POV-Ray : Newsgroups : povray.general : Smooth triangles? Server Time
20 Sep 2025 06:20:06 EDT (-0400)
  Smooth triangles? (Message 1 to 7 of 7)
Subject: Smooth triangles?
Date: 25 Aug 2002 14:21:45
Message: <3d692039@news.povray.org>
Hi
A few days ago I posted a thread about making a spiral, and decided to make
a to write a smooth_triangle mesh. The problem is it ain't smooth. As I
understand it, the normal vectors are just directional and their magnitude
doesn't matter (is this assumption correct?) so <0,1,0> has the same value
in terms of normals as <0,10,0>?
thanks
jim
Subject: Re: Smooth triangles?
Date: 25 Aug 2002 17:29:05
Message: <chrishuff-3002C1.17290325082002@netplex.aussie.org>
In article <3d692039@news.povray.org>,
I'm not sure, it is possible the magnitude affects the weighting of the
normals when they are interpolated across the triangle. Try normalizing
the normal vectors you specify.
http://tag.povray.org/
Date: 26 Aug 2002 13:33:06
Message: <3d6a6652$1@news.povray.org>
I don't know about the weighting, but the surface-vectors should
be one-unit in size. POV doesn't normalize them internally, and in
my experience, using other than unit-sized vector lead to strange
looking surfaces...
Tim Nikias
Email: Tim### [at] gmxde
Date: 26 Aug 2002 15:57:42
Message: <3d6a8836@news.povray.org>
> looking surfaces...
  Can you demonstrate this with a small example?
Date: 27 Aug 2002 00:53:30
Message: <3d6b05ca@news.povray.org>
Hm. I played around, and it seems that it doesn't
matter. I'll play around more when I've got more time,
I'll come back later...
Tim Nikias
Date: 28 Aug 2002 08:39:20
Message: <3d6cc478@news.povray.org>
Seems that it doesn't matter. I thought of some problems
about a year ago which I had when having a go on meshes,
but I guess that had to do with the way I calculated the
normals (pointing in weird directions), rather than the length
of the vectors...
Still, I think it would be best to keep uniform-vectors as surface
vectors. If you'd use subdivision-macros you'll see where
problems could arise... In the truest meaning of sense...
Tim Nikias
Date: 28 Aug 2002 17:50:17
Message: <3d6d4599@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3d6cc478@news.povray.org...
> of the vectors...
this is the funny thing, I -know- the normals are correct, I 've drawn them
in using cylinders, but I still see the triangles. for the moment I've given
up on figuring it out and gone for the brute force method - increase the
number of triangles 'til you can't see them.
jim
