POV-Ray : Newsgroups : povray.general : Fast way to subtract multiple spheres? Server Time
11 Jun 2026 09:57:55 EDT (-0400)
  Fast way to subtract multiple spheres? (Message 1 to 7 of 7)
Subject: Fast way to subtract multiple spheres?
Date: 12 Jan 2005 14:30:43
Message: <41e57ae3$1@news.povray.org>
Okay,
I have a box. I want to subtract hundreds of spheres from said box.
I have attempted 2 methods ...
1) CSG. Reasonable up to about 100, beyond 100, painful. Cand be
somewhat mitigated by bounding the final object, but that particular
object's render speed is unacceptably slow. And before you point me to
it... yes, I am aware of the holes tutorial. The object is transparent
and a merge does no better.
2) Isosurface. Quite simply, I'd recommend jumping off a building first.
Hundreds of f_sphere calls and calls to min() to create the union of
spheres is really too much to ask of POV-Ray. Render time is painful to
excruciating.
One thought I haven't entertained is... is there a function that will
give me random spherical areas w/o the high cost of a few thousand
function calls per sample?
Feature Request for POV4: Fix bounding on CSG :) <Applies asbestos clothing>
~Mike
Subject: Re: Fast way to subtract multiple spheres?
Date: 12 Jan 2005 14:46:18
Message: <41e57e8a@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:41e57ae3$1@news.povray.org...
> Okay,
> excruciating.
crackle-pattern with a form of <1,0,0> will give you something that looks more
or less like a bunch of randomly placed intersecting spheres.
cu!
Date: 12 Jan 2005 16:06:34
Message: <41e5915a$1@news.povray.org>
This works more or less, but is still a bit slow, though not as bad as
the other methods.
Thanks!
~Mike
Date: 12 Jan 2005 16:30:33
Message: <41e596f9@news.povray.org>
IIRC, someone had experimented and found that using a blob to subtract
dozens of spheres is *way* faster than using single spheres, even if the
threshold et al is set so that you don't actually see the difference. Might
want to try that?
"Tim Nikias v2.0"
Date: 12 Jan 2005 17:17:11
Message: <41e5a1e7@news.povray.org>
Tim Nikias nous apporta ses lumieres en ce 2005-01-12 16:30:
> want to try that?
Was about to suggest the same. Try with a thresshold of zero to get the full radius of
the
components.
Date: 13 Jan 2005 02:30:03
Message: <hMmAPEA+Mi5BFwTf@econym.demon.co.uk>
Wasn't it Mike Raiford who wrote:
>Okay,
>excruciating.
I think you may have misunderstood the isosurface page of my holes
tutorial. The idea isn't to use hundreds of isosurface functions, but to
use one isosurface that evaluates to hundreds of spheres.
Since your object is transparent, I would have suggested that you should
have first tried part 3 of the holes tutorial: Transparent Holes.
If you've got as particular problem that *really* isn't covered with my
existing holes tutorial, I'd be interested in hearing more details about
what you're trying to do and seeing your current source code.
Mike Williams
Gentleman of Leisure
Date: 13 Jan 2005 07:36:59
Message: <41e66b6b$1@news.povray.org>
>>Okay,
>>excruciating.
Ahgh.. I never saw that part of the tutorial before... pure genius. :)
That was what I was trying to accomplish in a nutshell.
~Mike
