POV-Ray : Newsgroups : povray.general : Distributed Rendering program (continued) Server Time
19 Sep 2025 23:01:38 EDT (-0400)
  Distributed Rendering program (continued) (Message 1 to 8 of 8)
Subject: Distributed Rendering program (continued)
Date: 14 Sep 2002 08:16:43
Message: <3d8328ab$1@news.povray.org>
Hey Cristoph,
    Yes, I've taken your previous comments to heart. While the Master is a
GUI Windows program, the slaves could be ported to any platform, since they
are command-line programs and communicate with the Master via a TCP
protocol. That way, you would only need one Windows machine for the entire
render farm, and it wouldn't need to be a particularly powerful or expensive
machine. Also I am coding in 48-bit support from the start :) And yes,
automating a 2-pass render is definitely a goal of mine. I know that if you
use always_sample off that you need higher quality settings and other
techniques to make up for the loss, but how do scenes *rely* on data
gathered during the final trace?
Also, thanks Peter for the link!
Thanks,
George Pantazopoulos
Subject: Re: Distributed Rendering program (continued)
Date: 14 Sep 2002 09:10:04
Message: <3D83352B.6320A851@gmx.de>
George Pantazopoulos wrote:
> Hey Cristoph,
> machine.
If you make the communication program platform independent i don't
understand why you need a platform specific master.  The GUI should be
purely optional anyway.  And if you want the system to be universally
usable you should probably test it on different machines during
development - especially network communication is a critical part in that
concern.
If you don't have access to a unix machine to test simply try compiling it
with cygwin. - if it works there is a good chance it will do so on other
systems as well (assuming you are taking care of things like byte order
etc.).
Changing the settings does not compensate the lack of possibility to take
samples during final trace.  If you use a minimum pretrace_end this will
help a lot but there are still samples taken during the final trace in
many cases.
After all radiosity simply isn't possible to be distributed on many
computers perfectly, but the best solution will be to share the data
gathered on the individual nodes like it is done in PVMegapov.  This will
of course create extra network traffic and will not work without modifying
POV-Ray.
Date: 14 Sep 2002 09:33:30
Message: <3d833aaa@news.povray.org>
Christoph,
    My original goal was to make an ultra-user friendly program with a
realtime render display, and also to learn MFC , hence the GUI. :) However,
now that you mentioned it, it would not be hard at all to also make a
commandline-only version of the Master as well. All the render control code
will be encapsulated into a RenderController class, so it wont matter
whether a GUI or a command-line is feeding it. Also, thanks for the cygwin
suggestion, as I do not use unix or have any unix/linux machines handy. As
far as radiosity goes, I will be looking into the PVMegaPov approach.
However is it really necessary to modify POV-Ray? What if the radiosity file
(from save_file) generated by each slave is harvested by the Master after
each tile is done and appended to the master copy of the octree (with
updates sent to each slave whenever a change to the octree is made) ?
Thanks for the insight, keep it coming :)
> > Hey Cristoph,
a
they
entire
expensive
> > machine.
> concern.
> etc.).
you
> many cases.
> POV-Ray.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Date: 14 Sep 2002 10:27:27
Message: <3d83474f@news.povray.org>
I vote for the
"ultra-user friendly program with a  realtime render display"
Look forward to seeing that.
D.
code
file
> > > Hey Cristoph,
is
> a
> they
> entire
> expensive
> > > machine.
that
> > concern.
it
> > etc.).
if
> you
take
> > many cases.
will
modifying
> > POV-Ray.
> > Christoph
Date: 15 Sep 2002 09:47:14
Message: <3d848f62$1@news.povray.org>
Hey thanks for the vote of confidence Dennis :) Anything else you'd like to
see?
George
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3d83474f@news.povray.org...
> I vote for the
> D.
> code
cygwin
As
> file
after
> > > > Hey Cristoph,
Master
> is
> > a
since
> > they
> > entire
> > expensive
> > > > machine.
> that
> > > concern.
compiling
> it
other
order
> > > etc.).
> if
> > you
other
> take
will
> > > many cases.
> will
> modifying
> > > POV-Ray.
> > > Christoph
Date: 17 Sep 2002 03:58:29
Message: <3d86e0a5$1@news.povray.org>
I find very interesting all the work in progress on the use of POVray in
distributed rendering.
There is really good work already done, by the people of pvmpov and
pvmmegapov for example,
but it looks like this can be the field for an important development for the
future.
I wish to thank all the people involved in the development of distributed
rendering solutions for POV.
Subject: Must 3.5 be changed
Date: 20 Sep 2002 06:03:11
Message: <3d8af25f@news.povray.org>
I would also prefer a Version that works with a standard POV 3.5, as I would
like to be able to exchange
my pic's etc. with the community and have the same results..
After reading above I have doubt if there is even a theoretical
chance to make radiosity work on "tiled rendering" without modifying the 3.5
code.
What do the experts say ?
Did I hear some subtones saying that  the calculation diffrences on
mathematics/CPU's/OS'es
may eventually influence the result in (only/not only ?) radiosity so that
the tiles would not fit perfectly together IF they are not rendered on the
same platform ?
I'd prefer if there would be something "builtin" in the next POV-version
that would enable to
make "tiling" possible and maybe some support from the normal POV-Shell ?
In the easiest form that would be the possibility to start two processes,
telling each which part of the pic to render. (= simple SMP Support).
--Theo
Distributed Network-Rendering or Local SMP-Rendering on all CPU's you have.
With SMPOV und POV-Ray 3.5. Download free at:
http://www.it-berater.org/smpov.htm
Subject: Re: Must 3.5 be changed
Date: 21 Sep 2002 14:51:33
Message: <chrishuff-09B3A1.14492821092002@netplex.aussie.org>
In article <3d8af25f@news.povray.org>,
> mathematics/CPU's/OS'es may eventually influence the result in
> (only/not only ?) radiosity so that the tiles would not fit perfectly
> together IF they are not rendered on the same platform ?
The platform doesn't really matter...the tiles won't match up even if
you render them on identical machines. A different portion of the scene
is rendered for each tile, so the pseudo-random samples will be
different, giving slightly different shading for each tile. It is likely
that the only way to avoid artifacts is to ensure that enough data is
computed before the render starts...but then, I don't know how POV
handles adding additional data during rendering in the current
single-threaded version. Radiosity is the only thing that causes this
problem, but there are other things that could cause similar problems in
the future...some kind of optimized reflection blur, for example. Maybe
photons with jitter would also be a problem.
You could overlap the tile edges and interpolate to smooth out the
transitions, "over-rendering" the image. This would probably make the
artifacts invisible in most cases without processing to find them, but
is less efficient. However, it could be done with the current version +
some clever scripts and a program to merge the tiles together.
> POV-version that would enable to make "tiling" possible and maybe
If it was that easy, don't you think it would have been done already?
http://tag.povray.org/
