POV-Ray : Newsgroups : povray.general : Flux Server Time
31 Mar 2026 06:27:00 EDT (-0400)
  Flux (Message 1 to 9 of 9)
Subject: Flux
Date: 29 Oct 2003 20:10:28
Message: <3fa06504$1@news.povray.org>
Hello,
I want to use a pattern defined by a function. I know that it is possible to
access the coordinates from inside the function, however is it possible to
access the normal vector to the object ?
Thanks,
Yann
Subject: Re: Flux
Date: 29 Oct 2003 20:27:22
Message: <3fa068f9@news.povray.org>
Yann <[antispam]rollin***@mit..edu))> wrote:
> is it possible to access the normal vector to the object ?
  No.
  (You might want to search for the povman patch which might have this
property.)
Subject: Re: Flux
Date: 29 Oct 2003 21:09:47
Message: <3fa072eb@news.povray.org>
All right...
more specificaly, I would like to encode the flux of a certain vector field
V by a color along a surface. Are you telling me that there is no simple way
to do that with POVRAY?
There is the pattern slope which does almost what I want, except that it
returns a value which doesn't depend on the length of V (only on the angle).
Could I modify afterward the color returned by the slope pattern, according
to the length of V?
As you see, I am quite reluctant to learn how to use povman patch.
Yann
news:3fa068f9@news.povray.org...
>   No.
> property.)
M()}}
Warp -
Subject: Re: Flux
Date: 29 Oct 2003 22:30:06
Message: <cjameshuff-2555CC.22280729102003@netplex.aussie.org>
In article <3fa06504$1@news.povray.org>,
Very unfortunately, this is not possible. Of course, if you know the
object the pattern is being applied to, you can compute the normal given
the point being evaluated, but this is only practical in very limited
and simple cases.
http://tag.povray.org/
Subject: Re: Flux
Date: 29 Oct 2003 22:38:52
Message: <cjameshuff-85E877.22365429102003@netplex.aussie.org>
In article <3fa072eb@news.povray.org>,
An interesting idea...but there is no simple way to do this in the
general case. You could do it for meshes easily enough, just do it
per-vertex.
> to the length of V?
Slope returns a floating point scalar, not a color. And you can't alter
the slope vector with a function. And the slope pattern itself will not
work in a function, it needs to be applied to a surface. So you probably
can't do what you want...
It is probably the simplest and best way of doing what you want. You
could of course patch in normal parameters to function patterns, or just
patch in your flux pattern/pigment directly. (An interesting idea for a
pattern: use the angle between the surface normal and the gradient of a
function.)
Subject: Re: Flux
Date: 30 Oct 2003 03:45:58
Message: <vij1qvo0ofajcg35f7i1fgrre7o9o303tt@4ax.com>
On Wed, 29 Oct 2003 21:09:45 -0500, "Yann" <[antispam]rollin***@mit..edu))>
wrote:
> All right...
Yes and no. Patterns are not only related to the objects. They can exist in
medias, sky, expressions. But for many objects you could try to write
functions which return normal components for given coordinates , though only
for some subset of primitives. What object type you are looking for ?
ABX
Subject: Re: Flux
Date: 30 Oct 2003 04:02:02
Message: <tg0771-l22.ln1@triton.imagico.de>
Yann wrote:
> All right...
If you have the vector field defined as a function in POV (as a set of
df3 files for example) it is fairly easy to calculate other properties
of that field.  You can find some examples for this in the
sample scene 'incdemo/func_gradient.pov'.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Subject: Re: Flux
Date: 30 Oct 2003 20:07:35
Message: <3fa1b5d7$1@news.povray.org>
Thanks again for your advice. Of course if the object is simple enough,
it is easy to deduce what's the normal from the knowledge of its position.
However I wanted to deal with more complicated objects like animated blobs
or other  primitives with a normal perturbed by a wild normal noise.
I could as well construct all my object as big mesh and calculate the color
of each triangle using a little C program but it's a bit painfull, and
sillly since povray spends its time (I guess) to acces normal vector in
order to render the pictures.
So I am trying to install Povman now. I managed to install megapov --- easy!
But I don't manage to install Povman on the top, it isn't well documented
and I am not a linux guru... any help?
Thanks,
Yann
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
possible to
to
> and simple cases.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Subject: Re: Flux
Date: 31 Oct 2003 13:55:29
Message: <3fa2b021$1@news.povray.org>
Linux guru? But by your message header it seems that you use Windows? If
you are using Windows, then readme file contains overview, what you
should do. Basically you should copy executables into same directory,
where POV-Ray (or MegaPOV) executables are and add this directory to
path environment variable in order to access shading language compiler
easily.
If you are using Linux then it requires more work. Unfortunately I don't
have access to Linux machine right now and latest version of POVMan is
not tested with Linux, so this may require more work before you can
achieve results. Easiest way would be to create copy of MegaPov source
in different directory, copy POVMan files (from diff source code
package) over MegaPOV source files, add additional files in patches
directory to makefile and make it. POVSLC files will go to separate
directory and you should modify makefile in order to be able to make it
with Linux tools (if you really need, then I can dig out old makefile
for Linux from previous version).
If you need further assistance, then feel free to mail me.
