POV-Ray : Newsgroups : povray.general : radiosity clamping Server Time
28 Dec 2025 05:26:08 EST (-0500)
  radiosity clamping (Message 1 to 4 of 4)
Subject: radiosity clamping
Date: 15 Apr 2003 22:26:20
Message: <3e9cbf4c@news.povray.org>
I'm trying to simulate daylight coming through a window, like that classic
Vermeer scene on the cover of Computer Graphics by Foley et al.
I can't get my window pane to cast much light into the scene at all. I've
set ambient to 1 for the window and turned off all other ambient values in
the scene, then played with the variables. Is this a clamping problem in the
POV radiosity code, as I've seen mentioned before?
If I play with the POV source (volunteer to improve) is there a place where
I can easily add a capability to increase the effective brightness of an
arbitrary radiator to a value higher than ambient 1? I guess I'm talking
about simulating a very strong area light, which is what daylight coming
through a window is supposed to look like in a radiosity scene.
Subject: Re: radiosity clamping
Date: 16 Apr 2003 03:20:49
Message: <3e9d0451$1@news.povray.org>
;) like this one?
http://news.povray.org/povray.binaries.images/27257/
I do not think so.
I did go with an ambient value of about 150 (if I remember right) for the
skysphere and it is lit only by radiosity to reproduce the way the Foley
cover was done.
good luck
-Ive
Date: 16 Apr 2003 04:42:48
Message: <3E9D1788.FCC78AB2@gmx.de>
No.  The color values returned by sampling rays are not clipped in
POV-Ray.  Same applies for the samples stored in the cache (you can check
the cache file if you don't believe that).  The only place where values
are clipped is when reusing them.  Therefore you can use ambient finishes
with ambient > 1 without problems.  The only difficulty arises when the
stored illuminance values exceed 1.
If you want an area light, use an area light.  There is no point in trying
generate light source effects with ambient objects.  Sunlight coming
through a window should be made with a light source placed outside,
skylight with an ambient sphere/sky_sphere.
Next MegaPOV will contain a patch for removing the clipping.  You will
however recognize that it won't make much difference in most situations.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 16 Apr 2003 18:05:05
Message: <3e9dd391@news.povray.org>
Excellent result now!
I was suffering under the impression that I should normalize my ambients to
the range 0-1 and didn't realize I could use an unbounded value.
One of the scenes I'm trying to perfect can be seen at
http://www.worldwins.net/~peter/images/worldwins-sideview.jpg
My site at worldwins.net will  use a 'virtual office' based file system,
part of a new OS I'm developing so I want all my links to have a consistent
look and feel. POVRay is ideal for this, and also a lot of fun to work with.
This is only my second posting to any newsgroup (I've been an underground
cave dweller by necessity the last couple of years - the Real World has been
too distracting).
I'm doing a lot of work with XML, XSLT, SVG and  Schemas; all my POV source
files are in XML and are transformed back and forth from .xml to .pov to
SVG. If anyone else is doing work in this area I'd like to know about it.
