![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But then you've missed the thrust of my argument - users that realize the
need to upgrade their libraries and rebuild povray won't have the same
problems as those that link against the libraries included with 3.6.
Therefore, users of the (now old) libraries will start submitting bug
reports - which goes back to your originally stated problem.
Again, its nit picking, but IMHO worth consideration.
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.40fed6aea404e2e24e6ed3100@news.povray.org> , "Tim F"
No, that argument is nonsensical. The decision stands, and no matter how
much you or anybody else complain about it, it will *****not***** change.
If you or anybody else does not like that - we absolutely do not care.
Period!
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Then you haven't read it carefully enough. Whats to say the libraries
packaged with 3.6 are bug free and will not lead to non-povray related
error reports in the future?
Irrelevant - we're discussing the reasons for the decision - not an
imperative to change it.
Neither do I, since "liking it" was never any part of my post. Again, I'm
just trying to understand the decision, not challenge it.
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.40fefb25a404e2e24e6ed3100@news.povray.org> , "Tim F"
I already told you. You did apparently not understand also I was very
elaborate. I suggest you just accept it as given if you do not understand
the original answer to your original question in this regard.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You think POV-Ray's building system will always use the bundled libraries
regardless of what's installed in the system?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No - dynamic linking should handle this problem (correct me if I'm wrong).
However, the prepackaged binary is statically linked:
$ file /usr/local/bin/povray
/usr/local/bin/povray: ELF 32-bit LSB executable, Intel 80386, version 1
(SYSV), for GNU/Linux 2.2.0, statically linked, stripped
seems like it would only use the bundled libraries here, neh?
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.40ff8861a404e2e2300017f40@news.povray.org> , "Tim F"
As was already pointed out, users with outdated image support libray
versions would report problems in POV-Ray that were actually due to them
using outdated image support libray versions.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Dynamic linking is used for pre-installed libraries which versions
are at least (or above) that of the libraries provided with POV-Ray. For
instance, if you have an hypothetical libpng-1.3.1 while POV-Ray requires
at least libpng-1.2.5, the POV-Ray binary will be linked with your shared
library libpng-1.3.1. Otherwise POV-Ray will configure and build the
libpng-1.2.5 sources provided in the package, and statically link with it.
The console output of configure is quite clear about this.
That should not be the case with the binary you obtained on your
FC2 distro since you said zlib didn't have to build there. Therefore
at least this library (as well as probably libpng and libjpeg) should be
dynamically linked with the povray binary. Maybe only libtiff will be
linked statically (assuming FC2 does not ship with the most recent
version of libtiff).
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
BTW, having a fully-static binary for the official PC-Linux release
is the only way to go. We cannot afford tons of "bug" reports from people
unable to run a binary that requires shared libraries they don't necessarily
have on their system. The advantage of a fully-static binary is much higher
than the potential situation you describe (which can be resolved by installing
instead the POV-Ray source package and the updated 3rd-party libraries).
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
<snip>
I don't think I'm relaying my point properly. None of this has *anything*
to do with what I was trying to suggest. As an example, lets say I have
the prepackaged binary, which is statically linked against libpng-1.2.5 (I
think). But lets say there is a bug in libpng-1.2.5 that in certain
instances causes a memory overflow or (even less likely) a corrupted image.
libpng-1.2.6beta has a fix for this bug, but all users of the prepackaged
povray now have a borked binary.
My point is, end users may then submit bug reports for what is not a povray
related problem. Thus, the problem that you and Thorsten rightly bring up
(and I fully agree with) has now been effectively reversed.
Again, I realize its splitting hairs and most likely won't be a problem of
any consequence, and I'm sure has already been considered to be of
negligible risk.
Sorry for causing such a stir.
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
