POV-Ray : Newsgroups : povray.general : Spirals with rectangular cross section Server Time
4 Mar 2026 08:37:00 EST (-0500)
  Spirals with rectangular cross section (Message 1 to 6 of 6)
Subject: Spirals with rectangular cross section
Date: 22 Aug 2002 07:50:53
Message: <3d64d01d@news.povray.org>
Hi all,
Whats the easiest way of making a spiral which follows the surface of a
cylinder. The only way I can see is to sweep lots of boxes through the
spiral. ie like a sphere_sweep but with a rectangular cross section.
Thanks
jim
-is there an isosurface solution? - although I have a slow computer and the
scene will be rendered with radiosity which may make the render time
unacceptably long :(
Subject: Re: Spirals with rectangular cross section
Date: 22 Aug 2002 08:17:05
Message: <6dl9mu432ntkq8udmvkhfapmn3r7dis4qg@4ax.com>
On Thu, 22 Aug 2002 12:50:11 +0100, "James Taylor"
A mesh would be the easiest and fastest solution. You can make this
loft either in Rhino (download the demo) or with the Striscia (or
whatever what it was called :) ) macro. Ken should have the links to
both in the links section.
Peter Popov ICQ : 15002700
Date: 22 Aug 2002 09:43:46
Message: <3d64ea92@news.povray.org>
James Taylor <jim### [at] blueyondercouk> wrote in message
news:3d64d01d@news.povray.org...
> cylinder.
You could code this in a few minutes by placing mesh vertices with loops. It
would be even easier to make a macro which builds the object pointing
straight up in the y direction and then rotating the spiral into the
orientation you desire. Easier yet would be to code the square spiral as a
union of four different meshes. This is inelegant, but would make adding
textures and normals simpler.
Instead of rotating a square to form your spiral, consider rotating a
spline. This would allow for many different and interesting shapes of
spirals. A four point linear spline would also easily produce the square
spiral you mentioned. The uv mapping would be straight forward, so you could
twist your textures as well.
 -Shay
Date: 22 Aug 2002 10:55:34
Message: <3d64fb66$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3d64ea92@news.povray.org...
could
ahh, it seems so simple now ;)
there's even a spline extrusion macro on oyanale.com if I remember correctly
thanks
jim
Date: 22 Aug 2002 11:47:07
Message: <3d65077b@news.povray.org>
"James Taylor" <jim### [at] blueyondercouk> schrieb im Newsbeitrag
the
I don't know exactly, what you want, but have a look at f_helix1() in
functions.inc. Perhaps f_helix2() will save you the need of an extra
cylinder in the middle. IMO, those functions don't render to slow, but I
might be used to it already.
Marc-Hendrik
Date: 22 Aug 2002 13:53:29
Message: <dAqMdDAIRSZ9EwGg@econym.demon.co.uk>
Wasn't it James Taylor who wrote:
>Hi all,
>Thanks
>jim
Set the "cross section type" parameter of the f_helix1() function to 2
(diamond shape) and then set the cross section rotation angle to 45.
(They're the last two parameters of f_helix1().)
For example:-
#include "functions.inc"
camera { location  <0, 2, -2> look_at 0}
background {rgb 1}
light_source {<-10,20,-10> colour rgb 1}
isosurface {
  function { f_helix1(x,y,z,2,5,0.1,0.3,3,2,45) }
  max_gradient 1.5
  contained_by{box {<-0.4,-2,-0.4> <0.4,1,0.4>}}
  pigment {rgb 1}
