POV-Ray : Newsgroups : povray.general : Sphere with holes and lights shining out of it Server Time
17 Aug 2025 05:16:17 EDT (-0400)
  Sphere with holes and lights shining out of it (Message 1 to 4 of 4)
Subject: Sphere with holes and lights shining out of it
Date: 16 Oct 2004 04:35:02
Message: <4170dd36@news.povray.org>
Hi!
I am really clueless now.. I want to create a rotating sphere with the
effect seen here: http://users.pandora.be/eclypse/
I just dont get the emitting beams right. As soon as i add media the whole
scene is lit bright. Is this a CSG or media error?
Rotating is working and I cut the holes using cylinders... i would
appreciate
any hint very much how to do the light emitting from inside the sphere
right.
Thank you
Carsten
Here is what i have so far:
--------------- snip ---------------------
// Persistence of Vision Ray Tracer Scene Description File
// File: gomb.pov
// Vers: 3.5
#version 3.5;
global_settings {
  assumed_gamma 5.0
media {    // atmospheric media
  intervals 10
  scattering { 1, rgb 0.03 }
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
  location  <1.5, 0, 0>
  rotate  <90,0, 360*clock>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <10,10,10>  // light's color
  media_attenuation off
//  translate <-30, 30, -30>
difference{
sphere {
  0.0, .5
  color rgb <1, 1, 1>  // light's color
  hollow
    finish{
      specular 0.6
// Capped Cylinder, closed [or open ended]
// cylinder { <END1>, <END2>, RADIUS [open] }
//  END1 = coord of one end of cylinder
//  END2 = coord of other end
// RADIUS = size of cylinder
// open = if present, cylinder is hollow, else capped
#declare Index2 = 1;
#while(Index2 <= 10)
#declare Index = 1;
#while(Index <= 10)
cylinder {
  -1*x,  1*x,  0.03
   open
   hollow
   rotate <1,Index2*18,Index*18>
    finish{
      specular 0.6
  #declare Index = Index + 1;
  #declare Index2 = Index2 + 1;
Subject: Re: Sphere with holes and lights shining out of it
Date: 16 Oct 2004 04:59:14
Message: <4170e2e2$1@news.povray.org>
There are several things you might want to change.
1. Place the media inside a hollow container, e.g. a box or such. It can be
very difficult for POV-Ray to properly place the sampling of the intervals
when the rays aren't stopped at an object somewhere.
2. Also note that scattering media also absorbs light, so objects further
away will be less visible. With Point 1 this is the reason why the
background shows white, using a simple box (hollow and with pigment{rgbt 1}
to make the surface invisible) solves that.
3. Why do you set assumed_gamma to 5.0?! A normal screen has 2.2 or so, and
the Docs advise to use 1.0.
That should get you started.
Tim
"Tim Nikias v2.0"
Date: 16 Oct 2004 09:49:24
Message: <417126e4@news.povray.org>
What do you think of this?
Regards
// File: gomb.pov
// Vers: 3.5
#version 3.5;
global_settings {
  assumed_gamma 1.0
  direction 1.0*z  // So we can see the whole sphere.
light_source {
difference{
  sphere {
    0.0, .5
    hollow
    #declare Index = 1;
    #while(Index <= 10)
      cylinder {
        -1*x,  1*x,  0.015 // So not only the beams are thinner but they
spread less.
         //open  // There's no point in removing a cylinder's caps
                      // if you're subtracting it from another shape!
         hollow
  texture {  // When all the objects inside a CSG block have the same
texture, attaching it
               // to the whole CSG is faster and simpler.
    pigment{rgb 0} // Does nothing, but avoids a warning.
    finish{
      specular 0.6
sphere {  // We constrain the media within a concentric sphere.
  0, .65
  hollow
  pigment {rgbt 1}
  interior {
    media {
      intervals 10
      scattering { 1, rgb 1 }
      samples 1, 10
      confidence 0.9999
      variance 1/1000
      ratio 0.9
      density { onion frequency -1 scale 0.65 }  // To get a smooth
transition into darkness
                                                   // at the end of each
light beam.
Date: 16 Oct 2004 15:34:48
Message: <417177d8$1@news.povray.org>
Great!
Thank you very much for the help to both of you!
Carsten
"Frango com Nata" <odo### [at] yahoocombr> schrieb im Newsbeitrag
news:417126e4@news.povray.org...
> Regards
> // File: gomb.pov
> // Vers: 3.5
> #version 3.5;
> global_settings {
>   assumed_gamma 1.0
> camera {
> light_source {
> difference{
>   sphere {
>     0.0, .5
>     hollow
>     #declare Index = 1;
>     #while(Index <= 10)
>       cylinder {
> spread less.
>          hollow
>     #end
>   #end
>     finish{
>       specular 0.6
>   0, .65
>   hollow
>   pigment {rgbt 1}
>   interior {
>     media {
>       intervals 10
>       samples 1, 10
>       confidence 0.9999
>       variance 1/1000
>       ratio 0.9
> light beam.
