POV-Ray : Newsgroups : povray.general : splitting-up large renders Server Time
12 Sep 2025 22:29:49 EDT (-0400)
  splitting-up large renders (Message 1 to 4 of 4)
Subject: splitting-up large renders
Date: 25 Nov 2003 17:23:58
Message: <3fc3d67e@news.povray.org>
Recently, I tried running several instances of a very large render on
several different computers.  Where the images were spliced together, I was
left with lines in the shadowed areas.
I'm guessing that this has to do with different Radiosity calculations being
done on the different computers.  This must be a common problem, but I
didn't see anything in the documentation about it.
Is there a way around this?
Jeremy
Subject: Re: splitting-up large renders
Date: 25 Nov 2003 22:50:50
Message: <3FC4231E.74E4B59@pacbell.net>
Don't use radiosity.
Ken Tyler
Date: 26 Nov 2003 03:46:46
Message: <aop8svg88fo6kpqeotvqil7li64dq1boqb@4ax.com>
On Tue, 25 Nov 2003 17:23:58 -0500, "Jeremy M. Praay"
I think the docs mention it but maybe not the workaround.
The problem is that the radiosity cache (octree) is different on the
different machines because they render different sections of the
image. Hence the different lighting.
Yes. Have all the machines share the same radiosity data. This is
accomplished in two passes. In the first pass, for which you should
use the fastest machine you have, render the whole image (maybe in a
lower resolution and without antialiasing) and use always_sample on
and save_file. In the second pass, which you split across different
machines, use pretrace_start 1.0 pretrace_end 1.0 always_sample off
and load_file. This will load the same radiosity data on all nodes and
will minimize the amount of new samples they take, so you should end
up with properly lineable image slices.
Peter Popov ICQ : 15002700
Date: 26 Nov 2003 09:38:06
Message: <3fc4bace@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:aop8svg88fo6kpqeotvqil7li64dq1boqb@4ax.com...
Thanks!  I'll try that when I get a chance.
The effect wasn't very noticeable (luckily), since it was a
daylight+radiosity scene, but it was something that I noticed and I was a
bit disheartened, having spent 2 weeks running various pieces of the scene
on 3 different machines.
Jeremy
