POV-Ray : Newsgroups : povray.general : Scatter/partcle style macro help Server Time
13 Jan 2026 04:47:32 EST (-0500)
  Scatter/partcle style macro help (Message 1 to 6 of 6)
Subject: Scatter/partcle style macro help
Date: 13 Jun 2002 18:58:45
Message: <3d0923a5@news.povray.org>
Hi all,
In my current WIP I'm trying to place some objects (spheres) onto another
set of objects and I'm not having much success. I've tried JRG's Scatter
macro, but can't get the results I want (but still a kick-ass macro). As far
as I understand the scatter macro searches for three points of contact,
which of course doesn't truly happen for a sphere (without intersection
anyway). So I was thinking that using one of the particle systems (hope I
got the name right - it's the ones with the bouncing balls) to position the
objects and just taking the final frame.
So which one's best (or at least easiest to use)?
thanks in advance
jim
Subject: Re: Scatter/partcle style macro help
Date: 13 Jun 2002 20:47:57
Message: <3d093d3d$1@news.povray.org>
Not sure I understand what you are trying to do,
but it sounds like an ancient utility called SUDS
might do the trick.
http://freespace.virgin.net/r.jennings/suds.htm
HB
"James Taylor" <jim### [at] blueyondercouk> wrote in message
news:3d0923a5@news.povray.org...
> Hi all,
far
the
> thanks in advance
> jim
Date: 14 Jun 2002 02:16:29
Message: <312jgu09ciplov4348vptgplu5u3k58o0l@4ax.com>
On Thu, 13 Jun 2002 23:54:21 +0100, "James Taylor"
<jim### [at] blueyondercouk> wrote:
> Hi all,
Is your set of objects builded with simple primitives like torus, sphere,
cylinder, cone, plane etc ? Then you can use iso_csg library to create
equivalent of this set as function and sample this function for specified
distance. Tell me if you want an example. But since you want place only
spheres you can just use trace function and move intersection about
normal*radius. This simple method was used by me in
http://news.povray.org/kk1f1u0tvda2ul55rclt1or8opfkah6i5j%404ax.com
ABX
Date: 14 Jun 2002 14:46:44
Message: <3d0a3a14$1@news.povray.org>
Definitely NOT the best:
http://www.geocities.com/pterandon/boids.html
Date: 14 Jun 2002 19:37:56
Message: <3d0a7e54@news.povray.org>
"Harold Baize" <bai### [at] itsaucsfedu> wrote in message
news:3d093d3d$1@news.povray.org...
> might do the trick.
I've modelled one of those ball-bearings in a puzzle things and wanted to
use the particle system to drop the balls onto the puzzle, let them roll
around until they came to a stop and use that as my 'still' scene.
Thanks for the link, I'll look into it.
jim
Date: 14 Jun 2002 19:48:44
Message: <3d0a80dc@news.povray.org>
news:312jgu09ciplov4348vptgplu5u3k58o0l@4ax.com...
> > Hi all,
another
> ABX
Thanks for the link - it'll certainly be useful be for future use, but in
this instance, I only needed to place 12 objects and was being lazy (I'm
new(ish) to pov <6 months and didn't want to figure out the
maths+code)...anyway I placed them by hand instead (and now have a self
satisfied glow that I figured it out)
cheers
jim
