POV-Ray : Newsgroups : povray.general : Generating a mesh from points...? Server Time
23 Mar 2026 04:10:22 EDT (-0400)
  Generating a mesh from points...? (Message 1 to 10 of 12)
Subject: Generating a mesh from points...?
Date: 31 Aug 2002 11:37:59
Message: <3d70e2d7$1@news.povray.org>
I've implemented an electrostatic repulsion algorithm
in order to distribute points on a sphere.
Now I'd like to know how can easily convert the
points into a mesh which has only triangles on the
outside surface.
I'd like it to work by selecting three closest points, make
triangle, and then move on, creating triangles as need,
until the entire area is covered.
I could go about and simply connect all combinations of
three points, but this is insane for point-amounts well
above 200 (at the moment 500).
Any links?
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Generating a mesh from points...?
Date: 31 Aug 2002 12:06:17
Message: <3d70e979@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3d70e2d7$1@news.povray.org...
> outside surface.
    Hmm... You probably can't adapt your algorithm to do this, but if you
had a springy force between the points you could start with them linked up
into triangles and then allow them self organise over the sphere surface...
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 31 Aug 2002 12:07:17
Message: <3D70EA38.8050206@compuserve.de>
> Any links?
http://news.povray.org/povray.newusers/22081/
Be aware of some problems... it is not so easy as it seems, and I have
not succeeded in the given time. Maybe I will try later again, but at
the moment I have absolutely no time :-(. I'm looking forward for your
results ;-).
Florian Pesth
Date: 1 Sep 2002 15:36:03
Message: <3D726BFD.9C126391@hotmail.com>
> outside surface.
Brute force is an O(n^3) problem, so I can see how you'd want to
avoid that...
You could build three sets of indices, each of which sorts the points
according to the x, y, and z coordinates; then match only those that are
within a certain range along all three indices.
John
Date: 2 Sep 2002 01:50:17
Message: <3d72fc19$1@news.povray.org>
> Any links?
No links, but I can see a fairly straightforward way to accomplish this.
Three closest points *will not* work. No amount of time will ever make it
work, so patience isn't even an issue. Point B may be the closest point to
Point A, but Point A is not *necessarily* the closest point to PointB. Here
is an example:
A=========B==C
This is how I would accomplish what you are trying to. I don't know any
math, so I hope that I can communicate what I mean with words. Make a circle
around each point which is a little larger than half the maximum distance
around the closest points and make a polygons out of the circle
intersections. Then, make a polygon around any vertex for which the circle
method did not work out of all surrounding intersections or vertices.
Triangulate the polygons, and then you will be done, but with extra
triangles.
I had a better idea while I was typing the first. Just add planes making
sure all vertices are on one side of the plane until all vertices are
included and then  figure out the  plane intersections.
I haven't tested this, but it seems to make sense as I type.
 -Shay
Date: 2 Sep 2002 07:23:43
Message: <3d734a3f@news.povray.org>
  By the way, that's far from trivial.
Date: 2 Sep 2002 10:11:22
Message: <3d73718a$1@news.povray.org>
Hmmm, forces ?
That makes me thinking about blobs...
Maybe a way to solve your problem ?
Regards
 L.H.
> outside surface.
> Any links?
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 2 Sep 2002 13:35:08
Message: <3d73a14c$1@news.povray.org>
news:3d734a3f@news.povray.org...
I never said trivial. <g> Since all of the points lie on a sphere, however,
triangulating them would be pretty straightforward.
 -Shay
Date: 2 Sep 2002 15:31:31
Message: <3d73bc91@news.povray.org>
From what I understand your problem the "convex hull" of the points is what
you are looking for. The convex hull is the smallest surface of set of
triangles that contains all of the points in its interior (probably a bad
description). This is the set of triangles that you are looking for. It can
be created in O(n log n) (where n is the number of points). I cannot give
you a detailed algortihm for that right now as I only know it for 2D. But
searching for "convex hull 3d" in google gives plenty of results.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 2 Sep 2002 16:50:18
Message: <3d73cf0a$1@news.povray.org>
  You'll have to explain that in more detail before I believe it. :)
