POV-Ray : Newsgroups : povray.general : Possible pair of bugs affecting transparency. Server Time
23 Mar 2026 00:49:10 EDT (-0400)
  Possible pair of bugs affecting transparency. (Message 1 to 6 of 6)
Subject: Possible pair of bugs affecting transparency.
Date: 22 Sep 2002 00:18:03
Message: <3d8d447b@news.povray.org>
The code below shows 2 potential bugs affecting transparency.
These have been observed on 3.1 (using material_map) and 3.5, at least on a
Windows version, running XP.
The first bug makes the transparent part visible. It's apparently linked
with fog turbulence.
The second bug makes the normals behind look weird when the transparency
texture is scaled very unevenly (pure 100% transparent texture is not
affected).
Can other people confirm that these problems exist and that they are really
bugs (they were reported by a Moray/POV-Ray 3.1 user)?
camera {location  -z*35}
light_source {(x+y-z)*50 rgb 1}
fog {
  fog_type   1
  distance   30
  color      rgb 1
// turbulence makes the transparent part visible
  turbulence 0.8
sphere{0,8 pigment{rgb x+y} normal{bumps 1}}
union{
    triangle{-x,-x+y,x+y}
    triangle{-x,x,x+y}
    hollow
    texture{
        pigment_pattern{
            bozo color_map{[0.4 rgb 1][0.4 rgb 0]}
        texture_map{
            [0.5 pigment{rgb x} finish{ambient 0 diffuse 1}]
            [0.5 pigment{rgbt 1} finish{ambient 0 diffuse 0}]
// uneven scaling makes the normals behind look weird
        scale <1,1,0.001>
    scale 2
    translate -z*20
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: Re: Possible pair of bugs affecting transparency.
Date: 22 Sep 2002 03:54:33
Message: <3d8d7739@news.povray.org>
I can confirm both bugs. Windows XP &  pov3.5
Mick
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3d8d447b@news.povray.org...
a
> affected).
really
> fog {
>   fog_type   1
>   distance   30
>   color      rgb 1
>   turbulence 0.8
> union{
>     triangle{-x,x,x+y}
>     hollow
>     texture{
>         pigment_pattern{
>         texture_map{
>         scale <1,1,0.001>
>     scale 2
>     translate -z*20
> - POV-Ray and Poser computer images
> - Posters
Date: 22 Sep 2002 06:30:35
Message: <3D8D9CEB.D3830FD5@pacbell.net>
This has been a known limitation of fog and transparent objects for many years.
It came up several times during the beta of 3.5 and I seem to recall the
general consensus and official response was that media should be used instead.
Ken Tyler
Date: 22 Sep 2002 09:11:01
Message: <3d8dc165@news.povray.org>
3D8D9CEB.D3830FD5@pacbell.net...
years.
instead.
Well thanks, the first bug rang a (dim) bell.
Does the second one deserve a formal bug report ?
It's less a problem than the first one but it's really weird anyway. I
scratched my head for hours figuring it out (the initial problem was
submitted by an user, not by me, so I have to tell him something).
G.
- Posters
Date: 22 Sep 2002 11:57:34
Message: <chrishuff-CFF1C4.11553722092002@netplex.aussie.org>
In article <3d8d447b@news.povray.org>,
It isn't a bug, just a limitation of fog. Fog is really a cheat, it uses
the distance along the ray to figure out how much fog it goes through
assuming constant or gradient fog, and then uses turbulence with the
intersection point scaled by the turbulence amount and some other tricks
to mess with the real fog value. The result is nothing like real fog,
but usually looks good and is fast to compute.
"Fixing" this would require making fog into a more limited media, if you
need accurate results in this kind of situation just use scattering
media.
> affected).
I haven't had a chance to render this, but it seems very unlikely that
there is some problem with scaling of normals, or even scaling of normal
patterns. Maybe there is a problem with the ray directions not being
normalized for some reason...
http://tag.povray.org/
Date: 22 Sep 2002 12:44:55
Message: <3d8df386@news.povray.org>
  This could be a good proverb for CG: "Don't expect a trick to work like
the real thing." :)
