POV-Ray : Newsgroups : povray.general : convert isosurfaces to mesh Server Time
4 Oct 2024 20:26:24 EDT (-0400)
  convert isosurfaces to mesh (Message 1 to 10 of 13)
Subject: convert isosurfaces to mesh
Date: 9 Sep 2003 13:44:02
Message: <3f5e1162$1@news.povray.org>
I've been looking around and couldn't find any tool to 'convert' an
isosurface to a mesh. Does anyone have this kind of tool (preferably
povray script) handy ? Otherwise I'll have to write it myself, but I
suspect it will take some time, so if I can avoid it ...  :-)
Tx,
JC
Subject: Re: convert isosurfaces to mesh
Date: 9 Sep 2003 14:00:31
Message: <ar4slv4bdhd2kvov7vfgh2ilv7n0ib3prj@4ax.com>
On Tue, 09 Sep 2003 19:44:08 +0200, "JC (Exether)" <no### [at] spamfr> wrote:
http://news.povray.org/search/?s=tessel
Perhaps some of http://members.home.nl/seedseven/#MMMM could be useful too.
ABX
Date: 9 Sep 2003 14:10:04
Message: <Xns93F1901F0796None@204.213.191.226>
"JC (Exether)" <no### [at] spamfr> wrote in news:3f5e1162$1@news.povray.org:
The difficulty with isosurfaces is that they are functions and don't
necessarily present an actual contiguous surface.  A tessellation routine
that can handle any isosurface function would be very difficult, next to
impossible.
Date: 9 Sep 2003 15:02:02
Message: <7hk131-qmq.ln1@triton.schunter.etc.tu-bs.de>
There is the tesselation patch:
http://jgrimbert.free.fr/pov/patch/tessel/index.html
which also works for isosurfaces and there were various macros for this
posted over the time.
None the less you will find that all these methods are slow (esp. as
script) and don't really convert the isosurface - they just create a
rough approximation.
-- Christoph
Date: 9 Sep 2003 16:44:37
Message: <3f5e3bb5@news.povray.org>
> impossible.
  Actually tesselating a contiguous and derivable (read: smooth) isosurface
(which most are) is perfectly possible and not even too difficult. An
algorithm like the marching triangles is perfectly suitable.
Date: 9 Sep 2003 18:17:24
Message: <CCoseMAC9kX$EwdU@econym.demon.co.uk>
I've looked at Kevin Loney's approximation macro and Jaap Frank's go-
faster version for my Isosurface tutorial. Note that for many
isosurfaces it is faster to render the isosurface than it is to use the
approximation.
For parametric isosurfaces, there's Ingo Janssen's param.inc, which has
the advantage of being considerably faster than the original isosurface.
See my <http://www.econym.demon.co.uk/isotut/> for details.
Mike Williams
Date: 10 Sep 2003 07:19:37
Message: <3f5f08c9@news.povray.org>
Thanks all for you input, I will experiment that.
All I want to do is to have a basic equivalent to a very time-consuming
isosurface I have and use the iso for the real render.
JC
> Tx,
> JC
Date: 10 Sep 2003 09:35:31
Message: <Xns93F261949579None@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3f5e3bb5@news.povray.org:
>> routine that can handle any isosurface function would be very
>> difficult, next to impossible.
>   isosurface
I perfectly realize that, which is why I was reffering to non contiguous
surfaces and "any" (read: all) function.
Date: 10 Sep 2003 10:07:20
Message: <3f5f3018@news.povray.org>
> I've looked at Kevin Loney's approximation macro...
> Note that for many isosurfaces it is faster to render
> the isosurface than it is to use the approximation.
Considering the time to postprocess the data from Kevin Loney's macro,
perhaps it's faster to run an isosurface render. But I've found his macro to
be really useful. But you need to save the data. Possibly (as I did) in .OBJ
file format and run it through triangle decimation algoritm (that's always
neat). Then export back to mesh2 and the result will surely render faster
than any isosurface. It will, however, still use at least 10 times more
memory of course.
Hugo
Date: 10 Sep 2003 12:27:30
Message: <3f5f50f2$1@news.povray.org>
>>impossible.
Has anyone written a programm that does this for isosurfaces written in
povray syntax?
Sebastian H.
