POV-Ray : Newsgroups : povray.general : Bug in waves in 3.5? Server Time
19 Sep 2025 01:53:16 EDT (-0400)
  Bug in waves in 3.5? (Message 1 to 3 of 3)
Subject: Bug in waves in 3.5?
Date: 10 Feb 2003 08:17:13
Message: <3e47a659@news.povray.org>
OK, there is something different about the waves pattern in PovRay 3.5.
I found the following texture renders markedly differently in 3.5 compared
with both 3.0.20-10 debian and megapovplus 0.5.0.2.5a-1 (3.1 equivalent),
which both render the images similarly to each other.
It looks to me like the grade between 0 and 1.0 in the texture map of the
older versions is quite different to the grade in 3.5 .. for example as
if one used a linear gradient and the other an exponential one. I hope
someone understand what I mean.
In fact as outlined below, I found the cause is in the waves function,
not in the texture_map per se.
I don't see this particular case explained in the documentation or in the
bugs so far listed in povray.general or povray.bugreports, or by googling
old usenet postings.
I should have been more specific about the version I guess .. this is
3.50c for linux downloaded from povray.org as binary.
The problem occurs regardless of whether I declare #version 3.0 (or 3.1)
or just render it without the version declaration. It also occurs
regardless of which of the three noise_generators are used.
#version 3.0
//test.pov
//bah there is some bug in the 3.5 textures i think
//Simeon Scott 2003-02-01 ////////////////////////
//Something like a blue agate.
background
  { color White }
global_settings
  ambient_light 0.05
  assumed_gamma 1
//  noise_generator 1   /* line commented out
                          because it doen't fix it
                          and it breaks older versions.
                          Of course you should try it both
                          ways if you render the scene
                          in 3.5 to verify */
camera
  location <0, 0, -3>
  look_at <0, 0, 0>
  scale 0.2
light_source
  {  <2, 4, -3> color White scale 0.4 }
#declare Sim_Blue_Agate = texture
  waves
  texture_map
    [  0.15 pigment { color White }        ]
    [  1.0  pigment { color <0, 0, 0.3> }  ]
  turbulence <10, 10, 0.3>
  scale 0.1
sphere
  {  <0, 0, 0>, 0.3	texture {  Sim_Blue_Agate } }
http://bur.st/~shevek/test_3.0.jpg
http://bur.st/~shevek/test_mega0.5.jpg
http://bur.st/~shevek/test_3.5.jpg
Here is some of what I could garner from the documentation. Some people
suggested maybe the change in the noise_generator is what is causing my
problem. Changing to use noise_generator 1 doesn't fix the problem. But
who knows, maybe noise_generator 1 is what is broken. To try to find
out, here is some stuff from the documentation:
    2.6.14  Changed features that may 'break' old scenes
    Noise:
    New noise functions have been added in POV-Ray 3.5. Noise functions
    are internaly used in patterns. The default function in 3.5 is not
    the same as it was in 3.1 and earlier. This may affect the appearence
    of textures in old scenes.
    Solution: put noise_generator 1 in global_settings{}.
    6.7.12.4  Noise Generators
    There are three noise generators implemented. Changing the
    noise_generator will change the appearence of noise based patterns,
    like bozo and granite.
    * noise_generator 1 the noise that was used in POV_Ray 3.1
    * noise_generator 2 'range corrected' version of the old noise, it
      does not show the plateaus seen with noise_generator 1
    * noise_generator 3 generates Perlin noise
    The default is noise_generator 2
    Note: The noise_generator can also be set in global_settings
So it looks like indeed the 'noise generator' MAY be applicable, if it
is used in the waves function or in turbulence. Note that bozo is
mentioned as definitely being affected. So let's compare bozo/granite
and waves in functions.inc. But first, please note that setting
noise_generator 1 does not recitfy the output.
From functions.inc
#declare f_bozo = function {f_noise3d(x, y, z)}
#declare f_granite = function {pattern {granite}}
#declare f_waves = function {pattern {waves}}
Well, that isn't very enlightening. The case is still open. So
resorting to the source code, in patterns.cpp we find:
static DBL granite_pattern (VECTOR EPoint, TPATTERN *TPat)
  register int i;
  register DBL temp, noise = 0.0, freq = 1.0;
  VECTOR tv1,tv2;
  VScale(tv1,EPoint,4.0);
  int noise_generator;
  if (TPat != NULL)
    noise_generator = (TPat->Flags & NOISE_FLAGS) >> 4;
  if (!noise_generator)
    noise_generator=opts.Noise_Generator;
  for (i = 0; i < 6 ; freq *= 2.0, i++)
    VScale(tv2,tv1,freq);
    if(noise_generator==1)
      temp = 0.5 - Noise (tv2, TPat);
      temp = fabs(temp);
    else
      temp = 1.0 - 2.0 * Noise (tv2, TPat);
      temp = fabs(temp);
      if (temp>0.5) temp=0.5;
    noise += temp / freq;
  return(noise);
static DBL waves_pattern (VECTOR EPoint, TPATTERN *TPat)
  register unsigned int i;
  register DBL length, index;
  DBL scalar = 0.0;
  VECTOR point;
  for (i = 0 ; i < Number_Of_Waves ; i++)
    VSub (point, EPoint, Wave_Sources[i]);
    VLength (length, point);
    if (length == 0.0)
      length = 1.0;
    index = length * TPat->Frequency * frequency[i] + TPat->Phase;
    scalar += cycloidal(index)/frequency[i];
  scalar = 0.2*(2.5+(scalar / (DBL)Number_Of_Waves));
  return(scalar);
Looks to me like waves doesn't use the noise_generator. I wouldn't
testify in court because I didn't go through the whole code and
I'm not exactly an expert at C/C++, but from that code, and the
description in the manual, I'd say, waves doesn't use the noise
generator.
Now what about turbulence? The documentation doesn't tell me
whether it depends on noise_generator. But the source does:
DBL Turbulence(VECTOR EPoint,TURB *Turb,TPATTERN *TPat)
  int i;
  DBL Lambda, Omega, l, o, value;
  VECTOR temp;
  int Octaves=Turb->Octaves;
  int noise_generator = 0;
  if (TPat != NULL)
  if (noise_generator == 0)
    noise_generator = opts.Noise_Generator;
  if ((noise_generator>1) && opts.Language_Version >= 350) {
      value = (2.0 * Noise(EPoint, TPat) - 0.5);
      value = min(max(value,0.0),1.0);
        } else {
      value = Noise(EPoint, TPat);
  l = Lambda = Turb->Lambda;
  o = Omega  = Turb->Omega;
  for (i = 2; i <= Octaves; i++)
    VScale(temp,EPoint,l);
      value += o * (2.0 * Noise(temp, TPat) - 0.5);
        } else {
      value += o * Noise(temp, TPat);
    if (i < Octaves)
      l *= Lambda;
      o *= Omega;
  return (value);
So I render the scene without turbulence. Guess what? Marked
difference. You can see for yourself.
http://bur.st/~shevek/test_noturb_mega0.5.png
http://bur.st/~shevek/test_noturb_3.0.png
http://bur.st/~shevek/test_noturb_3.5.png
So the problem is not turbulence, which also means it is not
noise_generator. It is waves, or it is texture_map.
So, render a texture_map using some different pattern than waves,
and compare.
  agate
  texture_map
//  turbulence <10, 10, 0.3>
  scale 0.1
Well, waddayaknow? The images are exactly the same. Problem solved,
there IS SOMETHING DIFFERENT WITH THE WAVES FUNCTION IN POVRAY 3.5.
This is not documented in the manual, which means either the
behaviour is a bug, or the manual has a bug.
http://bur.st/~shevek/test_notwaves_mega0.5.png
http://bur.st/~shevek/test_notwaves_3.0.png
http://bur.st/~shevek/test_notwaves_3.5.png
Simeon
Subject: Re: Bug in waves in 3.5?
Date: 10 Feb 2003 09:25:23
Message: <3e47b653$1@news.povray.org>
I think that has been discussed in your older post:
Yes, there have been changes in the way POV-Ray
calculates textures and their gradients.
No, not all of them are linked to new default noise-
generators.
No, not all of them may be changed to the "old way"
by using the #version directive.
#version is useful only for language (like using
component{...} rather than sphere{Center,Radius,Strengh ...}
in blobs), not for the rendering process itself.
It's like trying to compare Win3.1 with Win98. Its a
NEW version, though its BASED upon the old one.
The NEW stuff alters the OLD stuff. Some doesn't work
anymore, some doesn't work as expected, and some
things are just DIFFERENT.
There is no such thing as a BUG if one version works like
this, and another like that. Its called a CHANGE.
I hope this doesn't sound too rude, but this has been
discussed in your other thread about textures. Just stop
expecting POV 3.5 to behave like 3.1 or some Megapov
version.
And the Documentation only covers the most obvious and
probably most common changes. Why bother to mention every
little facet that has been changed?
Just render your old stuff with POV 3.1 if its that important.
Tim
Tim Nikias
Email: Tim### [at] gmxde
Date: 10 Feb 2003 15:19:49
Message: <3e480965@news.povray.org>
"Not My Real Email Address" <ano### [at] anoncom> wrote in message
news:3e47a659@news.povray.org...
<snip>
Thorough work - IMHO I've never got a scene from 3.1 to render in 3.5
without work, and I just take it for granted that it's going to look a
little different whatever I do.
You might post a short note to docs, but as others have said, the docs main
purpose is to document the sdl (which would include the refs to the noise
generator, but not waves since the change is not part of the sdl).
