POV-Ray : Newsgroups : povray.general : Missing something basic: Including sky_spheres Server Time
16 Aug 2025 00:04:50 EDT (-0400)
  Missing something basic: Including sky_spheres (Message 1 to 7 of 7)
Subject: Missing something basic: Including sky_spheres
Date: 8 Jan 2005 18:02:23
Message: <41e0667f$1@news.povray.org>
Folks,
Hopefully I am missing something basic here ...
The following is my .pov file:
#include "skies.inc"
S_Cloud5
Unfortunately, it doesn't render.  I get a message:
File: C:\myfile.inc  Line: 4
S_Cloud5 <----ERROR
Parse Error: Expected 'object or directive', sky_sphere identifier found
instead
Returned from renderer with error status
When I look into "skies.inc", I find a #declare of S_Cloud5 which starts
with:
#declare S_Cloud5 =
sky_sphere {
    pigment { rgb <0.258, 0.258, 0.435> }
        bozo
I had thought that the #declare created a macro that substituted my
"S_Cloud5" for all that was defined.  When I copy the S_Cloud5 body to my
.pov file ... it works.
Why can't I simply "refer" to S_Cloud5?
Neil
Subject: Re: Missing something basic: Including sky_spheres
Date: 8 Jan 2005 18:20:21
Message: <41e06ab5$1@news.povray.org>
"Neil Kolban" <kol### [at] kolbancom> wrote in message
news:41e0667f$1@news.povray.org...
> Folks,
> S_Cloud5
change to:
sky_sphere {S_Cloud5}
It's the same as declaring an object.  You still have to put
"object{MyObject}" around it.
Jeremy
www.beantoad.com
Date: 8 Jan 2005 18:51:33
Message: <41e07205$1@news.povray.org>
Thanks so much.  Naturally, that works ... but I'm afraid I am still not
sure what is going on.
I had assumed that
#declare X = Y
and then entering
X
in my scene was the same as entering
Y
I guess I am missing something more intrinsic.  Do you happen to have a
reference to a POV-Ray documentation section that describes this area?
Neil
"Jeremy M. Praay" <sla### [at] hotmailcom> wrote in message
news:41e06ab5$1@news.povray.org...
> > Folks,
> > S_Cloud5
> change to:
> Jeremy
> www.beantoad.com
Date: 8 Jan 2005 19:35:23
Message: <41e07c4b$1@news.povray.org>
It's because it's a sky_sphere, which is not the same as an object.
- Grim
Date: 9 Jan 2005 14:03:39
Message: <41e1800b$1@news.povray.org>
> I had assumed that
> #declare X = Y
> and then entering
> X
> Y
If you define a macro, you can use the macro's name, with it's
parameters) by itself.
When you #declare an object, you need an object{MyObject} construction.
When you #declare a sky_sphere, you need to use sky_sphere{MySkySphere}
Just the name of the object, sky_sphere, texture, pigment, material,...
is not enough.
Date: 9 Jan 2005 14:23:46
Message: <41e184c2$1@news.povray.org>
> If you define a macro, you can use the macro's name, with it's parameters)
> by itself.
> Just the name of the object, sky_sphere, texture, pigment, material,... is
> not enough.
> Alain
I am sorry to inform you that this is incorrect.
The following works just fine:
#declare Mice = object { sphere { 0,1 } texture { pigment { color rgb
1 } } }
#declare Cat = sphere { 0,1 texture { pigment { color rgb 1 } } translate
<5,0,5> }
camera { location <10,10,-5> look_at 0 }
light_source { <10,10,-5> color rgb 1 }
Mice
Cat
but in order for this to work:
1 } } }
<5,0,5> }
#declare Moon = sky_sphere { pigment { gradient z poly_wave 1.05 color_map {
      [0 color rgb .993]
      [1.03 color rgb 1.03] } } }
Mice
Cat
Moon
"Moon" must be written as "sky_sphere { Moon }" or an error will occur.
- Grim
Date: 10 Jan 2005 05:25:01
Message: <41e257fd$2@news.povray.org>
"GrimDude" <a36### [at] bellsouthnet> wrote in message
news:41e184c2$1@news.povray.org...
IIRC you can get away with simple object declarations w/o an object wrapper.
However, you won't be able to use the object in CSG w/o a wrapper and you
won't be able to apply a texture of other value to it.
So, if I did RC, then:
#declare Foo = sphere{0,1}
union{
    sphere{x*1,1}
    Foo
will fail
but
union{
    sphere{x*1,1}
    object{Foo}
will be okay.
And
Foo pigment{rgb 1}
is plainly wrong, but
object{Foo pigment{rgb 1}}
is fine.
