POV-Ray : Newsgroups : povray.general : Mesh Interpolation? Server Time
7 Oct 2024 03:13:53 EDT (-0400)
  Mesh Interpolation? (Message 1 to 4 of 4)
Subject: Mesh Interpolation?
Date: 21 May 2002 21:43:31
Message: <3ceaf7c3$1@news.povray.org>
I'm a bit fuzzy on how to transform a list of coordinates into a mesh.  What
would be the easiest way to generate a mesh based on a table of 3D vectors?
Subject: Re: Mesh Interpolation?
Date: 22 May 2002 05:29:46
Message: <3CEB6527.3030602@free.fr>
There is no simple solution, because you've lost the connectivity information.
Best approach is probably to use the 3D coordinates to generate a scalar
field, and then to generate the mesh out of the scalar field.
see http://astronomy.swin.edu.au/~pbourke/modelling/polygonise/
Beware, if you are relevant to USA patent, you should check the marching
cube and other patents before going on.
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Date: 22 May 2002 09:47:18
Message: <3ceba166@news.povray.org>
Thanks, L'Harmonieux, for the information.  I've seen various 3D contour
sofware packages perform some operations on a table of XYZ coordinates, and
produce interpolated mesh results.  For example, SigmaPlot, Surfer for
Windows, etc.  However, they provide no explanation as to their methods.
What if I wanted to 'fake' the connectivity info?  For example, choosing
between linearly connecting all the data points, or some non-linear fit.
Would it still be best to go the route of creating a scalar field?
- How
"L'Harmonieux Forgeron" <jgr### [at] freefr> wrote in message
news:3CE### [at] freefr...
What
vectors?
information.
> Non Sine Numine
Date: 22 May 2002 16:37:16
Message: <3cec017c@news.povray.org>
I've tried this, but didn't have the time to finish. The idea behind my
program was simple to build a small pyramid and then enlarge this pyramid,
adding the best fitting points. But my program lacks some tests and so there
are still some possibilities (for example it doesn't check if the connecting
pyramid hits the existing body). I think with some work it could be usefull,
but my source code (written in C) is very messy and not documented (or only
in German).
But if you want to have a look at it, you're welcome.
Best regards,
Florian
Oh, btw I have posted this problem to povray.newusers some time ago and got
some useful replies, have a look at that thread...
