POV-Ray : Newsgroups : povray.general : POVRay says Macro is not defined Server Time
16 Apr 2026 18:15:02 EDT (-0400)
  POVRay says Macro is not defined (Message 1 to 8 of 8)
Subject: POVRay says Macro is not defined
Date: 12 Dec 2004 13:28:13
Message: <41bc8dbd$1@news.povray.org>
Hi
I have the following macros:
#macro CON_SMD_MOLEX_53261_GRND(n)
union{
     #local pin =
     union{
         box{<-0.18,-0.35,0><0.18,0.35,3.6> translate<0,1.375,0>}
         box{<-0.18,0.8,0><0.18,1.375,-0.3> }
         box{<-0.18,0.0,-0.3><0.18,1.375,-1.0> }
     //Pins
     union{
         #local i = 0;
         #while(i<n)
             object{pin translate<-(n-1)*1.25/2+i*1.25,0,0>}
             #local i = i + 1;
         texture{col_silver}
     //Plastikkoerper
     union{
         difference{
             box{<-(4.25+(n-2)*1.25)/2,0,0.01>
                 <(4.25+(n-2)*1.25)/2,3.4,4.2>}
             box{<-(3.05+(n-2)*1.25)/2,0.6,0.8>
                 <(3.05+(n-2)*1.25)/2,3.0,4.3>}
             box{<-(4.3+(n-2)*1.25)/2,2.99,3.2>
                 <(4.3+(n-2)*1.25)/2,3.41,4.3>}
             box{<-(2.5+(n-2)*1.25)/2,2.99,2.8>
                 <(2.5+(n-2)*1.25)/2,3.41,4.3>}
             #local i = 0;
             #while(i<n+2)
                 box{<-0.3,2.8,0> <0.3,3.41,0.6>
                     translate<-(n+1)*1.25/2+i*1.25,0,0>}
                 #local i = i + 1;
         texture{pigment{Gray30}}
#macro CON_SMD_MOLEX_53261_2()
object{CON_SMD_MOLEX_53261_GRND(2)}
#macro CON_SMD_MOLEX_53261_3()
object{CON_SMD_MOLEX_53261_GRND(3)}
#macro CON_SMD_MOLEX_53261_4()
object{CON_SMD_MOLEX_53261_GRND(4)}
POVRay parses the file containing this macro (and others befor and
behind it) When I call that macro POVRay says
Parse Error: Expected 'object', undeclared identifier
'CON_SMD_MOLEX_53261_4' found instead.
Any ideas?
mat### [at] matweide
http://www.matwei.de
Subject: Re: POVRay says Macro is not defined
Date: 12 Dec 2004 14:30:00
Message: <web.41bc9bda655f53448a85f6810@news.povray.org>
I had no problems running the macro as it was under POV-Ray 3.6 for Mac OS
9.x, although there were a few issues that I noticed with the general
construction.
First of all it is un-necessary to encapsulate the contents of your macro in
a union, and I found no problems in dispensing with the outer union block.
Second, It is, in my opinion, redundant to encapsulate your macro calls in
their own macros when they can be called easier by themselves and it takes
up less space doing so.
Third, it is also un-necessary to place your macro calls inside an object
block unless you are going to trasform them in some way (f.ex. translate,
rotate or scale)
Other than that I simply added some stuff so that I could view the scene.
ADB
#include "metals.inc"
 location <5.0, 4.0, -10.0>
 look_at 0
light_source { <5.0, 15.0, -20.0> rgb 1 }
#default { pigment { White } finish { ambient 0.4 diffuse 0.6 } }
#local pin =
 union{
     //Pins
 union{
         #local i = 0;
         #while(i<n)
             #local i = i + 1;
         pigment { P_Silver3 }
     //Plastikkoerper
 union{
  difference{
   box{<-(4.25+(n-2)*1.25)/2,0,0.01> <(4.25+(n-2)*1.25)/2,3.4,4.2>}
   box{<-(3.05+(n-2)*1.25)/2,0.6,0.8> <(3.05+(n-2)*1.25)/2,3.0,4.3>}
   box{<-(4.3+(n-2)*1.25)/2,2.99,3.2> <(4.3+(n-2)*1.25)/2,3.41,4.3>}
   box{<-(2.5+(n-2)*1.25)/2,2.99,2.8> <(2.5+(n-2)*1.25)/2,3.41,4.3>}
  #local i = 0;
  #while(i<n+2)
   box{<-0.3,2.8,0> <0.3,3.41,0.6> translate<-(n+1)*1.25/2+i*1.25,0,0>}
  #local i = i + 1;
Date: 12 Dec 2004 15:00:17
Message: <41bca351@news.povray.org>
> construction.
OK. But that shouldnt be the problem.
The macro is part of a much bigger system:
http://web2.callisto.twam.info/eng/index.php?page1=eagle3d
So it is necessary to do it that way.
> rotate or scale)
I do so to place the parts on the PCB.
Thats strange. I can also use the macro within a test scene (forget to
mention it) But if I call it from the main file (the macro is in a
include file which is included by a top level include file) it isn't found.
Date: 12 Dec 2004 15:08:33
Message: <41bca541$1@news.povray.org>
found.
Have you checked for the obvious problems, like mispellings of the macro
name, or failing to #include files such that the macro really is defined
before it's called?
Put #debug "\n\nMacro defined\n\n" right after the macro definition and see
if the text is displayed before the error occurs.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 12 Dec 2004 21:43:41
Message: <41bd01dd$1@news.povray.org>
An issue I have hit a few times is that the SDL interpreter seems to have
trouble with macro definitions after the first inside say a layered texture.
Something like this:
#declare A_MACRO = {...}
#declare A_LAYERED_TEXTURE = {
texture { .... A_MACRO .... }
texture { .... A_MACRO .... }   // This macro substitution is not handled
does not work and I am in the habit of coding instead:
#declare A_MACRO {...}
#declare A_LAYERED_TEXTURE_1 = {... A_MACRO ... }
#declare A_LAYERED_TEXTURE_2 = {... A_MACRO ... }
texture { A_LAYERED_TEXTURE_1 }
texture { A_LAYERED_TEXTURE_2 }
which works fine.
Date: 13 Dec 2004 04:09:56
Message: <41bd5c64$1@news.povray.org>
In article <41bd01dd$1@news.povray.org> , "William Pokorny"
This is not a macro, it is a declaration!
The limitations and pitfalls of layered texture declarations are explained
in the manual.
    Thorsten
e-mail: tho### [at] trfde
Date: 13 Dec 2004 11:30:32
Message: <41bdc3a8$1@news.povray.org>
That was the point brougt the solution. I was a bit (or more than a bit
:) stupid. The macro is defined in a file called connector.inc. That
file is in directory which is added to the POVRay library path via an
INI File. Now I had (unintentionally) a older version of this file
(without that macro) in the same directory as the POV file calling that
macro. So that (older) file was found first and used. Doh!
Thanks for your time and sorry.
Date: 13 Dec 2004 12:51:49
Message: <41bdd6b5$1@news.povray.org>
Hi Thorsten,
Indeed in my rush to aid Matthias I wrote #declare... instead of #macro....
The documentation of course says you cannot use #macro definitions in
layered textures, but like many rules in life it is in fact not a hard a
fast one. Using macros in layered textures has been a very useful way for me
to create versions of the standard POV-Ray texture include files that
support both my older assumed_gamma of 2.2 scenes and my new assumed_gamma
of 1.0 scenes.
I adopted this approach based upon a recommendation Ive made about a year
ago as a way to cope with the fact the shipped textures do not work well if
you try and use the recommended assumed_gamma  of 1...  I had been running
with an assumed_gamma of 2.2 for YEARs because it was all that seemed to
work with shipped textures.
To any who might also have been confused by this quirk of the standard
includes - get to where you ALWAYS use an assumed_gamma of 1. Adjustments to
textures are easier and simply make more sense. The resultant images have a
better fidelity that could probably be measured if I wanted to bother, but
it is obvious.
Unfortunately, the supplied textures and any others you might have created
so they look good on your non-apple system - without adjustment - and to
work with the supplied textures will need to be adapted to run with an
assumed_gamma of 1. A painful change, but well worth it.The illegal use of
macros happens to make adapting easier.
I know it is hard sometimes for you Thorsten and the other POV-Ray experts
to deal with us fools - but keep after us and eventually we'll get it!
Thanks again for catching my error.
Bill
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:41bd5c64$1@news.povray.org...
have
texture.
> in the manual.
>     Thorsten
