POV-Ray : Newsgroups : povray.general : Text Server Time
4 Mar 2026 18:20:47 EST (-0500)
  Text (Message 1 to 10 of 10)
Subject: Text
Date: 23 May 2002 09:20:12
Message: <3cecec8c$1@news.povray.org>
Hello Everyone,
     I'm back again.. Got a quick question, is there a way to Warp text?
    I Want to take a string of text I Created with the
text {} tag, and want it to go around a cylinder..
As I have it now, a part of the text, "hangs" off the edge of the cylinder..
Anyone got any suggestions?
Much appreciated..
Dave
Subject: Re: Text
Date: 23 May 2002 09:31:09
Message: <3cecef1c@news.povray.org>
If the text doesn't have to be a 3D object but it suffices to be a pigment
on the surface of the cylinder, then make an object pattern from the text
and apply the cylindrical warp to it and then use it as pigment on a cylinder.
Subject: Re: Text
Date: 23 May 2002 10:40:56
Message: <3cecff78$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3cecef1c@news.povray.org...
Not that I understand cylindrical warps (never used 'em), but you might be able
to make it 3d using this technique.
Use two nested cylinders, use the object pattern on the outer one, using a
transparent pigment for the non-object areas. Your letters would then be 3d
IMHO.
Subject: Re: Text
Date: 23 May 2002 11:36:02
Message: <3ced0c62$1@news.povray.org>
> using a transparent pigment for the non-object areas. Your letters
> would then be 3d IMHO.
What? No!
The surface of an object never changes no matter what textures you use.
What you suggest would produce some curved 2d letters floating around
the inner cylinder, but without being 3d.
If the shapes of objects depended on their textures, we wouldn't need
isosurfaces! ;)
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Subject: Re: Text
Date: 23 May 2002 11:41:03
Message: <3ced0d8f@news.povray.org>
Rune wrote:
>> pattern on the outer one, using a transparent
> What? No!
Of course I may have misunderstood you. But those letters just won't be
3d... :/
Rune
Subject: Re: Text
Date: 23 May 2002 12:21:10
Message: <3ced16f6$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3ced0c62$1@news.povray.org...
> What? No!
<snip>
Sounds right to me - what was I thinking of? Another beautiful theory slain by
an ugly fact.
Subject: Re: Text
Date: 23 May 2002 12:44:14
Message: <3ced1c5e$1@news.povray.org>
Warp,
    Thanks for the info.. that seemed to work, without the Warp.. :)
    But I have a Word like: Text, the Top of the Uppercase word is clipped,
but the rest is okay.. is there a bounding box for this?  Or do you think I
have to try and rotate it a little?
pigment
cylinder.
M()}}
Warp -
Subject: Re: Text
Date: 23 May 2002 15:53:29
Message: <3ced48b9@news.povray.org>
"Dave Bates [{Norman}]" <dab### [at] msncom> wrote in message
news:3ced1c5e$1@news.povray.org...
> Warp,
clipped,
I
Hard to say without seeing the code, but it sounds as though you need to to
make your text-depth bigger. I suspect that what is happening is that your
text doesn't intersect the cylinder at its upper and lower bounds.
If I understand the principle of warps correctly, Warp's warp would avoid
this (and the distortion of the letters).
Subject: Re: Text
Date: 23 May 2002 16:15:59
Message: <3ced4dff$1@news.povray.org>
to
I think my text intersects.. I can make it deeper I guess..
** Note **
I forgot to send this, but I did try the depth and that worked WONDERS..
thanks alot eveyrone!  This one will be posted here (p.b.i) when I get it
finished.. :)
Subject: Re: Text
Date: 23 May 2002 23:37:04
Message: <3cedb560$1@news.povray.org>
Thanks for all the help guys, I posted my first picture in p.b.i..
Enjoy.. comments welcome..
"Dave Bates {[Norman]}" <dab### [at] msncom> wrote in message
news:3cecec8c$1@news.povray.org...
> Hello Everyone,
cylinder..
> Much appreciated..
> Dave
