POV-Ray : Newsgroups : povray.general : wheel slice of a sphere Server Time
24 Nov 2025 04:21:19 EST (-0500)
  wheel slice of a sphere (Message 1 to 5 of 5)
Subject: wheel slice of a sphere
Date: 2 Jun 2003 10:29:38
Message: <3edb5f52$1@news.povray.org>
Hello again!
Imagine wheel. Now imagine it  cut in half. That is the shape I am trying to
get.
I was able to get that shape by using taking the difference of a sphere and
some cubes, but is there an easier way?
Below is an example of how I do it now, hopefully there is a better way
// file begin
#version 3.5;
#include "textures.inc"
global_settings {
  assumed_gamma 1.0
  max_trace_level 5
  location  <5.5, 4, -20>
  look_at   <5.5, 4, -10>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
plane {               // checkered floor
  y, -2.5
  texture
      checker
      color rgb 1
      color blue 1
      scale 0.5
    finish{
      diffuse 0.8
      ambient 0.1
difference {
    sphere {              // reflective sphere
      <5.5, 4, -10>, 2.5
            Glass
            scale 4      // Scale by the same amount in all
    // bottom box
    box {
        <3, 1.5, -12.5>
        <8, 4,  -7.5>
            Glass
    // front box
    box {
        <3, 4, -12.5>
        <8, 6.5, -10.125>
            Glass
    // back box
    box {
        <3, 4, -9.875>
        <8, 6.5, -7.5>
            Glass
Subject: Re: wheel slice of a sphere
Date: 2 Jun 2003 10:39:20
Message: <73omdv4t3jo38s0j0hpmb67p893hklsrcm@4ax.com>
On Mon, 2 Jun 2003 10:29:39 -0400, "Mario" <ant### [at] spamcopnet> wrote:
> Hello again!
> get.
intersection{} of sphere{} and plane{} ?
>        texture {
>            Glass
Out of curriosity what you expect from "scale 4" here ?
And since all components of difference{} have the same texture you could apply
it once at end of difference{} block.
ABX
Date: 2 Jun 2003 10:50:23
Message: <3edb642f$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:73omdv4t3jo38s0j0hpmb67p893hklsrcm@4ax.com...
wrote:
> > Hello again!
trying to
> > get.
and
I think that would be more like a hemisphere. What I wanted was a slice of
that. Hmm... like a lemon wedge slice or orange slice
> >        texture {
> >            Glass
I'm not sure....I think that was just copied from code somewhere else. Maybe
something off of the POVRay "Insert" submenu...
apply
That's good to know! Thanks!
Date: 2 Jun 2003 10:53:46
Message: <23pmdv4o26ijgv0rq1u8kvtgnb5c4i7tdc@4ax.com>
then put intersection between sphere and box, like:
intersection{
  sphere{0 1}
  box{<-.5,-1,-1><-.4,1,1>}
  pigment{rgb 1}
ABX
Date: 3 Jun 2003 06:07:15
Message: <3edc7353@news.povray.org>
Maybe you should look at superellipsoids....
difference {
  superellipsoid {  <1, 0.5>
    scale z/2
  plane {y,0 rotate z*30}
  plane {y,0 rotate -z*30}
  pigment {Red}
  rotate <0,45,0>
// ----- Tim Attwood -----
light_source{-10 color rgb 1}#local T=6*z-3*x;#local I=T;#local
M=0;#local A=
array[10]{1287709,43035510,7312399,36346003,50603446,6192184,12772732,33037915,
41777870,42384480}union{#while(M<99)#local
N=int(mod(A[div(M,10)]/pow(6,(9-mod(
M,10))),6));#local
I=I+((N=0)-(N=1))*y/2+((N=3)-(N=2))*x/2;#if(N=4)sphere{T.1}
cylinder{T,I,.1}#end#local T=((N>3)?I:T);#local M=M+1;#end pigment{rgb x+y}}
