POV-Ray : Newsgroups : povray.general : isosurface on a declared object Server Time
15 Jan 2026 15:39:09 EST (-0500)
  isosurface on a declared object (Message 1 to 7 of 7)
Subject: isosurface on a declared object
Date: 28 Jun 2004 02:01:54
Message: <40dfb452$1@news.povray.org>
Im am still a novice with povray, which means i dont understand a lot
about povray. How do i go about creating a rough surface (for example
the randomness/roughness of the surface of a rock). From what i have
read so far I can use an isosurface to achieve this, or is there
something else that will work better.
If isosurface is the way to go how can i apply it to a object that i
have declared / created?
Regards
Martin.
Subject: Re: isosurface on a declared object
Date: 28 Jun 2004 02:21:19
Message: <40dfb8df@news.povray.org>
Try this
Mick
"Marty" <1@1.1> wrote in message news:40dfb452$1@news.povray.org...
> Regards
> Martin.
Download 'Rock tezst.pov.txt' (3 KB)
Date: 28 Jun 2004 04:17:42
Message: <40dfd426@news.povray.org>
The question is, do you need something which is truly rough, or can you
settle for something which only *looks* rough?
If you only need a small amount of roughness, you can make an otherwise
smooth surface *appear* rough by adding a normal{} to it. This has the
advantage of keeping the modelling simple while still making an object that
looks detailed. It has the disadvantage that the object's shadow is still
smooth, and the fake bumps don't really protrude from the object. But
sometimes it's good enough, and it's definitely easier for a beginner.
If this will work for you, then you should look up "normal" in the
documentation, or look for it in the tutorial in the documentation's
contents.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 28 Jun 2004 07:55:44
Message: <40e00740@news.povray.org>
Thanks for the point in an easier direction, but what i am after is a
very tight rough surface, the kind that you normally get with sand stone
or granite.
Thanks
Martin.
> contents.
>  - Slime
Date: 29 Jun 2004 03:01:16
Message: <40e113bc$1@news.povray.org>
"Marty" <1@1.1> wrote in message news:40e00740@news.povray.org...
> or granite.
Hey Marty (Martin), I replied to you in p.n. and since then have looked for
some info about predeclared objects in isosurfaces. Mike Williams'
Isosurface Tutorial helps explain a bit about that:
http://www.econym.demon.co.uk/isotut/dont.htm
For easy roughness texturing... and I do mean easiest... the 'crand'
keyword, used in a finish statement, can add a sandpaper effect all by
itself. A value of 1 is really extreme, with 0.1 being mild. Tends to be
unusable in animations, it's so random.
Like was already mentioned, just a normal statement -- as in normal {
granite 1 scale 0.1 } -- can do okay if you don't need the object surfaces
actually changed from their usual smooth, textureless form. You'll need the
depth value and scale to suit your object though.
Bob H.
http://www.3digitaleyes.com
Date: 29 Jun 2004 20:00:19
Message: <40e20293$1@news.povray.org>
Thanks for the tips I managed to get the effect of what i wanted by using:
   texture { T_Gold_2A normal { granite 0.1 scale 0 } }
   finish { reflection 1 phong 0.1 }
Regards
Martin.
>>or granite.
Date: 29 Jun 2004 22:42:42
Message: <40e228a2@news.povray.org>
> scale 0
"scale 0" means "make this infinitely small." Since this isn't really
possible, POV-Ray is ignoring it. It is probably also giving you warnings
like "Illegal value: Scale X by 0.0. Changed to 1.0." In effect, you could
remove the "scale 0" and it should have no effect on your scene.
 - Slime
