![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How do I get an emission media to add to the light of a scene with
radiosity?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> radiosity?
Reading the documentation might help. (Tip: 6.11.11.2.9)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That ain't too difficult (see documentation). But the question for *me* is
how to let radiosity influence scattering media! Does the media test for
light sources or photons only?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" <war### [at] tag povray org> wrote in message news:3e26893d@news.povray.org...
> > radiosity?
I've tended to find that you need to set brightness > 1 to get any visible
effect. Here's the scene I played with:
#version 3.5;
global_settings {
assumed_gamma 1.0
ambient_light 0
radiosity{
pretrace_start 0.08
pretrace_end 0.04
count 200
media true
brightness 2
location <0.0, 0.0, -5.0>
look_at <0.0, 0.0, 0.0>
box{-6,6 inverse pigment{White}}
plane{y,-1 pigment{checker pigment{Gray}, pigment{White}}}
sphere{
0,1
pigment{rgbf 1}
hollow
interior{
media{
density{agate}
density{spherical}
emission <1.0,0.5,1.0>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3e269168$1@news.povray.org...
scratch that - the posted scene works with brightness 1. I think I managed to
make the floor semi-transparent on initial tests.
That said, emission media appears to be treated as a brightly lit object, rather
than an emitting object, so the effect is not very strong without a higher
brightness (which presumably might screw up other elements of the scene if you
have additional normal light sources).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Knowing how radiosity and scattering media works, I would suppose that
that would be really, really, really extremely incredibly astonishingly
slow.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does any one of a good way to make emission add more light to the scene with
out washing out the shadows with an over bright radiosity?
news:3e269552$1@news.povray.org...
visible
to
rather
you
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
with
You could try increasing the media density (which will increase the
brightness), save the rad data, and then load the rad data with the density
reduced to normal.
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What to think about saving radiosity samples on other locations in 3d space
than just on the surface of objects?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A much better solution which I was thinking of for a while would be to
scrap the radiosity system and do radiosity calculations using photon
mapping. Photon mapping was originally meant to be a full global
illumination model afterall.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
