POV-Ray : Newsgroups : povray.general : media & radiosity? Server Time
3 Mar 2026 18:05:04 EST (-0500)
  media & radiosity? (Message 1 to 10 of 11)
Subject: media & radiosity?
Date: 16 Jan 2003 00:19:08
Message: <3e2640cc@news.povray.org>
How do I get an emission media to add to the light of a scene with
radiosity?
Subject: Re: media & radiosity?
Date: 16 Jan 2003 05:28:13
Message: <3e26893d@news.povray.org>
> radiosity?
  Reading the documentation might help. (Tip: 6.11.11.2.9)
Date: 16 Jan 2003 05:35:50
Message: <3e268b06@news.povray.org>
That ain't too difficult (see documentation). But the question for *me* is
how to let radiosity influence scattering media! Does the media test for
light sources or photons only?
Date: 16 Jan 2003 06:03:04
Message: <3e269168$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e26893d@news.povray.org...
> > radiosity?
I've tended to find that you need to set brightness > 1 to get any visible
effect. Here's the scene I played with:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  ambient_light 0
  radiosity{
    pretrace_start 0.08
    pretrace_end   0.04
    count 200
    media true
    brightness 2
  location  <0.0, 0.0, -5.0>
  look_at   <0.0, 0.0,  0.0>
box{-6,6 inverse pigment{White}}
plane{y,-1 pigment{checker pigment{Gray}, pigment{White}}}
sphere{
  0,1
  pigment{rgbf 1}
  hollow
  interior{
    media{
      density{agate}
      density{spherical}
      emission <1.0,0.5,1.0>
Date: 16 Jan 2003 06:19:46
Message: <3e269552$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3e269168$1@news.povray.org...
scratch that - the posted scene works with brightness 1. I think I managed to
make the floor semi-transparent on initial tests.
That said, emission media appears to be treated as a brightly lit object, rather
than an emitting object, so the effect is not very strong without a higher
brightness (which presumably might screw up other elements of the scene if you
have additional normal light sources).
Date: 16 Jan 2003 06:41:03
Message: <3e269a4f@news.povray.org>
  Knowing how radiosity and scattering media works, I would suppose that
that would be really, really, really extremely incredibly astonishingly
slow.
Date: 16 Jan 2003 10:20:03
Message: <3e26cda3@news.povray.org>
Does any one of a good way to make emission add more light to the scene with
out washing out the shadows with an over bright radiosity?
news:3e269552$1@news.povray.org...
visible
to
rather
you
Date: 16 Jan 2003 10:45:44
Message: <3e26d3a8$4@news.povray.org>
with
You could try increasing the media density (which will increase the
brightness), save the rad data, and then load the rad data with the density
reduced to normal.
 - Slime
[ http://www.slimeland.com/ ]
Date: 16 Jan 2003 17:46:23
Message: <3e27363f@news.povray.org>
What to think about saving radiosity samples on other locations in 3d space
than just on the surface of objects?
Date: 3 Feb 2003 16:36:35
Message: <ikro1nn8bt17$.9f9rjaotlhgo.dlg@40tude.net>
A much better solution which I was thinking of for a while would be to
scrap the radiosity system and do radiosity calculations using photon
mapping. Photon mapping was originally meant to be a full global
illumination model afterall.
