POV-Ray : Newsgroups : povray.general : Translate by turbulence Server Time
29 Dec 2025 09:22:07 EST (-0500)
  Translate by turbulence (Message 1 to 10 of 16)
Subject: Translate by turbulence
Date: 12 Jul 2002 10:12:53
Message: <3d2ee3e5$1@news.povray.org>
I don't think this is possible in 3.5 but I'll ask anyways (perhaps it'll
give someone an idea for a patch ;) )
This is a bit difficult to explain but:  I want to be able to translate an
object according to the turbulence value at its location.  Let's say we have
a plane with a checker pattern on it and we place a little ball at the
origin.  If we apply turbulence to the checker pattern, the point that was
originally at <0,0,0> is now somewhere else defined by the turbulence
parameters.  I would like to be able to move the sphere to this new
location, something along the lines of:
plane{y 0
     pigment{
       checker rgb 1 rgb 0
       turbulence 0.5
       octaves 5
       lambda 1.2
       omega .25
#declare newpt =
sphere{0 0.1
   pigment{rgb <1,0,0>}
   translate turb_translate(
      <0,0,0> //point to read turbulence value from
      turbulence 0.5
      octaves 5
      lambda 1.2
      omega .25
Does anyone have any idea on how this can be done in 3.5?
-tgq
Subject: Re: Translate by turbulence
Date: 12 Jul 2002 10:19:44
Message: <q2ptiucj8s1rouqpnt4td2ej9mufa0j41m@4ax.com>
On Fri, 12 Jul 2002 10:12:32 -0400, "TinCanMan" <Tin### [at] hotmailcom>
Can you use user defined functions to recreate turbulence behaviour ?
If yes, that's could be solution (using some noise functions additionaly).
ABX
Date: 12 Jul 2002 10:22:46
Message: <3D2EE636.107D3BD6@gmx.de>
Have a look at the 'vturbulence()' function.
Last updated 30 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 12 Jul 2002 10:23:32
Message: <3d2ee664$1@news.povray.org>
Possibly.
How would you get the translation value from the noise function?
-tgq
Date: 12 Jul 2002 10:35:50
Message: <q5qtiucq5q9a7dnt2pthadd6g9sbk4r7t3@4ax.com>
On Fri, 12 Jul 2002 16:22:46 +0200, Christoph Hormann <chr### [at] gmxde>
It can be wrong solution when you want displace geometry instead of vector as
for displacement in isosurfaces.
ABX
Date: 12 Jul 2002 10:36:37
Message: <3d2ee975$1@news.povray.org>
> Christoph
Thanks, but it appears to be the opposite of what I want (if I understand
turbulence properly).  The vector returned by vturbulence() for pt A is the
original vector of the point that is essentially now located at A rather
than where the point that was originally at A is now.
-tgq
Date: 12 Jul 2002 10:37:50
Message: <i8qtiusukna1bkaftjqee1nekhildarvqe@4ax.com>
On Fri, 12 Jul 2002 10:23:11 -0400, "TinCanMan" <Tin### [at] hotmailcom>
> Possibly.
<f_noise(x,y,z),f_noise(y,z,x),f_noise(y,z,x)> ?
ABX
Date: 12 Jul 2002 10:40:34
Message: <3d2eea62$1@news.povray.org>
news:i8qtiusukna1bkaftjqee1nekhildarvqe@4ax.com...
additionaly).
> > Possibly.
> ABX
Hmm, I'll try this out.
After reading more into how turbulence works I don't think there is a simple
solution to this.  Turbulence works by grabbing a value *from* the
turbulated location rather than moving the point *to* a turbulated location.
-tgq
Date: 12 Jul 2002 10:43:47
Message: <ejqtiu85qkheglkr0pucrpsj3p4jdvi3gd@4ax.com>
On Fri, 12 Jul 2002 10:36:16 -0400, "TinCanMan" <Tin### [at] hotmailcom>
I'm affraid it will be the same in my solution. What you are looking for is
bidirectional (reversable) turbulence (noise). I have looked for this kind if
noise at the time when I was working on deform patch. I passed but perhaps you
will find it.
ABX
Date: 12 Jul 2002 10:50:11
Message: <3D2EECA2.BFD1426@gmx.de>
I think TinCanMan only wanted to translate a sphere.
