POV-Ray : Newsgroups : povray.general : One picture, multiple machines, using radiosity Server Time
1 Feb 2026 00:51:36 EST (-0500)
  One picture, multiple machines, using radiosity (Message 1 to 5 of 5)
Subject: One picture, multiple machines, using radiosity
Date: 19 Oct 2004 14:21:17
Message: <41755b1d@news.povray.org>
If I split a rendering between multiple computers,
and the rendering is using radiosity, should I have
one machine generate the radiosity file to be used
by all the others? Or will Pov do fine without it?
=Bob=
Subject: Re: One picture, multiple machines, using radiosity
Date: 19 Oct 2004 14:30:00
Message: <41755d28$1@news.povray.org>
You have to generate and save it before and then load the data on the
different machines. I've never tried it myself (because I've only got one
PC), but there have been numerous reports about radiosity not looking alike.
This is because POV-Ray only generates radiosity-samples in the visible
image, so when you split the image onto several machines, these gather
different samples. Gathering the data can also be done on a somewhat smaller
image IIRC.
To make sure that the machines don't gather individual additional data, use
always_sample off. It might be a good idea to slightly overlap the
distributed parts of the image though, so that you could stitch them
together in an image application if borders still don't look proper. But
that's just a wild guess, I'm just not sure if the output will be 100% the
same even when you load the data.
Tim
"Tim Nikias v2.0"
Date: 19 Oct 2004 15:39:27
Message: <41756d6f@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in message
news:41755d28$1@news.povray.org...
: > If I split a rendering between multiple computers,
: > and the rendering is using radiosity, should I have
: > one machine generate the radiosity file to be used
: > by all the others? Or will Pov do fine without it?
: You have to generate and save it before and then load the data on the
: different machines. I've never tried it myself (because I've only got one
: PC), but there have been numerous reports about radiosity not looking alike.
: This is because POV-Ray only generates radiosity-samples in the visible
: image, so when you split the image onto several machines, these gather
: different samples. Gathering the data can also be done on a somewhat smaller
: image IIRC.
Ok, I got that.
: To make sure that the machines don't gather individual additional data, use
: always_sample off. It might be a good idea to slightly overlap the
Ok, I got that too.
: distributed parts of the image though, so that you could stitch them
: together in an image application if borders still don't look proper. But
: that's just a wild guess, I'm just not sure if the output will be 100% the
: same even when you load the data.
Thanks Tim!
=Bob=
Date: 19 Oct 2004 20:40:45
Message: <4175b40d$1@news.povray.org>
For me, it's inevitable that the power will go out approximately 1 day
before completing a 20-day render.  ;-)
Anyway, someone gave me this code a while back.  I guess you can leave all
other radiosity settings the same (if not, someone can feel free to let me
know, but I don't think it matters either way):
      #if (SaveRadiosity)
        save_file "Radiosity.rad" // save radiosity data
      #if (LoadRadiosity)
        pretrace_start 1           // start pretrace at this size
        pretrace_end   1           // end pretrace at this size
        always_sample off
        load_file "Radiosity.rad" // load saved radiosity data
So, the first pass (with SaveRadiosity=on), you can render at a lower
resolution with no AA (or focal blur).  Then for the final-render
(LoadRadiosity=on, SaveRadiosity=off), you can crank-up the resolution, turn
on AA, and you'll get a faster render, without much difference in radiosity
as far as I've noticed.
Jeremy
www.beantoad.com
Date: 19 Oct 2004 21:14:59
Message: <4175bc13@news.povray.org>
"Jeremy M. Praay" <sla### [at] hotmailcom> wrote in message
news:4175b40d$1@news.povray.org...
: For me, it's inevitable that the power will go out approximately 1 day
: before completing a 20-day render.  ;-)
That's my worry now!
[rad setting deleted]
Thanks! I will try these.
=Bob=
