POV-Ray : Newsgroups : povray.general : Creating Graphs with POV-Ray Server Time
11 May 2026 12:13:02 EDT (-0400)
  Creating Graphs with POV-Ray (Message 1 to 7 of 7)
Subject: Creating Graphs with POV-Ray
Date: 19 Jan 2005 05:36:43
Message: <41ee383b@news.povray.org>
Hi all,
I was wondering if anyone had used POV-Ray to create graphs or charts
(bar graphs and pie charts). I would like to be able to automate the
creation graph images on a webserver. I know there are lots of graphing
tools out there which provide this kind of functionality (i.e.
ploticus), but creating graphs in POV-Ray would be so much cooler!
Thanks in advance
Reuben
reu### [at] pearsecouk
Subject: Re: Creating Graphs with POV-Ray
Date: 19 Jan 2005 07:18:39
Message: <41ee501f$1@news.povray.org>
"Reuben Pearse" <reu### [at] pearsecouk> wrote in message
news:41ee383b@news.povray.org...
> Hi all,
Hmm, I once used pov for graphing a particular dataset that, for some reason
I can't remember, was impossible to graph in the way I wanted in Excel.
I'll see if I can find the code, but don't hold your breath....
Date: 19 Jan 2005 08:22:40
Message: <41ee5f20$1@news.povray.org>
>>Hi all,
That would be great...
I've got exactly the same problem. The graphs that I want I can't do in
Excel. Doing some searching around I found this link to pov-plot:
http://sthigpen.freeshell.org/pov-plot.html
But it looks rather Linux/Unix specific?
Reuben
Date: 19 Jan 2005 11:48:15
Message: <41ee8f4f$1@news.povray.org>
news:41ee5f20$1@news.povray.org...
Sorry - I've searched everywhere I can think of, but nada.
Date: 19 Jan 2005 11:50:29
Message: <41ee8fd5@news.povray.org>
Reuben Pearse schrieb:
> Hi all,
> Thanks in advance
> Reuben
Just do it?
In the end you have to adapt every plot script or program
to your needs anyway.
For the ticks one have to write a loop that places cylinders
or something similar along a longer cylinder which is the x-axis
for example. The same loop can be used to place number under the ticks
and so on.
For pie charts one must calculate the angles for the pieces
and do some intersection or difference operations, like
#declare piece1=
difference {
	cylinder {0, <0,0.1,0>}
	prism {... linear_sweep linear_spline }
	... Don't know the exact syntax right now ...
It's not that hard and making it by yourself is even cooler
than using a toolkit.
(And after doing it one knows how to handle the toolkit the right way...
Sebastian
Date: 19 Jan 2005 13:00:42
Message: <41eea04a$1@news.povray.org>
I have some POV-Ray code that reads a data file (text) created by an Access
database and then renders a cloud of points in 2D or 3D, with axis, ticks,
coordinates and a regression line (or regression plane for the 3D version).
I've produced thousands of graphs with it for my day job.
In any case it's not very difficult to code, just a little boring...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 20 Jan 2005 06:40:00
Message: <web.41ef9869b2bdf8724ccd982c0@news.povray.org>
Reuben Pearse <reu### [at] pearsecouk> wrote:
> Hi all,
> Thanks in advance
> Reuben
Try this, taken found at Dr. A. Filler's homepage :
http://www.ph-heidelberg.de/wp/filler/
#declare Font1="cyrvetic.ttf";
#declare ks5 =
   union{                          // X-Achse
     cylinder{-x*8,x*7.5,.1}
     cone{ x*8.5,0, x*7.5,.25}
     #declare Count=-8;
     #while (Count < 8)
        sphere {<Count,0,0>, .20}
        #declare Count=Count+1;
      cylinder{-y*8,y*7.5,.1}
      cone{ y*8.5,0, y*7.5,.25}
      #declare Count=-8;
      #while (Count < 8)
        sphere {<0,Count,0>, .20}
      cylinder{-z*8,z*7.5,.1}
      cone{ z*8.5,0, z*7.5,.25}
      #declare Count=-8;
      #while (Count < 8)
        sphere {<0,0,Count>, .20}
      text{ttf Font1 "x",0.1,0 scale <1.5,1.5,1.5> translate <7.9,-1.2,0>}
      text{ttf Font1 "y",0.1,0 scale <1.5,1.5,1.5> translate <-1,7.7,0>}
      text{ttf Font1 "z",0.1,0 scale <1.5,1.5,1.5> translate <-1,-0.2,7.8>}
      pigment { rgb<0.1,0.1,0.5> }
      finish { ambient 0.1 diffuse 0.4 reflection 0.2 brilliance 1 specular
0.3 roughness 0.2 }
     no_shadow
ks5
