POV-Ray : Newsgroups : povray.general : finding points after a transform Server Time
28 Dec 2025 10:49:21 EST (-0500)
  finding points after a transform (Message 1 to 6 of 6)
Subject: finding points after a transform
Date: 6 Feb 2003 15:33:57
Message: <3e42c6b5$1@news.povray.org>
Ok, I have this problem where I have a couple cylinders that get rotated and
moved durring an animation.  What I need to do is find the ends of the
cylinders after the transforms so I can use them as a reference for another
object.  I have no clue where to start on this and I'd appreciate any help.
Thanks in advance,
  Rob
Subject: Re: finding points after a transform
Date: 6 Feb 2003 16:25:03
Message: <web.3e42d27c3d6c529a0c272b50@news.povray.org>
>Thanks in advance,
>  Rob
I had a similar problem stringing some telephone wires on poles that were
randomly moved and rotated in a loop.  Look in the docs: 7.9.2 Vector
functions and macros, look up VRotation & VRotationD.
Worked great for me.
RG
Date: 6 Feb 2003 17:00:12
Message: <3e42daec@news.povray.org>
Nope that won't do it. VRotation and VRotationD return the angle I need the
point.  Allow me to illustrate.
cylinder{
  <0,0,0>,<5,0,0>,1
rotate <0,40+clock*50,0>
I need to know where the ends of the cylinder are after the rotation.
However now that you pointed me tword those functions I can see that vrotate
will help.
Thanks,
  Rob
"gonzo" <rgo### [at] lansetcom> wrote in message
news:web.3e42d27c3d6c529a0c272b50@news.povray.org...
and
another
help.
> >Thanks in advance,
> >  Rob
> RG
Date: 6 Feb 2003 18:12:23
Message: <3e42ebd7@news.povray.org>
  Which angle? Where did you get this impression?
  By the way, the vtransform() macro is a more generic vector transformation.
Date: 6 Feb 2003 23:03:27
Message: <3e43300f$1@news.povray.org>
Perhaps a better solution is
cyl_Transform1=transform{rotate <0,40+clock*50,0>}
cyl_Transform2=transform{translate 5*x  rotate <0,40+clock*50,0>
blahblah}
this is how many people make arm joints, for example....
Date: 10 Feb 2003 21:41:58
Message: <3e4862f6$1@news.povray.org>
VRotation(V1, V2, Axis), VRotationD(V1, V2, Axis).Compute the rotation angle
from V1 to V2 around Axis. Axis should be perpendicular to both V1 and V2.
The output will be in the range between -pi and pi radians or between -180
degrees and 180 degrees if you are using the degree version.
as I said you may have ment VRotate in any case that's what I needed.
vrotate(A,B) Rotate A about origin by B. Given the x,y,z coordinates of a
point in space designated by the vector A, rotate that point about the
origin by an amount specified by the vector B. Rotate it about the x-axis by
an angle specified in degrees by the float value B.x. Similarly B.y and B.z
specify the amount to rotate in degrees about the y-axis and z-axis. The
result is a vector containing the new x,y,z coordinates of the point.
Here's some code that should explain what I needed to do (specifically the
last object the polygon).  However my project actually consisted of 16
cylinders.
#declare Cyl1_End1 = <0,0,0>;
#declare Cyl1_End2 = <5,0,0>;
#declare Cyl1_Location = <2,2,-3>;
#declare Cyl1_Rotation = <0,45 + (45 * clock),0>
#declare Cyl2_End1 = <0,0,0>;
#declare Cyl2_End2 = <5,0,0>;
#declare Cyl2_Location = <1,2,-3>;
#declare Cyl2_Rotation = <0,45 + (30 * clock),0>
cylinder{Cyl1_End1,Cyl1_End2,0.3
texture{pigment{color Red}}
rotate Cyl1_Rotation
translate Cyl1_Location
cylinder{Cyl2_End1,Cyl2_End2,0.3
rotate Cyl2_Rotation
translate Cyl2_Location
#declare Poly_P1 = vrotate(Cyl1_End1,Cyl1_Rotation) + Cyl1_Location;
#declare Poly_P1 = vrotate(Cyl1_End2,Cyl1_Rotation) + Cyl1_Location;
#declare Poly_P1 = vrotate(Cyl2_End2,Cyl2_Rotation) + Cyl2_Location;
#declare Poly_P1 = vrotate(Cyl2_End1,Cyl2_Rotation) + Cyl2_Location;
polygon{
4,Poly_P1,Poly_P2,Poly_P3,Poly_P4
texture{pigment{color White}}
news:3e42ebd7@news.povray.org...
transformation.
x]
Warp -
