POV-Ray : Newsgroups : povray.general : multiple object duplication factoring question Server Time
24 Nov 2025 00:28:43 EST (-0500)
  multiple object duplication factoring question (Message 1 to 8 of 8)
Subject: multiple object duplication factoring question
Date: 11 Jul 2003 10:54:18
Message: <3f0ecf9a$1@news.povray.org>
I'm attempting to make a chain of objects (about 300 of them) in which each
object is .04 units larger than the preceding one. Each object needs to be
translated *in proportion* to its increase in size. For example, the first
object is scale 1, the second is scale 1.04, trans .01*X. My calculator
tells me that the translation =scale*0.0096154*object's number in the chain
(the first one being 0, the second one being 1, etc). So, the third object
is scale 1.08*0.0096154*2=trans 0.0207692; the fourth would be
scale 1.12*0.0096154*3=trans 0.0323076, and so on. I could calculate each
translation and go crazy in the process, or find an easier way to do it. Do
any of you have any suggestions?
Thank you,
Steve Shelby
Subject: Re: multiple object duplication factoring question
Date: 11 Jul 2003 10:59:35
Message: <7vjtgvsv7pm5rvhp1i8shlv934k7a6q3gd@4ax.com>
On Fri, 11 Jul 2003 09:54:04 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
#local ObjectOrg = object{ ... }
#local Object = ObjectOrg;
#local Counter = 0;
#while (Counter<Iterations)
  #local Object = union{
    object{ ObjectOrg }
    object{ Object scale 1.04 translate .01*X}
  #local Counter = Counter + 1;
helped ?
ABX
Date: 11 Jul 2003 14:27:42
Message: <3f0f019e@news.povray.org>
ABX,
I tried the code you sent, and povray rendered just the background. I guess
I didn't fill in the blanks correctly. I put a simple sphere for the object,
and replaced "Iterations" with "300". I kept everything else the same. What
am I doing wrong?
Steve
"ABX" <abx### [at] abxartpl> wrote in message
news:7vjtgvsv7pm5rvhp1i8shlv934k7a6q3gd@4ax.com...
> #local Counter = 0;
>     object{ ObjectOrg }
> #end
> helped ?
> ABX
Date: 11 Jul 2003 14:49:31
Message: <ha1ugvcd9o9vf5sntjjv4vl6pv3c69mglm@4ax.com>
On Fri, 11 Jul 2003 13:27:27 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
> ABX,
If you rendered that code without _any_ change than you definietly rendered
differenc code. Perhaps some ini setting refered to another input file. If you
want to render my code you _need_ changes because it was only algorithjm
presented in form of POV script. You need to:
1. declare ObjectOrg and apply some texturing to it.
2. declare Iterations
3. add some light_source
4. add camera oriented to direction where your objects are grouped
ABX
Date: 11 Jul 2003 16:34:26
Message: <3f0f1f52@news.povray.org>
3f0f019e@news.povray.org...
> ABX,
guess
object,
What
> am I doing wrong?
Hmm, did you actually display the object by adding object{Object} after the
loop? ABX's code declares it but does not display it.
This little problem happens to me regularly...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 12 Jul 2003 18:15:36
Message: <3f108888@news.povray.org>
I'm sorry, but I can't make any sense of this at all. My level of expertise
with povray is very low, having relied  mostly on Moray to do the script
writing for me. Here's my sample pov file:
light_source {
  0*x
  color rgb <1,1,1>
  translate <-20, 40, -20>
  location  <0.0, 2.0, -5.0>
  look_at   <0.0, 0.0,  0.0>
#declare ObjectOrg = object{
sphere {
  <0, 0, 0>
  0.01 color rgb<1,1,1>
#declare iterations=300;
#declare Count = 1;
#while (Count<iterations)
    object{ ObjectOrg }
    object{ Object scale 1.04 translate .01*Count}
  #local Count = Count + 1;
Could you please tell me why it renders just blackness?
Steve
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3f0f1f52@news.povray.org...
> > ABX,
> guess
> object,
> What
> > am I doing wrong?
the
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 12 Jul 2003 18:47:27
Message: <3f108fe2.1752790@news.povray.org>
On Sat, 12 Jul 2003 17:15:33 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
I'm in the same boat Steve.
For a start try
sphere {
  <0, 0, 0>
  0.1
      pigment { color rgb<1,1,1>  }
This will give you your sphere (I changed the scale so I could see it)
I often use the statement (taken from Moray)
default {
    pigment { rgb <1,0,0> }
so that If I see a red object I know the texture statement is wrong.
Regards
Date: 14 Jul 2003 02:29:49
Message: <bqi4hvcebb4tum3tpghpcfkd2a1gtavfjh@4ax.com>
You probably expect something like such complete scene, commented with possible
problems. Think about sense of questions in comments:
#include "transforms.inc"
light_source {
  0*x
  color rgb <1,1,1>
#declare ObjectOrg = sphere {
  <0, 0, 0>
  0.01
  pigment{ color rgb<1,1,1> }  // why not added pigment in your version ?
#declare Iterations=300;
#declare Count = 1;
#while (Count<Iterations)
    object{ ObjectOrg }
    object{ Object scale 1.04 translate .01*x} // why X replaced with counter ?
object{ Object }  // why you not added object to scene ?
  #local Mn = min_extent(Object);
  #local Mx = max_extent(Object);
  look_at   (Mn+Mx)/2 // why not look to center of object ?
ABX
