![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here's the error I've been getting every now and then:
#declare vpmtemp = array[4][vpmS]
# <----ERROR
memory macro:64: error: Attempt to malloc zero size block
(File:TOKENIZE.C Line: 4451).
I have no idea what this means, but it seems to be some kind of a
problem in defining variables when using one macro within another. (?)
The only way I have been able to fix this is by doing this the long way
around and by trial and error since I have no idea what it means! Any
help or suggestions would be greatly appreciated.
- Ricky
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I cannot say for absolute certain without seeing the source code for POVray,
but I know that if vpmS is ever equal to zero, that would likely cause such an
error. "malloc" is the name for the instruction to allocate a block of memory.
When nesting this inside a macro, you may be experiencing a "look-ahead"
problem- the compiler has to evaluate everything before it can get the true
value of vpmS, and it may not do so at a certain nesting depth.
Just a thought, and it seems that I have seen a similar problem discussed
before.
Cheers!
Chip Shults
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <110720021604089456%reu### [at] chorus net> , Reusser
> # <----ERROR
Make sure vpmS is _not_ less or equal to zero!
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3d2f1669$1@news.povray.org>, Thorsten Froehlich
DUMB MISTAKE on my part. I accidentally had the dimension_size
operator looking at the wrong (non-existent) dimension of an array, so
it returned a zero instead. I guess it makes perfect sense now...
Thanks!
- Ricky
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanks!
Of course the error message could be clearer...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
