POV-Ray : Newsgroups : povray.general : Is it possible to move a torus? Server Time
10 Sep 2025 06:44:38 EDT (-0400)
  Is it possible to move a torus? (Message 1 to 10 of 12)
Subject: Is it possible to move a torus?
Date: 1 Aug 2002 22:17:51
Message: <3d49ebcf$1@news.povray.org>
I want to specify the coordinates for a torus other than the origin.  Is
this possible, and if so, how can I do it?
Subject: Re: Is it possible to move a torus?
Date: 1 Aug 2002 23:13:54
Message: <3d49f8f2@news.povray.org>
"Vash" <gra### [at] telusplanetnet> wrote in message
news:3d49ebcf$1@news.povray.org...
Wow, that sure is a povray.newusers group question if I ever saw one!
I'm just teasing. I'm going to answer like I'm talking to a child, if I can,
anyhow.
Since the torus wants to begin at the origin, <0,0,0>, you need to add a
'translate' vector or axis. Only a size is given to begin with, but not a
location vector as is with sphere and many other primitives.
Order of things put in are typically done like:
torus {
    WheelSize, // main width in units
    TireSize // secondary width in units
scale <1,1,1> // initial resize and/or reshape
 rotate <360,360,360> // initial turning
  translate <1,2,3> // intial position
// (numbers can be whatever you want).
In this way you can resize then spin it around and finally place it. Of
course, other orders of the "transformations" (scale, rotate, translate) are
possible but this is how to manipulate the torus in the basic way.
Date: 1 Aug 2002 23:48:10
Message: <chrishuff-2FEBF4.22392001082002@netplex.aussie.org>
In article <3d49ebcf$1@news.povray.org>,
Look up the "translate" transform:
torus {1, 0.2
    ...textures, etc...
    translate NEW_CENTER_POSITION
Date: 2 Aug 2002 12:28:36
Message: <3D4AB315.5D76F0DE@aol.com>
The other option, of course, would to be to write a macro called Torus that
lets you supply the start coordinates (yes, I know expressed as a
translation), and normal axis (a rotation), as well as the inner and outer
radii. Something like: Torus(Maj_Rad, Min_Rad, Location, Normal). As part of
an included file, this would make using torus a bit more intuitive, and in
keeping with the syntax of most other primitives.
Dave
Date: 2 Aug 2002 12:58:37
Message: <3D4ABA1E.533A0C06@aol.com>
This may be a bit much on this subject, but here is some code showing how a
Torus macro might work. I am not happy with having to declare the variables for
the normals outside the macro, but don't have time to really think about it
right now. The cleanest way would be to just remember that normal y is 0, x is 1
and z is 2, but I wanted a clearer version for this example.
camera { location  <0, 1, -10> look_at 0}
light_source {<5,10,-20> White}
// This would go in the include file
#declare Y=0;
#declare X=1;
#declare Z=2;
#macro Torus(Maj,Min,Nor,Loc)
torus {Maj,Min
#switch(Nor)
#case(0)
#break
#case(1)
rotate z*90
#case(2)
rotate x*-90
translate Loc}
//This would go in the scene file
object {Torus(3,.2,Y,<2,2,5>)
pigment {Red}}
Date: 2 Aug 2002 13:16:04
Message: <naflkugv9mcjq9somrc4tlirg5cq4vfgpd@4ax.com>
On Fri, 02 Aug 2002 12:58:06 -0400, Dave Dunn <poi### [at] aolcom> wrote:
> This may be a bit much on this subject, but here is some code showing ...
This could be extended with macro from standard includes to orient torus along
any direction. Don't remember its name ? Check names of all identifiers at
http://www.abx.art.pl/pov/bonus
ABX
Date: 2 Aug 2002 14:09:27
Message: <chrishuff-D3AA17.13001402082002@netplex.aussie.org>
In article <3D4ABA1E.533A0C06@aol.com>, Dave Dunn <poi### [at] aolcom>
> how a Torus macro might work. I am not happy with having to declare
> the variables for the normals outside the macro, but don't have time
> to really think about it right now. The cleanest way would be to just
> remember that normal y is 0, x is 1 and z is 2, but I wanted a
You could have just used x, y, and z, though the logic for finding the
axis would be a bit more complex. Best would be something like this,
which can use any axis (rearranged the parameters to be more consistent
with the built-in shapes):
#include "transforms.inc"
#macro Torus(Center, Axis, MajorRadius, MinorRadius)
    torus {MajorRadius, MinorRadius
        Point_At_Trans(Axis)
        translate Center
The "sturm" flag is a problem...you could either have this macro
generate sturm or non-sturm torii, or you could add another parameter
that will always have to be given because macros don't have default
parameter values. You could just leave out the last } bracket, so the
macro usage would be like:
Torus(< 0, 0, 0>, < 1, 2, 3>, 1, 0.2)
    sturm
    texture {...}
This would make it easier for other things, like textures, hollow and
inverse, etc...you wouldn't have to wrap the macro call in an object {}
block. Brackets don't match up though, which may annoy some people.
Date: 2 Aug 2002 14:42:50
Message: <3D4AD28B.126EA1F3@aol.com>
You know, this is almost shaping up like an argument to modify the syntax
of the torus object. You would, of course have to still call the original
version by its name for backwards compatibility, but a torus2 object might
be nice to have. I have always thought that it was odd that torus was the
only primitive that could not be placed without a transformation anywhere
else than at the Origin.
Date: 2 Aug 2002 15:52:52
Message: <chrishuff-332A02.14434002082002@netplex.aussie.org>
In article <3D4AD28B.126EA1F3@aol.com>, Dave Dunn <poi### [at] aolcom>
That would be strange, if it was true:
height_field
julia_fractal
lathe
sor
superellipsoid
text
poly
cubic
quartic
quadric
Date: 2 Aug 2002 15:59:56
Message: <3D4AE49D.5A5093DE@aol.com>
Heh heh. I knew I should have qualified that and said basic primitives, in which
group I include torus. I was thinking, of course, of the following:
sphere
box
cylinder
cone
torus2  ; }
