to use the slerp.Somehow. Like, eh, yeah!
Tim
"Tim Nikias v2.0"
Date: 29 Jan 2005 09:57:36
Message: <41fba460@news.povray.org>
Ok, I'll try some more googling and start experimenting...
Thanks anyway!
-Sascha
