POV-Ray : Newsgroups : povray.general : Offloading some calculations to a GPU Server Time
10 Jan 2026 01:33:45 EST (-0500)
  Offloading some calculations to a GPU (Message 1 to 10 of 19)
Subject: Offloading some calculations to a GPU
Date: 11 Jun 2003 11:30:01
Message: <3ee74af9$2@news.povray.org>
Most modern PCs have a very powerful 3d video card with a GPU that is
hundreds if not thousands of times faster than the CPU for certain
calculations. I was thinking if some of the POV computations could be
offloaded to the GPU, we could speed up renders by a very large factor. The
big question is one of which routines thouse would be and which chunks of
the GPU could be utilized. Certainly matrix operations could be offloaded at
the very least, although I don't know to what extent that would improve
performance. It's just a shame that there is this uber-powerful floating
point processor sitting in most PCs that can't be used to help things move
along. What do others think?
Subject: Re: Offloading some calculations to a GPU
Date: 11 Jun 2003 11:33:04
Message: <3ee74bb0$1@news.povray.org>
In article <3ee74af9$2@news.povray.org> , "Michael Goldshteyn"
You need double precision floating-point processing.  Sorry!
    Thorsten
Date: 11 Jun 2003 11:47:17
Message: <3ee74f05$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3ee74bb0$1@news.povray.org...
The
of
offloaded at
move
>     Thorsten
Sorry, I accidentally e-mailed my reply, instead of posting it.
In any case, a quote from NVIDIA's web site:
And, powered by the second-generation NVIDIA CineFXT 2.0 engine with the
industry's only true 128-bit precision processing--the GeForce FX 5900 GPUs
take cinematic-quality special effects to new levels while providing the
industry's most compatible and reliable gaming platform.
Now, double-precision uses 64-bit floating point, so I think this is more
than enough.
Date: 11 Jun 2003 11:50:01
Message: <web.3ee74ea3d3e4b3b1465fc1770@news.povray.org>
I wanted answer almost identicall but I'm completly dumb in that area so did
quick search in google. It answered there are GPUs with 128-bit
floating-point precision.
ABX
Date: 11 Jun 2003 11:55:55
Message: <3ee7510b$1@news.povray.org>
After doing more reading, the 128 bit precision may refer to 32-bit floating
point times four. So, in fact, the GPU may only be single-precision per
color.
Date: 11 Jun 2003 12:57:34
Message: <3ee75f7e$1@news.povray.org>
In article <web.3ee74ea3d3e4b3b1465fc1770@news.povray.org> ,
No, you simply fall for a good trap their marketing people have set up.  The
GPUs are SIMD processors and the units work with four single precision
floating-point numbers*.  Hence, for a marketing person it works with 128
bits precision using floating-point numbers <sigh>
    Thorsten
* The smallest document on the Nvidia site that details the marketing math
is <http://developer.nvidia.com/docs/IO/3121/ATT/CineFX-TechBrief_v02.pdf>
e-mail: tho### [at] trfde
Date: 11 Jun 2003 14:33:40
Message: <3ee77604$1@news.povray.org>
But do you *really* need it for everything
Kitty5 NewMedia http://Kitty5.com
PGP Public Key
Date: 11 Jun 2003 14:40:24
Message: <pmteevkvm0gutj413ddie2rpdjontfdeeg@4ax.com>
On Wed, 11 Jun 2003 19:31:17 +0100, "Rick [Kitty5]" <spa### [at] kitty5com> wrote:
Single precision floats are used for colors in POV sources.
ABX
Date: 11 Jun 2003 15:37:15
Message: <3ee784eb$1@news.povray.org>
In article <3ee77604$1@news.povray.org> , "Rick [Kitty5]"
You need it for intersection tests.  You cannot store enough data in 32 bits
to perform adequate intersection tests without limiting the geometry.
You seem to misunderstand what precision anything stored in 32 bits can
possibly provide.  From a more conventional perspective, I would suggest to
get a introduction to combinatorics book and read the chapter on the
pigeonhole principle.
    Thorsten
Date: 11 Jun 2003 17:18:07
Message: <cjameshuff-0BE258.16094311062003@netplex.aussie.org>
In article <3ee74af9$2@news.povray.org>,
As others have mentioned, because of precision issues, this isn't useful
for geometry calculations. But more importantly, this isn't like a
floating point coprocessor, it is a video card, and is designed to
efficiently display things. Even if the card can do the operations
faster, it will take far more time to send the data to the card to be
processed and then retrieve it than it would to process the data on the
CPU. There are some things it could accelerate, but typically not what
POV needs.
With more programmable cards becoming available, you can do more
general-purpose things with the card...it may be possible to process
data in large enough chunks that it is worth it to use the card, maybe
even doing all the raytracing on the card. However, you'd most likely
have to design the raytracer around this, I don't see anyone converting
POV to do it. And then you have the hardware dependencies, etc...
http://tag.povray.org/
