POV-Ray : Newsgroups : povray.general : 2.8 GHz chip is 2.5 times slower than 1 GHz Server Time
21 Apr 2026 19:12:49 EDT (-0400)
  2.8 GHz chip is 2.5 times slower than 1 GHz (Message 1 to 10 of 14)
Subject: 2.8 GHz chip is 2.5 times slower than 1 GHz
Date: 14 Mar 2003 09:09:20
Message: <3e71e290$1@news.povray.org>
I got a new WinXP PC with a 2.8 GHz chip.  I ran the benchmark.pov scene
this PC and an old one with 1 GHz.  Both boxes are WinXP.
Results:
  2.8 GHz  13361  secs
  1.0 GHz    5315 secs.
Comments:
1) This *does* play in to my cynicism that advances in hardware are going to
be taken up by the demands of the operating system for ads,  checks on the
internet for Windows bugifixes every other minute, etc...
2) I just downloaded 3.5 and didn't make any checks for render priority,
etc. Perhaps this makes all the difference in the world.
3) The new PC went into a sleep mode by the next morning, a harder, deeper
sleep, and I know it does so after a much shorter time than the old one.
Perhaps the folks who design sleep modes  never consider you might need to
do some CPU-intensive stuff while you're away: they probably figure that if
you're not typing at the word processor, you have absolutely no need for the
CPU at all.   I've always wondered how povray interacts with the sleep cycle
of various versions of windows.
4) On my 1 GHz PC, I  have several times seen povray's render get hung up by
an error message from WinXP that it had lost contact with the internet.
Now, I may be pushing the envelope even further by having two PC's with
wireless modems right next to each other.  WinXP is always giving me
messages about the status of this connection, and it's even more
intermittent now that I have two PC's on my wireless router.  It's also
likely that my brand of wireless modem is not WinXP-friendly, which may
cause additonal problems.     I also (stupidly) may have asked the PC
company to install network capabilities (a lan card??) that I don't even
need, and this may cause WinXP to spend lots of time fussing over it.
Subject: Re: 2.8 GHz chip is 2.5 times slower than 1 GHz
Date: 14 Mar 2003 10:27:43
Message: <3e71f4ef$1@news.povray.org>
In article <3e71e290$1@news.povray.org> , "Greg M. Johnson"
> Results:
>   2.8 GHz  13361  secs
>   1.0 GHz    5315 secs.
Something is misconfigured.  That's all ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Mar 2003 10:31:53
Message: <3e71f5e9$1@news.povray.org>
"Greg M. Johnson" <gregj:-)565### [at] aolcom> wrote in message
news:3e71e290$1@news.povray.org...
Just as a little side note (and this may be fixed under xp) - make sure that you
disable any unused network cards in the device manager. On booting, windows 95,
98 and 2000* spend a lot of time trying to find something useful to do with
network cards, even if they are not connected to anything.
The indicator that this is happening is a long pause in the boot-up not
accompanied by much in the way of disk activity.
* I haven't exactly experienced this with a card under 2000 - it was some AOL
protocol or other (installed AOL to help out a friend - had to delete the
protocol before boot-times went back to normal).
Date: 14 Mar 2003 11:05:32
Message: <3e71fdcc$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e71f4ef$1@news.povray.org...
Do you suspect it's an outright  warranty issue or is this just a humorous
comment?
Date: 14 Mar 2003 11:15:05
Message: <rlv37vgii4qjg7o5nu60j96n8kp7u9hlrn@4ax.com>
On Fri, 14 Mar 2003 11:04:40 -0500, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
> comment?
knowledge?
Did you used WinGUI installed over previous version ? Did you used benchmark
from menu of from file ? Did you had the same priority settings verified ? Both
had energy saving off ? Non other applications ? Any other benchmark application
tested ?
ABX
Date: 14 Mar 2003 15:05:28
Message: <MPG.18dbdcb250372a2989774@news.povray.org>
In article <3e71e290$1@news.povray.org>, "Greg M. Johnson" <gregj:-
)565### [at] aolcom> says...
> Results:
>   2.8 GHz  13361  secs
>   1.0 GHz    5315 secs.
> Comments:
Well, I seem to remember someone once saying that, "if you idiot proof
things enough, only an idiot will want to use them." I think in some
respects Windows is starting to approach that level. The blasted OS
already liked to do incomprehensibly useless things in Win98 (like
letting some programs spawn 20 dial-up connection wizards if they
couldn't access the internet), now it does even more stuff behind your
back in XP. lol
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 14 Mar 2003 17:21:07
Message: <3e7255d3@news.povray.org>
Was that an Intel or AMD CPU?
- Nekar Xenos
Date: 14 Mar 2003 19:04:11
Message: <3e726dfb$1@news.povray.org>
> Results:
>   2.8 GHz  13361  secs
>   1.0 GHz    5315 secs.
Sorry, it doesn't make any sense. You sure you didn't forget the
antialiasing on the 1GHz machine ? This alone would make these figures
consistent.
The only other reason I can think of is a RAM issue (not enough RAM on the
2.8 GHz machine) but I'm not sure the benchmark is such a RAM hog.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 14 Mar 2003 22:36:21
Message: <3e729fb5$1@news.povray.org>
I've now been able to try again.
Second try on the 2.8GHz machine:   2446 secs (vs. 13361 on first try).
Last night, I hit the Render button and went to sleep.  Next morning PC was
in sleep mode (a deeper one than I usually see on the 1.0 machine). and the
next morning the  Message board said 13361 secs.
This morning I hit Render again and went to work.  When I was able to check
the PC again, it said 2446 secs.
So two wacky things going on:
1) WinXP's overagressive sleep mode.
2) WinXP's extreme neurosis about the state of its connectivity to the
internet (I've seen renders hang due to a warning message from XP).
Both cases  512 x 384 AA 0.3 of benchmark.
Will try new experiments.
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3e726dfb$1@news.povray.org...
> consistent.
Date: 14 Mar 2003 23:53:30
Message: <3e72b1ca$1@news.povray.org>
Greg M. Johnson's furious key-hammering produced this:
As far as I know, Windows XP does little but tell the computer's BIOS when to
go into sleep mode.  Also, if going into sleep mode were based on processor
activity, the computer would never go into sleep mode.
> internet
Make sure the auto-update features are off and MSN Messenger is shut down.
Shouldn't happen in Windows.  Even if a window popped up in front of POV-Ray it
should keep tracing in the background.
/*^*/light_source{100*<-5,2,-5>2}#macro I(i,n)#while(strlen(i)>=n)#local A=asc(
substr(i,n,1));#local a=asc(substr(i,n+1,1));cylinder{<div(A,8)-12,mod(A,8)-4,4
><div(a,8)-12,mod(a,8)-4,4>,0.1pigment{rgb z}}#local n=n+2;#end#end I("ScUe[]"1
/*<*/)I("mkmtlttk"1)//@_$#!,:<"Thhis polysig brought to you by Ian Burgmyer :)"
