POV-Ray : Newsgroups : povray.general : Smooth triangle trouble Server Time
27 Dec 2025 20:26:31 EST (-0500)
  Smooth triangle trouble (Message 1 to 8 of 8)
Subject: Smooth triangle trouble
Date: 16 Jul 2003 13:45:34
Message: <3f158f3e@news.povray.org>
Hi.
I've got an object made of smooth triangles, and I'm using radiosity and a
sky_sphere for lighting. When I render, there's unnatural-looking, very dark
shadows on some triangles - especially those that are nearly edge-on to the
camera. It looks like I've got the "smooth triangle bug" as described in the
VFAQ, but when I add 'double_illuminate', the shadows remain. The only way
I've found to remove them is ditch smooth_triangles, and go with regular
flat ones.
So, does the double_illuminate fix not work with radiosity, or am I looking
at a different problem altogether? these shadows are too sharp-edged to be
radiosity artefacts.
Yours,
Luke.
Subject: Re: Smooth triangle trouble
Date: 16 Jul 2003 15:20:41
Message: <3f15a589@news.povray.org>
  Radiosity does not take double_illuminate into account.
  Probably not an intentional behaviour.
Date: 16 Jul 2003 18:02:23
Message: <3f15cb6f$1@news.povray.org>
if it's unintentional behaviour, I'd LOVE TO SEE THIS FIXED.
Apache
Date: 16 Jul 2003 18:07:36
Message: <3f15cca8$1@news.povray.org>
Is this a mesh of triangles made from other software, or did you construct
the object yourself?  I've had meshes that I ran through PolyTrans, and when
they were smoothed I got strange holes and such in the objects.  In other
words, it is probably something wth the way the surface normals are being
calculated, and using another piece of software to calculate them might fix
it.
Douglas C. Eichenberg
dou### [at] nlsnet
http://www.getinfo.net/douge
Date: 17 Jul 2003 08:19:17
Message: <3f169444@news.povray.org>
  There was a thread about the subject some time ago. I don't remember
what was the final decision about it.
Date: 17 Jul 2003 12:36:46
Message: <3f16d09e@news.povray.org>
Doug,
It's pure SDL (A little rope macro) and so entirely possible that I've got
the normals wrong. However, I think Warp had the right answer, so I'll be
using direct lighting for now.
Thanks all.
-Luke.
Date: 17 Jul 2003 12:43:21
Message: <3f16d229$1@news.povray.org>
I think it does.
See for example this:
http://news.povray.org/povray.binaries.images/25135/
Date: 17 Jul 2003 13:53:42
Message: <3f16e2a6$1@news.povray.org>
> I think it does.
After doing some tests I noticed that I am wrong. Radiosity does take
double_illuminate into account only when the surface is illuminated by
direct lights.
