POV-Ray : Newsgroups : povray.general : matrix (components as functions of the coordinates) Server Time
25 Aug 2025 03:31:00 EDT (-0400)
  matrix (components as functions of the coordinates) (Message 1 to 8 of 8)
Subject: matrix (components as functions of the coordinates)
Date: 12 Jun 2003 19:36:23
Message: <3ee90e76@news.povray.org>
Hi, I`ve got a question about the matrix keyword...
Is there any way to create a (matrix) transformation in POVRAY with
the matrix components V00 .. V32 (as descripted in the manual) as
functions of the image coordinates px, py, pz?
I wanted to create a "cone" with the base just like a ellipse and the
top just like a normal circle. Therefor I have to scale the original cone
at the base with something like <1,1,0.5> and at the top with <1,1,1>,
between these both position scaling like a linear function.
If there's no way to solve this problem with the matrix keyword,
is there any other way to do?
thanks...
Subject: Re: matrix (components as functions of the coordinates)
Date: 12 Jun 2003 20:54:22
Message: <F3Q9TCAW5R6+EwjK@econym.demon.co.uk>
You could do it with an isosurface.
This spline-driven parametric isosurface gives an open "cone" that
varies from <1,1,0.5> to <1,1,1>. (For speed you could use Ingo's
param.inc.)
// Cone with an elliptical base and circular top
#version 3.5;
camera { location  <3, 3, -5> look_at <0, 0.5, 0> angle 20}
light_source {<100,200,-500> colour rgb 1}
// The spline that defines the edges of the "cone"
#declare S = function {
   spline {
    linear_spline
      0, <1, 1, 0.5>,
      1, <1, 1, 1>
// The Fx and Fy functions are derived from the
// X and Y values of the spline
#declare Fx = function(x,y) {(S(u).x * sin(v)/2)}
#declare Fy = function(x,y) {u}
#declare Fz = function(x,y) {(S(u).z * cos(v)/2)}
// The U parameter controls the Y height
#declare Umin =  0;
#declare Umax =  1;
// The V value goes round the circumpherence
// plus a little overlap to prevent an edge artefact
#declare Vmin =  -pi;
#declare Vmax =  1.001*pi;
// The isosurface
parametric {
  function {Fx(u,v)}
  function {Fy(u,v)}
  function {Fz(u,v)}
      <Umin,Vmin>,<Umax,Vmax>
  contained_by{box{<-1,0,-1><1,1,1>}}
  precompute 18, x,y,z
  pigment {rgb 0.9}
  finish {phong 0.5 phong_size 10 ambient 0.2}
plane {y,0 pigment {rgb 1}}
This isosurface gives a closed shape and renders much faster,
unfortunately the sides aren't quite straight.
#version 3.5;
camera { location  <10, 5, -10> look_at <0, 0.5, 0> angle 10 }
light_source {<0,100,-100> colour rgb 1}
background {rgb 0.3}
// This function would give an ordinary cylinder
#declare F=function { x*x + z*z - 0.25}
// The Z value is then transformed by z*(2-y)
// which gives z*1 at the top when y=1
// and z*2 at the bottom when y=0
isosurface {
        function {F(x,y,z*(2-y))}
        max_gradient 5.5
        contained_by{box {<-1,0,-1><1,1,1>}}
        pigment {rgb .9}
        finish {phong 0.5 phong_size 10}
Date: 12 Jun 2003 21:00:44
Message: <cjameshuff-623393.19522612062003@netplex.aussie.org>
In article <3ee90e76@news.povray.org>,
You can not. The matrix coefficients are constant, and only reversable
linear transforms are supported. To do otherwise would require tracing
curved rays, which is very, very slow.
You could use a generic polynomial shape or an isosurface. Or you could
just use the Supercone() macro in shapes.inc, which lets you specify an
ellipse for each end of a cone.
http://tag.povray.org/
Date: 13 Jun 2003 03:14:00
Message: <3ee979b8@news.povray.org>
  "You could use a polynomial... or you could use the Supercone() macro" as
if they were two different things is a bit misleading because the Supercone()
macro creates a polynomial. :)
  Using the Supercone() macro is certainly the easiest way.
Date: 13 Jun 2003 03:14:31
Message: <3ee979d7@news.povray.org>
How about using Supercone() in shapes.inc instead?-)
Date: 13 Jun 2003 04:50:46
Message: <3ee99065@news.povray.org>
>   as
> Supercone() macro creates a polynomial. :)
Hi, many thanks for your hints (Supercone). It worked fine.
(Guess I have to read all of the Include-Files...;-)
But nevertheless it would be a great feature (in my opinion)
if POVRAY could do something like skaling an object as a function
of the coordinates ;-)
best regards
   Edwin
Date: 13 Jun 2003 04:58:25
Message: <3ee99231@news.povray.org>
  It certainly would be nice, but it's not possible because it's not
an affine transformation (even though it might look like it was).
  Affine transformations are all those transformation which keep a
straight line straight after the transformation. If the line would be
bent after the transformation, that's just not possible. (And here I'm
talking naturally about the ray we are tracing.)
Date: 13 Jun 2003 05:18:13
Message: <3ee996d4@news.povray.org>
Hi Mike,
I've raytraced your isosurface and it worked fine. But it'll
take some time for me to understand what's going on ;-)
It seems that those isosurfaces are a powerful feature.
Many thanks,
   Edwin
