POV-Ray : Newsgroups : povray.general : Image texture with alpha channel in POV? Server Time
31 Mar 2026 20:05:46 EDT (-0400)
  Image texture with alpha channel in POV? (Message 1 to 6 of 6)
Subject: Image texture with alpha channel in POV?
Date: 18 May 2003 10:47:33
Message: <3ec79d05@news.povray.org>
I use Blender for my scenes so the exported output is in mesh2 format. Now I
need an (uv-mapped) image texture for a logo, but the finish under that
should still be visible and it should not be influenced by the texture. Is
this possible? A TGA-texture with alpha channel doesn't work properly
because the finish is then invisible, too.
Andreas
http://www.render-zone.com
Subject: Re: Image texture with alpha channel in POV?
Date: 18 May 2003 10:58:16
Message: <3ec79f88$1@news.povray.org>
3ec79d05@news.povray.org...
> Hi,
I
Try an image_pattern, like in this page :
http://www.oyonale.com/ressources/english/xfrog2.htm
This is not exactly the same problem but I guess it should work.
G.
- Graphic experiments
- Posters
Date: 18 May 2003 12:43:21
Message: <3ec7b829@news.povray.org>
Hi Gilles!
Thanks for your response. I just have a question regarding your texture
definition. You wrote on your website:
texture{
    image_pattern{jpeg "autleaf_tr"} // used for the transparency
    texture_map{
        [0 pigment{Clear}finish{ambient 0 diffuse 0}] // transparent part,
no highlights or reflections
        [1 pigment{image_map{jpeg "autleaf"}} finish{ambient 0 diffuse 1}]
// leaf pigment
What does "{Clear}" mean?
Andreas
Date: 18 May 2003 13:31:38
Message: <3ec7c379@news.povray.org>
Andreas Kreisig wrote:
> texture{
>     texture_map{
> // leaf pigment
Okay, If "Clear" means something like "color rgbt <1,1,1,1>" I have the same
problem as before. The whole mesh is invisible except the image wich is
mapped on it.
Andreas
Date: 19 May 2003 12:40:56
Message: <3ec90918$1@news.povray.org>
3ec7c379@news.povray.org...
same
> mapped on it.
In the example, the clear pigment is necessary to make the transparent part
really transparent. In your case, you need to use your regular texture
instead.
#declare T_mat=texture{
    image_pattern{ jpeg "mylogo_blackandwhite" interpolate 2}
//    pigment_pattern{image_map{jpeg "mylogo_blackandwhite" interpolate 2}}
// for more control
    texture_map{
        [0.5 T_MainTexture]
        [0.5 T_Logo]
Of course, if there several logotypes, it may not be very easy... It's true
that there's no "decal" feature in POV-Ray to do this.
G.
- Posters
Date: 20 May 2003 10:37:05
Message: <3eca3d90@news.povray.org>
> part really transparent. In your case, you need to use your regular
> texture instead.
> 2}} // for more control
>     texture_map{
>         [0.5 T_MainTexture]
>         [0.5 T_Logo]
> true that there's no "decal" feature in POV-Ray to do this.
Well, I think I'll try to copy the appropriate part of the mesh, move it
(very) slightly and try to map the image on it - like your description on
your website, so that the mesh itself is completely transparent. I hope
that there are no edges visible when I prevent the object to cast shadows.
Thanks so far,
Andreas
