POV-Ray : Newsgroups : povray.general : Beta test version of the new mesh compressor program Server Time
22 May 2026 19:56:43 EDT (-0400)
  Beta test version of the new mesh compressor program (Message 1 to 10 of 29)
Subject: Beta test version of the new mesh compressor program
Date: 20 Nov 2003 18:37:50
Message: <3fbd504e@news.povray.org>
Finally, after so many years of laziness, I decided to enhance the
mesh compressor program to the POV-Ray 3.5 era. That is, it should
now have full support for mesh2's (reading and writing), as well
as uv-mapping in regular meshes.
  Chris Colefax is still working on the PCM macros and they are not
yet available, so you will only be able to test pov-pov and pov-pcm-pov
conversion. However, I think that most bugs should be possible to find
this way.
  Only Windows-version of the beta, sorry.
  (Oh dear, I would have never thought I would ever say something like
that, but... I'm not quite willing to publish the source before all the
most obvious bugs are fixed... Rest assured, however, that the
command-line version is extremely system-independent. :) )
  You can download the Windows beta version here:
http://www.cs.tut.fi/~warp/WinMeshcomp30_beta.zip
  (In case you don't have the slightest idea what this is all about, see
http://www.geocities.com/ccolefax/pcm.html )
Subject: Re: Beta test version of the new mesh compressor program
Date: 20 Nov 2003 19:12:57
Message: <3fbd5889$1@news.povray.org>
Yee hah!  Very cool indeed.
Date: 21 Nov 2003 06:11:02
Message: <3fbdf2c6@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3fbd504e@news.povray.org...
Excuses, excuses...
http://tinyurl.com/vykx
Date: 21 Nov 2003 06:45:04
Message: <plurrvcfv65fsitbdjhjhmasvrj17ihts5@4ax.com>
On Fri, 21 Nov 2003 11:11:01 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
LOL
Regards
Date: 21 Nov 2003 17:23:46
Message: <3fbe9072@news.povray.org>
> Excuses, excuses...
Oh my goodness... that's hilarious. I want one.
Jonathan.
Date: 6 Dec 2003 08:37:20
Message: <3fd1db90@news.povray.org>
Apparently the program is either completely bugless, or doesn't really
interest anyone...
  I hope it's the former. ;)
Date: 6 Dec 2003 09:29:17
Message: <3fd1e7bd$1@news.povray.org>
> interest anyone...
It worked nicely as far as I was able to make use of it.  Unfortunately
I think I need to have the color carry through for my application
(hair).  So, so far I am just using the plain mesh.  But the mesh2 would
give me more memory to work with so the jury is still out on which way I
will comprimise as I increase the number of triangles.
I don't suppose .obj to pcm would be possible?
The thing is that Greg Johnson wrote some interesting macros adapting
the pcm hair macros to give Maya options that might be interesting to
try.  But any modelling I do is exported in .obj among others.
Crossroads works just fine for this so it's hardly a big deal, but it
would shorten the workflow.
-Jim
Date: 6 Dec 2003 18:19:47
Message: <3fd26413@news.povray.org>
  Currently you will need to convert the .obj file to a mesh or mesh2
with some converter and then convert it to pcm with my program.
  I don't have the slightest idea what kind of format .obj is, but if
it's simple enough, I might add support for it...
Date: 6 Dec 2003 19:03:36
Message: <3fd26e58$1@news.povray.org>
I don't think so, you don't read Mesh2 just Mesh.  That is why the need
for Crossroads.  It can read .obj and output Mesh.
I think it is originally a Alias/Wavefront format. I actually wondered
if Mesh2 was modelled after .obj in part.  The prob with .obj is that it
comes in a couple of flavors I think.  Something about different line
endings, newline or carriage return.  Since I first tried mesh modelling
in a Maya course it was the format I got used to and have confidence in.
  But it is really a matter of which button to push. Personally I like
to produce mesh models with Wings3D which exports in a number of formats.
Anyway, as I said there is a way to manage the situation.  Support for
.obj or other commom mesh format would give your app more of a
one-stop-shopping place in the workflow.  But the reward would have to
come from the doing I expect.
Btw my present endeavor is trying to apply hair to a mesh such that the
direction it lies in can be controlled more closely.  Have you ever
applied youself to that problem?
Date: 6 Dec 2003 19:23:57
Message: <cjameshuff-4B28D6.19233606122003@netplex.aussie.org>
In article <3fd26413@news.povray.org>, Warp <war### [at] tagpovrayorg>
http://astronomy.swin.edu.au/~pbourke/geomformats/obj/
(more formats at http://astronomy.swin.edu.au/~pbourke/geomformats/)
http://pipin.tmd.ns.ac.yu/extra/fileformat/3d/index.htm
http://tag.povray.org/
