POV-Ray : Newsgroups : povray.general : Text, csg & speed Server Time
31 Mar 2026 11:42:59 EDT (-0400)
  Text, csg & speed (Message 1 to 8 of 8)
Subject: Text, csg & speed
Date: 2 Sep 2003 15:12:06
Message: <3f54eb85@news.povray.org>
Hi all,
I'm modelling an engraved ring (the One Ring, actually), and I'm suffering a
serious slow down when I add the text. Currently, the basic structure of
the model is something like this:
  union {
    INNER_RING (inside of the letters, sort of a torus)
    difference {
      OUTER_RING (a slightly bigger torus)
      TEXT (a union of individually rotated and translated letters)
The whole thing is bounded_by a short cylinder of the right size. Is there
anything I could do to improve the rendering speed? Without text it renders
in around 2 minutes, with text it takes more than 2 hours.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Subject: Re: Text, csg & speed
Date: 2 Sep 2003 15:41:01
Message: <Xns93EADC93B9B9Bseed7@povray.org>
A completly different approach by Remco de Korte,
http://www.xs4all.nl/~remcodek/imaginc.html
Ingo
Date: 2 Sep 2003 16:22:00
Message: <bJ9aMBAcnPV$Ew+p@econym.demon.co.uk>
Wasn't it Jellby who wrote:
>Hi all,
>  union {
>    difference {
If possible, try cutting the OUTER_RING into letter-sized pieces,
difference one letter from each piece and union them back together
afterwards. Then remove your manual bounding, and let POV bounr it
automatically. The logic behind this is explained on my holes tutorial
page:
<http://www.econym.demon.co.uk/holetut/>
If the letters overlap, it should still work if you difference several
adjacent letters from each piece. It might sound like that would make it
run slower, but you still get the huge advantage of the tighter
bounding.
Mike Williams
Gentleman of Leisure
Date: 2 Sep 2003 16:24:08
Message: <3f54fc68@news.povray.org>
Jellby <jel### [at] m-yahoocom> wrote:
> Is there
  One thing which comes to mind is to use a cylindrical heighfield
(created by the HF_Cylinder() macro) to create the outer part of
the ring (with text and all). This would simply require you to
draw an image map suitable for this with an external painting program.
  The good thing is that you can smooth the edges of the text, which
you can't do with the text object (and in fact, if you use this method,
you certainly should because sharp edges don't work very well with
heightfields).
Date: 4 Sep 2003 15:13:37
Message: <3f578ee0@news.povray.org>
>>a serious slow down when I add the text. Currently, the basic structure of
>>  union {
>>    difference {
>>renders in around 2 minutes, with text it takes more than 2 hours.
> automatically.
Thanks for the ideas (yours and the other posters'). I tried this, but it
was becoming a too complicated code and I didn't see much improvement (I
assume it would have worked if I had done it right from the beginning).
However, if I manually bound each letter inside the TEXT union, render time
goes from 180 to 18 minutes (True Type Font test percentage: 44%). I
thought they would have been automatically bounded, since they are inside a
union...
Date: 4 Sep 2003 21:58:44
Message: <QIIIcAALs+V$EwOz@econym.demon.co.uk>
>>>  union {
>>>    difference {
>> automatically.
>union...
POV automatic bounding works for unions, but it doesn't work for
differences, which is basically the whole point of the holes tutorial
page I mentioned.
Mike Williams
Date: 5 Sep 2003 08:30:50
Message: <3f5881f9@news.povray.org>
>>time goes from 180 to 18 minutes (True Type Font test percentage: 44%). I
>>a union...
> page I mentioned.
I see, I expected it to work for unions inside a difference too.
Date: 5 Sep 2003 10:34:39
Message: <cjameshuff-084931.10343705092003@netplex.aussie.org>
In article <QIIIcAALs+V$EwOz@econym.demon.co.uk>,
> page I mentioned.
It does work in most cases, but does not produce bounds that are as
optimal as what a human looking at the involved shapes could come up
with. The same goes for intersections...I think POV simply intersects
the bounding boxes, which can result in very loose bounding. Your
message implied that there was no bounding done at all.
http://tag.povray.org/
