POV-Ray : Newsgroups : povray.general : SDL Access to Already Declared Objects? Server Time
4 Oct 2024 06:30:25 EDT (-0400)
  SDL Access to Already Declared Objects? (Message 1 to 10 of 12)
Subject: SDL Access to Already Declared Objects?
Date: 22 Mar 2004 13:02:39
Message: <405f2a3f$1@news.povray.org>
How difficult would it be to allow SDL access to predeclared objects?  Ie,
you'd use something like this:
#declare obj = firstObject;
// obj is now a reference to the first declared object
#declare loc = obj.location;
#declare pig = obj.texture.pigment;
#declare med = obj.interior.media;
#declare shine = obj.texture.finish.specular;
// The above would be access to the referenced variables.
#declare obj = nextObject;
// And continue with the rest
I'm not interested in changing the objects already declared, just in getting
information about them.  I don't see that there would be any technical
difficulties, and it would be hugely advantageous for particle simulations,
among other things.
Any thoughts?
...Chambers
http://www.geocities.com/bdchambers79
Subject: Re: SDL Access to Already Declared Objects?
Date: 22 Mar 2004 13:08:36
Message: <uqau509fp9s1aq67kkr6buhg3amup6lc0h@4ax.com>
Not difficoult at all if you encapsulate input data and object in one
structure and operate on it.
http://news.povray.org/povray.advanced-users/thread/%3C6lpkut0vdh0h6gljr7u2v4mip6olddkmel%404ax.com%3E/
ABX
Date: 22 Mar 2004 14:38:09
Message: <405f40a1$1@news.povray.org>
In article <405f2a3f$1@news.povray.org> , "Chambers"
Using the syntax you suggest, or any snytax for that matter: Impossible for
a practical implementation.  It would require duplicating most of the parser
code, and even then not every keyword is actually stored, so you could still
not access everything.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Mar 2004 14:55:50
Message: <405f44c6$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:uqau509fp9s1aq67kkr6buhg3amup6lc0h@4ax.com...
Hmm, I've used a similar method, but this again requires that you declare
your objects in #declare 's and then operate on those.
Say we have the following:
sphere {0,1 pigment {color red 1} }
#declare struct=array[3];
#declare struct[0]=sphere{y*2,1 pigment {color blue 1} }
#declare struct[1]=finish {reflection 1};
#declare struct[2]=sphere{x*2,1 pigment {color green 1} }
(I know it's a crude example, but let's keep things simple :)
OK, now in the struct we have two spheres and a finish because we declared
them.  Fine, we can access those.  For the purposes of the example, let's
say I'm doing collision detection (though this would be useful for much more
than that).  I can check against the blue and green spheres as parts of the
struct.  However, how can I check for collision against the red sphere?  In
fact, how do I know there aren't other objects in the scene that aren't part
of the struct?  I'd like a method for POV-Ray to let me *see* them (but not
necessarily change them) and their internal data.
...Chambers
Date: 23 Mar 2004 07:43:50
Message: <cjameshuff-6795B5.07440523032004@news.povray.org>
In article <405f2a3f$1@news.povray.org>,
obj has a location? What's the location of an infinite plane? Or a julia
fractal?
Which media? You can have more than one.
And which texture? What if the object has layered textures?
> among other things.
It would require writing a lot of special code for each object type, and
as already mentioned, the specified object parameters may no longer
exist in the same form, and some things can exist in multiple forms. You
could parse objects into an intermediate structure to avoid that
problem, and make it a structure of the script language to allow both
reading as in your examples and modification. This would be the best
way, but would be a large amount of work. It would be useful in other
ways though, if one were able to define custom structures. It wouldn't
need to be a full fledged object oriented system, but that would really
help.
http://tag.povray.org/
Date: 23 Mar 2004 16:22:07
Message: <4060aa7f@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-6795B5.07440523032004@news.povray.org...
Ie,
> fractal?
The location of all objects is <0,0,0> until acted on by translations /
rotations.  The final location is the sum of these transformations.
True.  Multiple textures / medias aren't something I tend to go for,
though - I prefer a nice ordered hierarchy.  Of course, that doesn't mean it
isn't possible, and any solution would need to account for that.
getting
simulations,
> > among other things.
But don't all objects share certain parameters, such as texture, location,
etc?
> help.
Structures would be useful in and of themselves, but that's another topic.
...Chambers
Date: 24 Mar 2004 16:20:00
Message: <4061fb80@news.povray.org>
sphere { y*10,1 } is located at the origin? Well Real Life (tm) is not
logical, either, so why not :)
About your particle system: You have to keep in mind that there may be
objects in the scene which have nothing to do with your system. To
seperate them from the ones your system interacts with you need a flag
for each object... Not really a nice and clean solution.
Normally I use something like this in such cases:
#declare System_Environment = object { SomeObject }
Or use an array of such environments if you want to give each
environment specific properties (in a particle system, that might be
things like friction, damping, etc.).
This method has another advantage: The objects your system works with
don't have to be part of the scene. That might sound strange, but
sometimes it's a handy thing to have.
Don't get me wrong, I'd love to see a syntax like the one you described
(and I'd like write-access, too *g*). But in most cases you can use a
pretty clean workaround.
HTH,
Florian
Date: 24 Mar 2004 16:47:52
Message: <40620208$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:4061fb80@news.povray.org...
Well, OK, that would start located at <0,10,0> - but that's because you
define the center of it there!
I'm not writing one.  That was just one example of what it would be useful
for.
Well, write access might be nice, but I thought asking for less would
increase the probability of implementation :)
OK, so even if we don't do the whole POV syntax, would it be possible just
to get object positions like this?
...Chambers
Date: 24 Mar 2004 18:28:01
Message: <40621981$1@news.povray.org>
"Chambers" <bdc### [at] yahoocom> wrote in message
news:40620208$1@news.povray.org...
OK, I figured it out by looking at objects other than spheres.  Sorry 'bout
that, everyone.
...Chambers
Date: 25 Mar 2004 08:41:26
Message: <cjameshuff-66A24A.08414525032004@news.povray.org>
In article <40620208$1@news.povray.org>,
What about cone {y*2, 0, y*5, 2}? Where's its center? y*3.5? y*4? It
certainly isn't < 0, 0, 0>.
Or for a more extreme example:
union {
    sphere {-x*5, 5}
    cylinder {-x*1, x*10, 0.05}
There's obviously far more of the object on the -x side than on the +x
side, but it extends an equal distance in both directions. Center of
mass/volume? Center of extents?
No, because there is no single vector that can represent the position of
an arbitrary object. You couldn't even get the transformations without
some additional work, because some objects apply the transformations at
parse time. For example, translating a sphere will move the center point
instead of adding a transformation matrix which would have to be
evaluated during tracing.
