POV-Ray : Newsgroups : povray.general : possible 3.6 bug when animating meshes and large unions Server Time
11 Sep 2025 19:26:06 EDT (-0400)
  possible 3.6 bug when animating meshes and large unions (Message 1 to 5 of 5)
Subject: possible 3.6 bug when animating meshes and large unions
Date: 20 Jul 2004 14:56:19
Message: <40fd6ad3$1@news.povray.org>
POV-Ray 3.6 on Win98 machine 650M processor with 256M Ram.
With the union included in case(1), both frames render as expected. With
the union commented out in case(1) (as shown here), the first frame
renders as expected, but the second renders *very* slowly.
// -F +KFI1 +KFF2
#declare VL = array[04] {
     <-0.577350,-0.577350,00.577350>, <-0.577350,00.577350,-0.577350>,
     <00.577350,-0.577350,-0.577350>, <00.577350,00.577350,00.577350>
#local TestMesh = mesh {
     triangle { VL[00], VL[01], VL[03] }
     triangle { VL[00], VL[02], VL[01] }
     triangle { VL[00], VL[03], VL[02] }
     triangle { VL[01], VL[02], VL[03] }
     translate z*10
#local TestLargeUnion = union {
     #local c0 = 0; #while ( c0 < 100 )
         cylinder { VL[0], VL[1]+<0,0,c0>, .003 }
         cylinder { VL[0], VL[2]+<0,0,c0>, .003 }
         cylinder { VL[0], VL[3]+<0,0,c0>, .003 }
         cylinder { VL[1], VL[2]+<0,0,c0>, .003 }
         cylinder { VL[2], VL[3]+<0,0,c0>, .003 }
         cylinder { VL[3], VL[1]+<0,0,c0>, .003 }
     #local c0 = c0 + 1; #end
     translate z*10
#switch ( frame_number )
     #case ( 1 )
         object { TestMesh }
         //object { TestLargeUnion }
         background { rgb <1,0,0> }
     #break
     #case ( 2 )
         object { TestMesh }
         background { rgb <0,1,0> }
     #break
Subject: Re: possible 3.6 bug when animating meshes and large unions
Date: 21 Jul 2004 09:32:20
Message: <40fe7064$1@news.povray.org>
Confirmed on 1200M processor with 384M Ram running Slackware Linux.
  -Shay
Date: 21 Jul 2004 13:04:56
Message: <40fea238@news.povray.org>
news:40fe7064$1@news.povray.org...
Confirmed on a P3/NT4 machine with 640 M Ram.
Here's a simpler scene. It's the number of elements in the first frame that
causes the trouble in the following frames. 3 spheres in the first frame =
OK ; 2 spheres or less = not OK.
Definitely worth a bug report.
camera{location -z*100}
#if (frame_number=1)
    sphere{0,1 pigment{rgb x} finish{ambient 1}}
    sphere{0,1 translate y*2 pigment{rgb x} finish{ambient 1}}
    sphere{0,1 translate y*4 pigment{rgb x} finish{ambient 1}}
 #else
    #declare i=0;
    #while (i<1000)
        sphere{0,1 translate y*i*2 pigment{rgb y} finish{ambient 1}}
        #declare i=i+1;
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 21 Jul 2004 14:22:28
Message: <40feb464@news.povray.org>
> in the first frame that causes the trouble in the
I think it's a feature, though IMO not a very clever one.
The number of objects in a scene determines if Auto Bounding is turned on.
However, it is the number of objects in the *first* frame that determines if
Auto Bounding *for the entire animation* is turned on or off.
To work around the problem, make sure that Auto Bounding is simply always
turned on by putting this in your master povray.ini file:
Bounding_Threshold = 0
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 21 Jul 2004 14:43:51
Message: <40feb967@news.povray.org>
Rune wrote:
Thanks, Gilles and Rune, for getting to the bottom of this.
Bounding_Threshold = 0 works.
  -Shay
