POV-Ray : Newsgroups : povray.general : Density help Server Time
26 Dec 2025 02:50:30 EST (-0500)
  Density help (Message 1 to 10 of 10)
Subject: Density help
Date: 17 Nov 2004 15:01:35
Message: <419bae1f@news.povray.org>
Hi!
Can anybody give me some pointers on how to create a media density like
the one you can see in http://tinyurl.com/4ddjl (the two spheres at the
right side). I tried it using a spherical warp on a scaled leopard
pattern and using actual cones, but none look good.
Thanks a lot!
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Subject: Re: Density help
Date: 17 Nov 2004 15:14:58
Message: <419bb142$1@news.povray.org>
Looks like it's the noise function sampled along the surface of a sphere:
#include "functions.inc"
// separate function used to avoid recalculating dist multiple times
#declare noisefunc = function(x,y,z,dist) {f_noise3d(x/dist,y/dist,z/dist)}
density {
function {noisefunc(x,y,z,sqrt(x*x+y*y+z*z))}
// you may want to add a color map too, or maybe not:
color_map {
[.4 rgb 0]
[.6 rgb 1]
 - Slime
 [ http://www.slimeland.com/ ]
Date: 17 Nov 2004 15:54:39
Message: <419bba8f$1@news.povray.org>
 > of a sphere:
Nice. Fast. Beautiful.
Great job! Not that I really understand it, though.
The sqrt() part is the distance to the origin.
And now you use the noise3d result of the current point, scaled with the
inverse of that distance? Could you give some more explanation on how
this works? All this function stuff is pretty new to me :)
Thanks!
Florian
Date: 17 Nov 2004 16:09:01
Message: <419bbded$1@news.povray.org>
Right.
Well, when you divide each component (x,y,z) of a vector by the size of that
vector, you get the normalized vector: that is, a vector pointing the same
direction away from the origin, but of length 1. (The exception is when you
try to do this for (0,0,0), which causes a division by zero - this makes
sense because (0,0,0) doesn't really have a direction.) So the end result is
that we're sampling the noise function on a sphere of radius 1. Another way
to think about it is that when you divide out the distance from the origin,
the distance is no longer a factor in where you're sampling the pattern:
only the direction is a factor. This causes directional rays of light which
don't vary according to distance.
If you want a busier pattern, you should change
to
f_noise3d(x/dist * scale,y/dist * scale,z/dist * scale)
where scale is the amount to make the pattern busier by. This essentially
increases the radius of the sphere that we're sampling on, so you get more
variation in the pattern.
 - Slime
Date: 17 Nov 2004 16:19:14
Message: <419bc052$1@news.povray.org>
Why not use vnormalize?
~Mike
Date: 17 Nov 2004 16:27:58
Message: <419bc25e$1@news.povray.org>
That's an SDL feature; functions don't work with vectors (to my knowledge,
with the exception of transformation functions) so you have to do vector
math manually.
 - Slime
Date: 17 Nov 2004 16:30:31
Message: <419bc2f7$1@news.povray.org>
> math manually.
Good enough reason :)
~Mike
Date: 17 Nov 2004 16:41:57
Message: <419bc5a5$1@news.povray.org>
Ah, normalizing the vector, of course! Nice idea ;)
Thanks for the explanation!
Florian
Date: 17 Nov 2004 16:56:58
Message: <419bc92a$1@news.povray.org>
> Right.
> to
I'm totally lost, but that's to be expected. Math never was or will be
my best subject.
Since Florian has it figured out now and we're on the topic of media
density, can I ask a question? For a while now I've been wondering how
one would create a plasma effect similar to this:
http://van.hep.uiuc.edu/van/demos/Plasma%20Ball/PlasmaBall-small.jpp.
How would any of you go about doing it?
~Mike
Date: 17 Nov 2004 17:04:36
Message: <419bcaf4$1@news.povray.org>
That's not an easy one. I would probably separate it into three emission
medias, one for the purple strands, one for the red things on the outside,
and one for the red thing on the inside.
For the purple things, I might start with the trick I just explained, only
with maybe the leopard pattern or crackle form<1,0,0> with some sort of
color map to get thin things extending outwards. Then I'd add some
turbulence.
The red things would use the same pattern (to ensure that there's a red
thing at the end of each purple thing), with a different color map that both
changes the color and makes them bigger. I'd combine this with a spherical
density that had a color map to make sure I only got red on the outer edges
(and not mixed in with the purple stuff).
The inner red thing could possibly be done with just a simple spherical
pattern.
 - Slime
