POV-Ray : Newsgroups : povray.general : memory question Server Time
1 Mar 2026 19:05:40 EST (-0500)
  memory question (Message 1 to 5 of 5)
Subject: memory question
Date: 27 Aug 2004 22:21:17
Message: <412fec1d@news.povray.org>
I'm working on a macro, and I get the idea that:
#declare SphereA = sphere{<0,0,0>,5 pigment{Green}}
#declare Count = 0;
union{
  #while (Count<5)
   object{SphereA translate x*2*Count}
   #declare Count = Count + 1;
uses a lot more memory then:
union{
  sphere{<0,0,0>,5 pigment{Green} translate x*2}
  sphere{<0,0,0>,5 pigment{Green} translate x*4}
  sphere{<0,0,0>,5 pigment{Green} translate x*6}
  sphere{<0,0,0>,5 pigment{Green} translate x*8}
  sphere{<0,0,0>,5 pigment{Green} translate x*10}
Can somebody tell me this is true? I find this strange for some reason.
Subject: Re: memory question
Date: 28 Aug 2004 08:47:44
Message: <41307ef0@news.povray.org>
I found exaltly the same memory usage.
ZeSly
http://perso.wanadoo.fr/zesly/
news:412fec1d@news.povray.org...
> #declare Count = 0;
> union{
>   #while (Count<5)
>   #end
> union{
Date: 28 Aug 2004 12:06:26
Message: <4130ad82$1@news.povray.org>
> #declare Count = 0;
> union{
>  #while (Count<5)
>  #end
> union{
The spheres in the union all use the same texture.  The separately-
declared spheres all use separate textures (since you gave them
separate ones).
So, if you're going to texture a bunch of things the same way, see if
they can go into a union together, and give the union the texture.  This
works very well if the texture is not patterened.
John
Date: 28 Aug 2004 15:07:54
Message: <4130d80a@news.povray.org>
Thanks, but that was not the point I am trying to make. But to clear
things up I refrase the question;
#declare SphereA = sphere{<0,0,0>,5}
#declare Count = 0;
union{
  #while (Count<5)
  pigment{Green}
union{
  sphere{<0,0,0>,5 translate x*2}
  sphere{<0,0,0>,5 translate x*4}
  sphere{<0,0,0>,5 translate x*6}
  sphere{<0,0,0>,5 translate x*8}
  sphere{<0,0,0>,5 translate x*10}
  pigment{Green}
I solve this problem by writing it to a .inc file with the #write
function. I just didn't expect a big difference in memory usage with the
two methods.
>> #declare Count = 0;
>> union{
>>  #while (Count<5)
>>  #end
>> union{
> separate ones).
> Regards,
> John
Date: 6 Sep 2004 13:52:35
Message: <413ca3e3$1@news.povray.org>
emkaah nous apporta ses lumieres ainsi en ce 28-08-2004 15:07... :
> #declare Count = 0;
> union{
>  #while (Count<5)
>  #end
>  pigment{Green}
> union{
>  pigment{Green}
> the two methods.
They should use about the same amount of memory. Case 1 use a little
memory for the variable, case 2 use some more memory for the source. If
you increase the count to 500, then case 2 will use more memory: the 500
individualy defined spheres source code. The alocated memory during
parse will be the same, to one variable.
