POV-Ray : Newsgroups : povray.general : Scattering media on a white background? Server Time
28 Dec 2025 19:29:04 EST (-0500)
  Scattering media on a white background? (Message 1 to 8 of 8)
Subject: Scattering media on a white background?
Date: 11 Nov 2002 11:37:35
Message: <3dcfdccf@news.povray.org>
Is there a combination of settings which makes this possible?
 -Shay
Subject: Re: Scattering media on a white background?
Date: 11 Nov 2002 12:24:18
Message: <Xns92C3BC15D86CCseed7@povray.org>
play with the extinction value or ad some absorbing media.
Ingo
Date: 11 Nov 2002 12:29:29
Message: <chrishuff-A6C486.12291411112002@netplex.aussie.org>
In article <3dcfdccf@news.povray.org>, "Shay" <sah### [at] simcopartscom>
Yes.
http://tag.povray.org/
Date: 11 Nov 2002 12:34:00
Message: <chrishuff-CF9C15.12334511112002@netplex.aussie.org>
In article <chr### [at] netplexaussieorg>,
 Christopher James Huff <chr### [at] maccom> wrote:
> Yes.
Scattering media works fine on a white background. You need to give more
information about what you are doing to get a more detailed answer. You
do need a non-0 value for extinction, maybe you set it to 0 for some
reason. Or were you intending to ask about emitting media? In that case,
add an absorbing media with a gray color or 1 - the emission color.
Date: 11 Nov 2002 14:45:25
Message: <3dd008d5$1@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
What I am trying to do is give the appearance of light emanating from the
center of a partially covered sphere. What I have now is my continent model
from the last IRTC round in a group with a light source to light it from the
outside. I then have a second light source in the center of the globe and a
spherical media container filled with scattering media.
The effect of light being filtered by the continent model is perfect on a
black background, but I have not been able to make the scattering visible on
a white background. I am trying to make a quick picture for a holiday card,
so I'm looking for any help with getting this project over as quickly as
possible.
Thank you,
-Shay
Date: 11 Nov 2002 15:27:48
Message: <aj40tu8q8v3thkvjdoivmvqe9g8t18e6e2@4ax.com>
On Mon, 11 Nov 2002 12:33:45 -0500, Christopher James Huff
No, that's not true. The absorbed color should be the opposite in hue,
but the same in brightness as the emitted one. Your suggestion would
add less absorption for brighter emission and vice versa, which is not
what is generally wanted.
There, we're even now :)
Peter Popov ICQ : 15002700
Date: 11 Nov 2002 16:04:14
Message: <chrishuff-A702A5.16035811112002@netplex.aussie.org>
In article <aj40tu8q8v3thkvjdoivmvqe9g8t18e6e2@4ax.com>,
There isn't really a "right" and "wrong" way...just rules of thumb that
usually work. "Hue" is an artificial way of specifying an attribute of
colors, there is no physical reason for emitting gasses to absorb light
of the opposite hue. The colors being absorbed don't always match the
color being emitted.
Actually, there is a "right" way, but it would require patching POV to
addjust the dynamic range. The beams of light are brighter than the
background, but the background is "white".
Heh, OK...
Date: 11 Nov 2002 16:12:38
Message: <chrishuff-BA7A56.16122311112002@netplex.aussie.org>
In article <3dd008d5$1@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> possible.
The beams are visible because they are brighter, right? Just use a
dimmer background then. You can't get whiter than white. I'm not sure
what you want white beams on a white background to look like...kind of
like a polar bear in a snowstorm. If the beams are colored...well, you
still have them being added to a 100% white background. Absorbing or
extinction will make the beams visible by blocking the background...not
white any more. The dynamic range patches floating around recently might
be able to do what you want, otherwise you will have to post process the
image.
