POV-Ray : Newsgroups : povray.general : I give up... Server Time
22 Mar 2026 15:26:05 EDT (-0400)
  I give up... (Message 1 to 5 of 5)
Subject: I give up...
Date: 15 Jan 2003 03:14:54
Message: <3e25187e@news.povray.org>
Why isn't this working?
The correct behaviour should be an animation where
the ship spins 360 degrees(10 degrees per frame). Once
it has completed 1 rotation it moves away from the camera
and spins again.
The ship spins just fine but I can't get it to move away from
the camera.
#declare NumColumns = 24;
#declare Columns = 0;
#declare NumRows = 36;
#declare Rows = 0;
#while(Columns < NumColumns)
         #while(Rows < NumRows)
            #declare T = Columns *40;
            object {ship rotate clock*z*360
                         translate < 0, T, T> }
            #declare Rows = Rows + 1;
     #declare Columns = Columns + 1;
Phil
Subject: Re: I give up...
Date: 15 Jan 2003 03:17:28
Message: <3e251918@news.povray.org>
I should probably mention that the camera is
rotated at x*-45 which is why "T" is in both
y and z .
Phil
Date: 15 Jan 2003 05:58:37
Message: <pan.2003.01.15.10.58.35.607177@internode.on.net>
> The correct behaviour should be an animation where the ship spins 360
> degrees(10 degrees per frame). Once it has completed 1 rotation it moves
> away from the camera and spins again.
> The ship spins just fine but I can't get it to move away from the camera.
> #declare Rows = 0;
>          #end
> #end
Rows has to be reinitialised to 0 inside the Columns loop.
The second time through the Columns loop Rows still has the value NumRows,
so the Rows loop will not be executed.
         #declare Rows = 0;
I believe that keeping the initialiser close to the #while loop makes it
clearer.  I usually do it as
#declare N = 0; #while( N < Limit)
    #declare N=N+1; #end
so that it looks more like a for() loop
Cheers,
PoD.
Date: 15 Jan 2003 08:49:12
Message: <3e2566d8@news.povray.org>
This might be of some help:
http://iki.fi/warp/povQandT/whileloops.html
Date: 15 Jan 2003 16:58:35
Message: <3e25d98b@news.povray.org>
Thanks guys.
I was doing it all wrong. I was creating a bunch
of ships when I only wanted 1, like this...
#declare T = floor(clock)*2;
             translate < 0,T, T> }
As usual I was trying to use way more code than I
needed. What's more, I found the function I was
looking for(in Game Maker image_scale)so I wont
need to use this anyhow. It figures.
Phil
