POV-Ray : Newsgroups : povray.general : The future of POVing Server Time
4 Mar 2026 01:41:18 EST (-0500)
  The future of POVing (Message 1 to 7 of 7)
Subject: The future of POVing
Date: 15 Oct 2002 19:05:33
Message: <3dac9f3d$1@news.povray.org>
I was wondering if it  will ever be (or is it already) to create add-ons for
POV where those users working so hard on patches new features etc. would be
able to just release an add-on or plug-in that POV would load and run rather
than having to modify the existing code and recompile and release the whole
program.  Or do I just not understand the way the program is set-up?  (I
would suspect the latter, but hope the former)
-tgq
Subject: Re: The future of POVing
Date: 15 Oct 2002 22:16:54
Message: <3daccc16$1@news.povray.org>
That would be great, but it is not possible to do in a cross-platform way.
And cross-platform compatibility is one of the fundamental values (so to
speak) of POV.
-Nathan
"TinCanMan" <Tin### [at] hotmailcom> wrote...
for
be
rather
whole
> -tgq
Date: 15 Oct 2002 23:20:42
Message: <3dacdb0a$1@news.povray.org>
>Nathan Kopp" <pov### [at] nkoppmailshellcom> wrote in message
news:3daccc16$1@news.povray.org...
> speak) of POV.
That's too bad I guess.  I have been watching some of the recent fixes and
patches and was hoping that someday there would be a simple way to use these
without having to install full patched versions (or wait for the next issue
of MegaPOV ;) )
-tgq
Date: 15 Oct 2002 23:45:18
Message: <chrishuff-D4D035.23402715102002@netplex.aussie.org>
In article <3dac9f3d$1@news.povray.org>,
Not really. Different processors need different machine code, and
different systems have their own way of loading things like this, so the
plugins would have to be compiled for each system and POV would have to
be modified to load them for each system. It is pretty much impossible
without having to change major parts of the code...though 4.0 might make
this easier, it probably still won't ever be an official feature.
http://tag.povray.org/
Date: 18 Oct 2002 08:49:16
Message: <Xns92AB96800F145raf256com@204.213.191.226>
"TinCanMan" <Tin### [at] hotmailcom> wrote in
news:3dac9f3d$1@news.povray.org
> add-ons for POV where those users working so hard on patches new
Personaly I'm against plugins / addons, BUT instead - it would be great to
make soem official tutorial how to write a path, how to write formal
documentation for it, and to choose some peoples that will merge well-
tested plugins into official releases but more often then today (maybe once
per 2 or 4 weeks)
Date: 18 Oct 2002 09:32:39
Message: <3db00d77$1@news.povray.org>
I guess the problem with patches is, that unless
you try to add something totally new (another
preprocessing step for cloth/particles/whatever,
which then use the standard object, or a new
object altogether), the patches will make changes
to similiar parts of the code, and thus may not work
together. I'm not too sure how easy it is to
add another functionality to preprocessing (like
mentioned cloth/partcles) or postprocessing
(especially if data from image has to be saved, like
depth, surface normals, etc). I'm no programmer
yet, and I've got hardly any experience, but I know
from my Particle-System (written in POV-SDL) that
adding features isn't as easy as one sometimes supposes
it could be.
Tim Nikias
Email: Tim### [at] gmxde
once
> per 2 or 4 weeks)
Date: 18 Oct 2002 09:55:40
Message: <8b30rug2o0lt486tblai50ah86ei87ohbb@4ax.com>
On 18 Oct 2002 08:49:16 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
Rafal, do you know how many aspects POV-Ray source code solves ? How many new
things can be introduced with patches ? And how often they are introduced ?
For example I'm implementing MPEG2 reading into POV. How often new input
format is introduced ? Who would like to write turorial just for me ? Things
are usually implemented once - isosurfaces, motion blur, sphere_sweep, etc.
Nobody have time to spend time to write turorials about such complicated
things becouse it is better to use this time. It is different thing to write
good comments nad theoretical explanation. But that is not a tutorial about
writing patch. Of course there are some common operations when patch is
created like adding keywords to parser. But such tutorials exist.
> how to write formal
Docbook was recently suggested. I'm personally consider such solution.
> per 2 or 4 weeks)
Please show me serious project with _official_ releases every two weeks.
ABX
