POV-Ray : Newsgroups : povray.general : Bent text? Server Time
11 Sep 2025 12:55:39 EDT (-0400)
  Bent text? (Message 1 to 10 of 22)
Subject: Bent text?
Date: 14 Feb 2002 08:13:50
Message: <3c6bb80e@news.povray.org>
I would like to model a column with words engraved or carved into or out of
(i.e. protruding from) the column.  I don't know how to create 3D letters
which are curved to match the column, however.
The hard way would be to use Chris Colefax's Bend include file.  Hard in
terms of render time--I have more than one column with unique text.  I would
like to ask if anyone knows of an easier way to accomplish this.
Thanks,
Hershel
Subject: Re: Bent text?
Date: 14 Feb 2002 08:23:56
Message: <3c6bba6c@news.povray.org>
"Hershel Robinson" <her### [at] yahoocom> wrote in message
news:3c6bb80e@news.povray.org...
of
would
    I don't think you can bend the individual letters in any easy way, but
there are ways to parse out the text string and rotate out each letter. Here
is the sample file I copied from somewhere...
background {
    color rgb 1
#declare Rotation = clock + 55;
#declare CText = "SOPHIE'S WORLD  SOPHIE'S WORLD  SOPHIE'S WORLD  "
 location <0, 0, -8>
 direction <0, 0, 1.5>
 look_at <0, 0, 0>
light_source {
 <-1, 1, -12>
 colour rgb <1.3, 1.3, 1.3>
#declare Letter = 1;
union {
 #while (Letter <= strlen (CText))
  text {
   ttf "c:\windows\fonts\courbd.ttf", substr (CText, Letter, 1), 0.1, 0
   translate <0, -0.5, -3>
            scale <0.55, 1.1, 1>
   rotate <0, -360 / strlen (CText) * Letter, 0>
   no_shadow
  #declare Letter = Letter + 1;
   colour rgb 0.9
  finish {
   crand 0.01
 rotate <0, Rotation, 0>
 rotate <15, 0, 20>
Date: 14 Feb 2002 08:30:55
Message: <3c6bbc0f$1@news.povray.org>
Hi Hershel,
I can propose you something that worked for one of my picture, move and
place each letter individualy. It is painfull when writing the scene, but
efficient at rendering. I used the following macro to place each letter. It
can be automated.
//Macro
#macro MDepTexte(Ax)
#declare DepTexte = transform {
        scale 1.5
        rotate 90*z
        translate <0,0,-4>
        rotate Ax * x
        translate <0,0,4>
        translate <-7,-2,-1>}
transform DepTexte
// usage: to write 3 times the word Spheres
#declare Angle = 16;
#declare AngOff = -120;
#declare i =0;
#while (i<3)
// create a TrueType text shape
text
  ttf
  "couri.ttf",
  "S",
  0.5,
  0
  MDepTexte(-3*Angle+AngOff)
  texture { T_Stone27 scale 2 }
text
  ttf
  "couri.ttf",
  "p",
  0.5,
  0
  MDepTexte(-2*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "h",
  0.5,
  0
  MDepTexte(-1*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "e",
  0.5,
  0
  MDepTexte(0*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "r",
  0.5,
  0
  MDepTexte(1*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "e",
  0.5,
  0
  MDepTexte(2*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "s",
  0.5,
  0
  MDepTexte(3*Angle+AngOff)
#declare AngOff = AngOff + 120;
#declare i = i + 1;
#end // while
of
would
> Thanks,
> Hershel
Date: 14 Feb 2002 08:33:54
Message: <pren6u0olknsehje4gi23m9i8jn5bnrn65@4ax.com>
On Thu, 14 Feb 2002 15:14:43 +0200, "Hershel Robinson" <her### [at] yahoocom>
If you want bend text but each letter can stay as is then you can use this
method:
1. split text into letters
2. measure width of each letter
3. create spline along  column
4. walk along spline and measure distance to its origin
5. put every next letter when the measured distance = width of previous letter
note: remember to reorient letter according to current dirrection of spline
something similiar was done in circle_text macro in 3.5
ABX
Date: 14 Feb 2002 08:55:44
Message: <slrna6ngf2.vgm.ron.parker@fwi.com>
Somebody sit down with the object pattern and a cylinder warp and an
isosurface and whip something up for the poor chap, eh?  I would, but I
don't happen to have a running copy of POV at the moment.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 14 Feb 2002 09:14:17
Message: <dmgn6u8f93mc51mqg6g0pbrckt9t82stq2@4ax.com>
I have tried isosurfaces bulided from object patter with megapov but it was
explained to me (iirc in p.u-p) that it is impossible to properly calculate
normal (iirc it was connected with gradient)
(my try is at http://www.abx.art.pl/pov/nonlinear/twist.jpg )
so does your reply means it is now possible in 3.5 ?
Is "yes" then great - I'll refresh my scripts probably.
ABX
Date: 14 Feb 2002 09:18:11
Message: <3C6BC723.B154333A@gmx.de>
Ron, you disappoint me.
You should really know that object pattern & isosurface are not a very
good combination.
Get back to your source files and don't try solving trivial users'
problems... ;-)
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 14 Feb 2002 09:24:06
Message: <3c6bc886$1@news.povray.org>
<snip>
As Bill said, the question is, do you need to bend each individual letter? If
not, Bill's script will probably do it.
Also, you could improve the final appearence by intersecting the text with a
column slightly wider than the column that will hold the letters. This will give
the text a curved surface.
Date: 14 Feb 2002 09:33:25
Message: <3C6BCAB5.4FB2FD22@gmx.de>
There's a fairly elegant and fast method for this using the
'HF_Cylinder()' macro from Povray 3.5 and an object pattern function.
Of course this isn't perfect if you have a close view of the object, but
since it's probably faster than any text object CSG solution it's worth
trying.
Date: 14 Feb 2002 09:47:40
Message: <slrna6njge.vjg.ron.parker@fwi.com>
> good combination.
Yeah, what was I thinking, looking at Gilles' spherical text thing and
then extrapolating.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
