POV-Ray : Newsgroups : povray.general : 16 bit image map pattern not working with isosurface Server Time
5 Oct 2024 10:12:42 EDT (-0400)
  16 bit image map pattern not working with isosurface (Message 1 to 10 of 11)
Subject: 16 bit image map pattern not working with isosurface
Date: 1 May 2003 10:00:11
Message: <3eb1286a@news.povray.org>
Using the following code...
#declare pigment_foo = function {
                image_map {
                        png "gray16.png"
                        interpolate 2
isosurface {
        function {
                ... prigment_foo(x,y,z).gray ...
...it turns out that the resulting isosurface only uses the
high 8 bit of the image_map although the image map source is
a 16 bit grayscale PNG.
Am I doing something wrong or
is there a way to get native support for 16 bit or
is it unavoidable that I fall back to using two 8-bit PNG-based
  pigments (one for MSB one for LSB) ?
Wolfgang
Subject: Re: 16 bit image map pattern not working with isosurface
Date: 1 May 2003 11:00:05
Message: <3EB13674.FD19BC5D@gmx.de>
Who said the png reader supports 16 bit grayscale files? :-)
The only format where 16 bit data is currently supported for image maps in
plain POV-Ray 3.5 is ascii PGM.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 1 May 2003 12:44:16
Message: <3eb14edf@news.povray.org>
Quoting POVRay-3.5 doc: (povray-3.50c/doc/html/povdoc_187.html)
> PNG format heightfields are usually stored in the form of a grayscale
> image with black corresponding to lower and white to higher parts of the
> height field. Because PNG files can store up to 16 bits in grayscale
> images they will be as smooth as TGA and PPM images.
This is about height fields, so I thought it was just natural that
it would also work for pigments.
Wolfgang
Date: 1 May 2003 14:18:02
Message: <3eb164da@news.povray.org>
In article <3eb14edf@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
pigments != heightfields
    Thorsten
Date: 1 May 2003 19:45:08
Message: <web.3eb1b01c2a9b1139f7846a350@news.povray.org>
>        pigment {
>                image_map {
>                        png "gray16.png"
>                        interpolate 2
>isosurface {
>        function {
>....it turns out that the resulting isosurface only uses the
>Wolfgang
I busted my head over this one too for a while. I ended up using TGA's of
the 16-bit-for-height_field flavor and extracting the MSB and LSB by
function{pigment_foo(x,y,z).red+pigment_foo(x,y,z).green/256}
which is probably where you are almost at anyway.
By the way, check out http://3dgallery.dhs.org/tutorials/iso_tutor.html if
you haven't already.
Abe
http://www2.taconic.net/bullfrog/sky
Date: 2 May 2003 01:33:46
Message: <3EB2033A.9489F377@gmx.de>
Note this is probably an extremely bad idea since it does not work with
interpolation and using not interpolated image maps will result in
infinite gradients in the function.
Date: 2 May 2003 10:25:05
Message: <web.3eb27f452a9b1139adb976770@news.povray.org>
>Christoph
>POV-Ray tutorials, include files, Sim-POV,
>HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Ouch! I missed the implications of interpolating before extracting MSB and
LSB. But then I was doing landscapes and the extra wrinkles were not that
apparent. (I would call it "a bad idea" instead of "an extemely bad" one,
since it
sort-of-sometimes-under-certain-circumstances-when-the-moon-is-in-the-righ-phase
works ;))
Is the correct answer then to build a 16 bit function_image from a non
interpolated image_map and interpolate that?
Abe
Date: 2 May 2003 12:24:33
Message: <3eb29bc1@news.povray.org>
  Doesn't pigment_foo(x,y,z).hf do exactly this?
Date: 3 May 2003 12:57:17
Message: <3eb3f4ec@news.povray.org>
Well, I thought that I will run into trouble with bilinear
interpolation. However, I actually didn't see any problems.
I'm interpolating the LSB and the MSB pigment map separately
and it looks great. Not interpolating one of them is a bad idea.
Maybe we could find a mathematical proof for the correctness or
falseness...
Wolfgang
Date: 3 May 2003 16:31:15
Message: <3eb42713@news.povray.org>
...what would you suggest to work around this problem
(beyond patching POVRay)?
Wolfgang
